Home » Eclipse Projects » Plugin Development Environment (PDE) » PluginRegistry.getExternalModels ???
PluginRegistry.getExternalModels ??? [message #34076] Fri, 21 November 2008 14:08
I want to query a plug-in installed in the target platform referenced by
a current running Eclipse IDE.
To do that, I'm using PDE APIs.
IPluginModelBase[] targetPlatformModels =
PluginRegistry.getExternalModels();
From retrieved IPluginModelBase instances, I lookup for those that have
an extension matching a specific extension-point id.
I use the method IPluginModelBase.getExtensions() that returns
IExtensions and I get all registered extensions from
IExtensions#getExtensions.Then, I test them against the search one.
Once retrieved, I want to have access to retrieved extension data.
I call the getChildren method on retrieved IPluginExtension.
But getChildren() returns an empty array of IPluginObject. Weird because
data are well defined. If I open the manifest editor on that plug-in,
it shows me the extension with its data.
If, I use the same code to search an extension declared on a plug-in
located in the workspace, that works perfectly.
Hence, I don't understand what I have missed.
I have tried to debug the ManifestEditor when we open it from the
plugins view but I failed to figure out my issue.
Does anyone have an idea ?
Any help would be appreciated.
Stephane.
Previous Topic:API Tooling Filter IDs Explained?
Next Topic:PluginRegistry.getExternalModels ???
Current Time: Thu Jul 31 12:53:59 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
