Home » Eclipse Projects » Eclipse Platform » p2 metadata generator doesn't complete
p2 metadata generator doesn't complete [message #335736] Fri, 24 April 2009 11:50 Go to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
I'm trying to generate the p2 metadata for a Babel update site, and it's
not completing. The CPU is pegged at 100% and the artifacts.xml file
grows, then shrinks, then grows, etc.
Actually, if you refresh this page, you will see it in action:
http://build.eclipse.org/technology/babel/test-updates/galil eo/
The command I'm using is this:
eclipse/eclipse -application
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator -updateSite
/shared/technology/babel/test-updates/galileo/ -site
file:/shared/technology/babel/test-updates/galileo/site.xml
-metadataRepositoryName "Babel language packs update site" -append
-reusePack200Files -vmargs -Xmx256m
I'm using eclipse-platform-3.4.2 and I get the same results on Linux
x86_64 and Linux ppc.
Any ideas?
Re: p2 metadata generator doesn't complete [message #335757 is a reply to message #335736] Mon, 27 April 2009 16:55 Go to previous message
I've also tried Eclipse 3.5M6 with the same results. If I remove the
MASSIVE plugins/ and features/ directories, the generation takes a
fraction of a second.
Any hints?
Previous Topic:access file within plug-in?
Next Topic:set run configuration programmtical, launch programmatical
Current Time: Tue Jul 22 14:48:52 EDT 2025
Powered by FUDForum. Page generated in 0.25231 seconds
