Home » Eclipse Projects » Eclipse Platform » Missing Required Bundle org.eclipse.wst.common.modulecore_0.0.0
Missing Required Bundle org.eclipse.wst.common.modulecore_0.0.0 [message #335697] Wed, 22 April 2009 11:24 Go to next message
I have developed an eclipse plug-in using Eclipse 3.3.2.
The plug-in makes use of api from the package :
org.eclipse.wst.common.componentcore like
ModuleCoreNature, IVirtualComponent, IVirtualFolder, etc.
I could install, use and test my plug-in on 3.3.2.
I tried to install the same on Eclipse 3.4.
The installation seemed fine but when I didn't see my menus, views,
perspective, etc, I tried to diagnose my plug-in from plug-in registry
view.
It comes up with a dialog saying "Missing Required Bundle
org.eclipse.wst.common.modulecore_0.0.0".
To overcome this, from this page
http://download.eclipse.org/webtools/downloads/drops/R3.0/R- 3.0.3-20081113203138/
I downloaded wtp-R-3.0.3-20081113203138.zip and unzipped it in a tmp dir.
I copied all plug-ins from the plugins directory and pasted in
<eclipse-3.4 installdir>/plugins.
I did the same with features.
I started Eclipse with -clean option. Still my plug-in doesn't show up in
3.4.
I tried the diagnose thing again, and came across same result ie :
"Missing Required Bundle org.eclipse.wst.common.modulecore_0.0.0".
How do I solve this problem?
Moreover what should go in the zip of my plug-in so that it would be self
content?
Thanks.
Re: Missing Required Bundle org.eclipse.wst.common.modulecore_0.0.0 [message #335730 is a reply to message #335697] Fri, 24 April 2009 06:31 Go to previous messageGo to next message
Use the Update Manager to install the plugins. If thats not possible, at
least try to put those plugins and features in the dropins folder - not
in the plugins/features. See:
http://wiki.eclipse.org/Equinox_p2_Getting_Started
- Prakash
http://blog.eclipse-tips.com
Re: Missing Required Bundle org.eclipse.wst.common.modulecore_0.0.0 [message #335761 is a reply to message #335730] Tue, 28 April 2009 07:06 Go to previous message
> - Prakash
Hi Prakash,
As said my plug-in makes use of wtp api. So it needs to be there on the
platform.
So I had to install wtp first. But then found out the hard way that,
to be able to install and use wtp plug-in, I needed all of the following
which I downloaded and installed.
emf-sdo-xsd-SDK-2.4.2.zip
GEF-runtime-3.4.2.zip
dtp_1.6.2.zip
And then my plug-in worked like a charm.
Thanks for your reply though.
Previous Topic:set run configuration programmtical, launch programmatical
Next Topic:How to get IEditorPart ID from IContentType?
Current Time: Sat Jul 26 05:18:47 EDT 2025
Powered by FUDForum. Page generated in 0.07316 seconds
