Home » Archived » XML Schema Definition (XSD) » Headless xsd2genmodel ?
Headless xsd2genmodel ? [message #34074] |
Mon, 15 December 2003 16:42  |
Is there a headless way to generate an genmodel from a schema file?
Like: org.eclipse.emf.codegen.ecore.Rose2GenModel
Ron
Re: Headless xsd2genmodel ? [message #34212 is a reply to message #34109] |
Wed, 17 December 2003 08:50   |
--------------41135B3281491240D74C8D12
Content-Type: text/plain; charset=us-ascii
Ron,
We plan to make another 2.0 drop available by the end of the week with some
minor fixes and enhancements. One of the things included will be the attached
implementation of XSD2GenModel; this registration in the plugin.xml is needed to
make it work:
<extension id="XSD2GenModel" point="org.eclipse.core.runtime.applications">
<application>
<run class="org.eclipse.emf.codegen.ecore.XSD2GenModel"/>
</application>
</extension>
dudeUnit wrote:
> According to a post in the EMF newsgroup, such an implementation might
> be available in January using the 2.0 base.
> Myself, I am trying to code this but am having problems due to lack of
> documentation. The rose2ecore source is not much help to a newbie like me :(
> -du
> > Thanks,
> > Ron
Content-Type: text/plain; charset=us-ascii;
name="XSD2GenModel.java"
Content-Disposition: inline;
filename="XSD2GenModel.java"
* <copyright>
* Copyright (c) 2002 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Common Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/cpl-v10.html
* Contributors:
* IBM - Initial API and implementation
* </copyright>
* %W%
* @version %I% %H%
package org.eclipse.emf.codegen.ecore;
import java.io.File;
import java.util.ArrayList;
import java.util.Collection;
import java.util.Collections;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import org.eclipse.core.boot.IPlatformRunnable;
import org.eclipse.core.resources.IWorkspace;
import org.eclipse.core.resources.IWorkspaceRunnable;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.core.runtime.Platform;
import org.eclipse.core.runtime.Plugin;
import org.eclipse.core.runtime.Status;
import org.eclipse.core.runtime.SubProgressMonitor;
import org.eclipse.emf.codegen.ecore.genmodel.GenModel;
import org.eclipse.emf.codegen.ecore.genmodel.GenModelFactory;
import org.eclipse.emf.codegen.ecore.genmodel.GenPackage;
import org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelFactoryI mpl;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.ExtendedMetaData;
* This implements the method {@link #run},
* which is called just like main during headless workbench invocation.
public class XSD2GenModel extends Generator
protected Object xsdEcoreBuilder;
protected Map packageInformationMap;
protected List packages;
protected List ePackageList;
protected List generatedEPackageList;
protected List referencedEPackageList;
* This creates an instance.
public XSD2GenModel()
protected void printUsage()
System.out.println("Usage: { <model.xsd> | <model.wsdl> }+ [ <model.genmodel> ] <OPTION>");
System.out.println("<OPTION> ::= [ <PROJECT-OPTION> ] [ <PACKAGE-MAP> ] [ <PACKAGES> ]");
System.out.println(" [ <TEMPLATE-PATH> ] [ <COPYRIGHT> ]");
System.out.println("<PROJECT-OPTION> ::= <MODEL-PROJECT> [ <EDIT-PROJECT> ] [ <EDITOR-PROJECT> ]");
System.out.println("<MODEL-PROJECT> ::= -modelProject <model-directory> <fragment-path>");
System.out.println("<EDIT-PROJECT> ::= -editProject <edit-directory> <fragment-path>");
System.out.println("<EDITOR-PROJECT> ::= -editorProject <editor-directory> <fragment-path>");
System.out.println("<PACKAGE-MAP> ::= -packageMap { <nsURI> <qualified-package-name> }+");
System.out.println("<PACKAGES> ::= -packages { <nsURI> }+");
System.out.println("<TEMPLATE-PATH> ::= -templatePath <template-directory>");
System.out.println("<COPYRIGHT> ::= -copyright <copyright-string>");
System.out.println("");
System.out.println("Specifying no -packages is the same as specifying them all");
System.out.println("Use ##local to represent the null nsURI");
System.out.println("For example:");
System.out.println(" xsd2genmodel");
System.out.println(" example.xsd");
System.out.println(" result/src/model/Example.genmodel");
System.out.println(" -modelProject result src");
System.out.println(" -editProject result.edit src");
System.out.println(" -editorProject result.editor src");
System.out.println(" -packages http://www.example.com/Example1");
* This is called with the command line arguments of a headless workbench invocation.
public Object run(Object object)
try
final String[] arguments = (String[])object;
final IWorkspace workspace = ResourcesPlugin.getWorkspace();
IWorkspaceRunnable runnable =
new IWorkspaceRunnable()
public void run(IProgressMonitor progressMonitor) throws CoreException
try
if (arguments.length == 0 || arguments[0].equalsIgnoreCase("-help"))
printUsage();
else
execute(progressMonitor, arguments);
catch (Exception exception)
throw
new CoreException
(new Status
(IStatus.ERROR, CodeGenEcorePlugin.getPlugin().getDescriptor().getUniqueIden tifier(), 0, "Error", exception));
finally
progressMonitor.done();
workspace.run(runnable, new StreamProgressMonitor(System.out));
return new Integer(0);
exception.printStackTrace();
CodeGenEcorePlugin.INSTANCE.log(exception);
return new Integer(1);
public void execute(IProgressMonitor progressMonitor, String [] arguments) throws Exception
Plugin xsdPlugin = Platform.getPlugin("org.eclipse.xsd");
Class theGeneratorClass = xsdPlugin.getClass().getClassLoader().loadClass("org.eclipse.xsd.ecore.XSDEcoreBuilder ");
xsdEcoreBuilder = theGeneratorClass.newInstance();
packageInformationMap = new HashMap();
packages = new ArrayList();
ePackageList = new ArrayList();
generatedEPackageList = new ArrayList();
referencedEPackageList = new ArrayList();
List modelURIs = new ArrayList();
int index = 0;
for (String modelURI = arguments[index]; modelURI.endsWith(".wsdl") || modelURI.endsWith(".xsd"); modelURI = arguments[index])
// This let's us test whether the string exists as a file.
// It not, we try as a URI.
URI uri;
File file = new File(modelURI);
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(modelURI);
modelURIs.add(uri);
if (++index >= arguments.length)
break;
IPath genModelPath =
arguments.length > index && !arguments[index].startsWith("-") ?
new Path(new File(arguments[index++]).getAbsolutePath()) :
new Path(new File(((URI)modelURIs.get(0)).trimFileExtension().appendFileE xtension( "genmodel").lastSegment()).getAbsolutePath());
URI genModelURI = URI.createFileURI(genModelPath.toOSString());
IPath modelProjectLocationPath = null;
IPath modelFragmentPath = null;
IPath editProjectLocationPath = null;
IPath editFragmentPath = null;
IPath editorProjectLocationPath = null;
IPath editorFragmentPath = null;
String templatePath = null;
String copyright = null;
for (; index < arguments.length; ++index)
if (arguments[index].equalsIgnoreCase("-modelProject"))
modelProjectLocationPath = new Path(new File(arguments[++index]).getAbsolutePath());
modelFragmentPath = new Path(arguments[++index]);
else if (arguments[index].equalsIgnoreCase("-editProject"))
editProjectLocationPath = new Path(new File(arguments[++index]).getAbsolutePath());
editFragmentPath = new Path(arguments[++index]);
else if (arguments[index].equalsIgnoreCase("-editorProject"))
editorProjectLocationPath = new Path(new File(arguments[++index]).getAbsolutePath());
editorFragmentPath = new Path(arguments[++index]);
else if (arguments[index].equalsIgnoreCase("-packagemap"))
do
String nsURI = arguments[++index];
if ("##local".equals(nsURI))
nsURI = null;
String packageName = arguments[++index];
packageInformationMap.put(nsURI, packageName);
while (index + 1 < arguments.length && !arguments[index + 1].startsWith("-"));
else if (arguments[index].equalsIgnoreCase("-packages"))
do
nsURI = null;
packages.add(nsURI);
else if (arguments[index].equalsIgnoreCase("-copyright"))
copyright = arguments[++index];
else if (arguments[index].equalsIgnoreCase("-templatePath"))
do
templatePath = URI.createFileURI(new File(arguments[++index]).getAbsolutePath()).toString();
else
throw
new CoreException
(new Status
(IStatus.ERROR,
0,
"Unrecognized argument: '" + arguments[index] + "'",
null));
if (modelProjectLocationPath == null)
modelProjectLocationPath = new Path(new File(".").getAbsolutePath());
if (modelFragmentPath == null)
modelFragmentPath = new Path(".");
ePackageList.addAll
((Collection)theGeneratorClass.getDeclaredMethod
("generate", new Class [] { Collection.class }).invoke(xsdEcoreBuilder, new Object [] { modelURIs }));
if (!ePackageList.isEmpty() && ePackageList.get(ePackageList.size() - 1) instanceof List)
List diagnostics = (List)ePackageList.remove(ePackageList.size() - 1);
if (!diagnostics.isEmpty())
System.err.println("Diagnostics were encountered processing the schemas.");
for (Iterator i = diagnostics.iterator(); i.hasNext(); )
List information = (List)i.next();
System.err.println(information.get(1));
ResourceSet resourceSet = new ResourceSetImpl();
for (Iterator i = ePackageList.iterator(); i.hasNext(); )
EPackage ePackage = (EPackage)i.next();
String namespace = ExtendedMetaData.INSTANCE.getNamespace(ePackage);
if (packageInformationMap.containsKey(namespace))
ePackage.setName((String)packageInformationMap.get(namespace ));
String ecoreFileName = ePackage.getName() + ".ecore";
URI ecoreURI = URI.createURI(ecoreFileName).resolve(genModelURI);
Resource resource = resourceSet.createResource(ecoreURI);
resource.getContents().add(ePackage);
Resource genModelResource = resourceSet.createResource(genModelURI);
GenModelFactory genModelFactory = GenModelFactory.eINSTANCE;
GenModel generatedGenModel = genModelFactory.createGenModel();
String modelName = genModelURI.trimFileExtension().lastSegment();
modelName = Character.toUpperCase(modelName.charAt(0)) + modelName.substring(1);
generatedGenModel.setModelName(modelName);
genModelResource.getContents().add(generatedGenModel);
GenModel referencedGenModel = genModelFactory.createGenModel();
genModelResource.getContents().add(referencedGenModel);
if (packages.isEmpty())
generatedEPackageList.addAll(ePackageList);
else
for (Iterator i = packages.iterator(); i.hasNext(); )
String nsURI = (String)i.next();
for (Iterator j = ePackageList.iterator(); j.hasNext(); )
EPackage ePackage = (EPackage)j.next();
if (nsURI == null ? namespace == null : namespace.equals(nsURI))
generatedEPackageList.add(ePackage);
referencedEPackageList.addAll(ePackageList);
referencedEPackageList.removeAll(generatedEPackageList);
// Initialize the GenModel with all the computed data.
generatedGenModel.initialize(generatedEPackageList);
referencedGenModel.initialize(referencedEPackageList);
generatedGenModel.getUsedGenPackages().addAll(referencedGenM odel.getGenPackages());
generatedGenModel.setModelPluginID
(((GenPackage)generatedGenModel.getGenPackages().get(0)).get InterfacePackageName());
generatedGenModel.setEditPluginClass
(generatedGenModel.getModelPluginID() + ".provider." +
Generator.validName(generatedGenModel.getModelName()) + "EditPlugin");
generatedGenModel.setEditorPluginClass
(generatedGenModel.getModelPluginID() + ".presentation." +
Generator.validName(generatedGenModel.getModelName()) + "EditorPlugin");
generatedGenModel.setModelDirectory(modelProjectLocationPath + "/./" + modelFragmentPath + "/.");
if (editProjectLocationPath != null)
generatedGenModel.setEditDirectory(editProjectLocationPath + "/./" + editFragmentPath + "/.");
if (editorProjectLocationPath != null)
generatedGenModel.setEditorDirectory(editorProjectLocationPa th + "/./" + editorFragmentPath + "/.");
if (templatePath != null)
generatedGenModel.setTemplateDirectory(templatePath);
generatedGenModel.setDynamicTemplates(true);
if (copyright != null)
generatedGenModel.setCopyrightText(copyright);
for (Iterator i = modelURIs.iterator(); i.hasNext(); )
generatedGenModel.getForeignModel().add(i.next().toString()) ;
referencedGenModel.getForeignModel().addAll(generatedGenMode l.getForeignModel());
// This walks the tree to set base packages and prefixes.
setGenPackageDetails(generatedGenModel.getGenPackages());
setGenPackageDetails(referencedGenModel.getGenPackages());
List missingPackages = generatedGenModel.getMissingPackages();
for (Iterator i = missingPackages.iterator(); i.hasNext(); )
System.err.println("The EPackage '" + ePackage.getName() + "' is used, but there's no GenPackage for it.");
for (Iterator resources = resourceSet.getResources().iterator(); resources.hasNext(); )
Resource resource = (Resource)resources.next();
resource.save(Collections.EMPTY_MAP);
protected void setGenPackageDetails(List genPackages)
// Set the package-specific base package and prefix information into the GenPackages.
for (Iterator i = genPackages.iterator(); i.hasNext(); )
GenPackage genPackage = (GenPackage)i.next();
EPackage ePackage = genPackage.getEcorePackage();
String name = ePackage.getName();
int index = name.lastIndexOf(".");
if (index != -1)
genPackage.setBasePackage(name.substring(0, index));
name = name.substring(index + 1);
ePackage.setName(name);
genPackage.setPrefix(Character.toUpperCase(name.charAt(0)) + name.substring(1));
// Recursively deal with subpackages.
setGenPackageDetails(genPackage.getNestedGenPackages());
--------------41135B3281491240D74C8D12--
Re: Headless xsd2genmodel ? [message #34619 is a reply to message #34212] |
Thu, 18 December 2003 18:53  |
Hi Ed, thanks for posting this. I actually ended up writing my own, but I
look forward to the next drop so I can see how it should have been done :)
Ed Merks wrote:
> Ron,
attached
needed to
> make it work:
> <application>
> </application>
> </extension>
> > -du
> > > Thanks,
> > > Ron
Re: Headless xsd2genmodel ? [message #581513 is a reply to message #34074] |
Mon, 15 December 2003 17:20  |
-du
> Ron
Re: Headless xsd2genmodel ? [message #581540 is a reply to message #34074] |
Mon, 15 December 2003 17:27  |
Ron,
No, we don't have the scaffolding to do this yet, but we do expect to be
working on it early in the new year...
> Ron
Re: Headless xsd2genmodel ? [message #581561 is a reply to message #34143] |
Mon, 15 December 2003 18:02  |
Hi Ed, thanks for the quick response. Considering what I think are the
options:
A) Grinding the code out myself. (XSD ---> my code ---> genmodel)
B) I noticed that there is a project on sourceforge called "crazybeans"
that can read and write rational rose mdl's.
C) I could use XSLT to create the .genmodel and .ecore.
... My schemas aren't particularly complicated so I'll probably look at C
first.
Ron
Ed Merks wrote:
> Ron,
> > Thanks,
> > Ron
Re: Headless xsd2genmodel ? [message #581582 is a reply to message #34109] |
Ron,
make it work:
<application>
</application>
</extension>
> -du
> > Thanks,
> > Ron
* <copyright>
* Contributors:
* </copyright>
* %W%
* @version %I% %H%
try
try
printUsage();
else
throw
new CoreException
(new Status
finally
int index = 0;
URI uri;
if (file.isFile())
else
modelURIs.add(uri);
break;
do
nsURI = null;
do
nsURI = null;
do
else
throw
new CoreException
(new Status
(IStatus.ERROR,
0,
null));
ePackageList.addAll
else
if (index != -1)
Re: Headless xsd2genmodel ? [message #581976 is a reply to message #34212] |
Ed Merks wrote:
> Ron,
attached
needed to
> make it work:
> <application>
> </application>
> </extension>
> > -du
> > > Thanks,
> > > Ron
Current Time: Wed Jul 30 18:12:29 EDT 2025
Powered by FUDForum. Page generated in 0.04477 seconds
