Home » Eclipse Projects » Eclipse Platform » Bug in saving file with same name as other open modified files
Bug in saving file with same name as other open modified files [message #335650] Sat, 18 April 2009 08:06 Go to next message
Hello eclipse users,
I believe I've found a bug in eclipse 3.4.2 (Build id: M20090211-1700). If
one opens and modifies without saving multiple files that have same name
but are on different paths (e.g. pom.xml files each belonging to a
different project in workspace), and if then one saves a single one of
them, eclipse will save file that has focus but will also wrongly mark all
the other open files with same name as saved one and will treat them as
files with no unsaved modifications, so when they get closed eclipse won't
report that there are unsaved modifications.
Stevo.
Re: Bug in saving file with same name as other open modified files [message #335656 is a reply to message #335650] Mon, 20 April 2009 04:22 Go to previous messageGo to next message
> M20090211-1700). If one opens and modifies without saving multiple
> files that have same name but are on different paths (e.g. pom.xml
> files each belonging to a different project in workspace), and if then
> one saves a single one of them, eclipse will save file that has focus
> but will also wrongly mark all the other open files with same name as
> saved one and will treat them as files with no unsaved modifications,
> so when they get closed eclipse won't report that there are unsaved
> modifications.
Looks like a bug. Please file it against the XML editor that has this
problem.
Dani
> Stevo.
Re: Bug in saving file with same name as other open modified files [message #335667 is a reply to message #335656] Mon, 20 April 2009 11:26 Go to previous messageGo to next message
>> modifications.
> problem.
> Dani
This is a bug in the Maven POM editor that is a part of m2eclipse. The
XML editor works correctly.
You can create a bug against m2eclipse
https://issues.sonatype.org/secure/BrowseProject.jspa
Snjeza
Re: Bug in saving file with same name as other open modified files [message #335676 is a reply to message #335667] Mon, 20 April 2009 19:11 Go to previous message
Created issue https://issues.sonatype.org/browse/MNGECLIPSE-1312
Thanks!
Stevo.
Previous Topic:[DataBinding] How to report an error during databinding update
Next Topic:update Site Problem
Current Time: Sun Aug 31 03:31:04 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
