Home » Eclipse Projects » Eclipse Platform » Re: Painting in a composite
| Re: Painting in a composite [message #335644] |
Fri, 17 April 2009 12:32  |
Originally posted by: riwright.adobe.com
(Included eclipse.platform as this appears related to Forms, which I think
are more of a platform issue than SWT)
I have now boiled this down. I have a FormPage which hosts a CTabFolder
which has one or more CTabItems in it.That all works fine. Now I want to
have custom drawing widgets hosted in the Tabs. The issue is that I never
get paint events. If I have code like:
ScrolledForm form = managedForm.getForm();
CTabFolder tabFolder = new CTabFolder(form.getBody(), SWT.FLAT|SWT.TOP);
CTabItem viewItem = new CTabItem(tabFolder.SWT.NULL);
Composite composite = new Composite(tabFolder, SWT.NONE);
composite.addPaintListener (new PaintListener() {
public void paintControl (PaintEvent e) {
e.gc.setBackground (red);
e.gc.fillOval (5, 5, 690, 590);
The paintListener never gets any events. This approach works fine in a
FormPage, for example, but not in a CTabItem. Seems like it should, but...
Is this expected behaviour? Any suggestions? What is the proper approach to
this? I'll keep poking at it, but any suggestions are welcome.
TIA, Ric
On 4/16/09 10:07 AM, in article C60CB3D7.27314%riwright@adobe.com, "Ric
Wright" <riwright@adobe.com> wrote:
> I am writing a program that has a rather elaborate "editor" akin to the PDE.
> I have most of it working and am working on the last part of the UI. I have
> a FormPage which hosts a TabFolder which has one or more TabItems in it.
> That all works fine. Now I want to have various kinds of widgets hosted in
> the Tabs. One of them is my JOGL OpenGL view. Normally I simply host it in
> a ViewPart and then instantiate it thusly:
> // we can't use the default Composite because using the AWT bridge
> // requires that it have the property of SWT.EMBEDDED
> Composite composite = new Composite(parent, SWT.EMBEDDED);
> // set the layout so our canvas fills the whole control
> composite.setLayout(new FillLayout());
> // create the special frame bridge to AWT
> java.awt.Frame glFrame = SWT_AWT.new_Frame(composite);
> // we need the listener so we get the GL events
> this.canvas.addGLEventListener(this);
> // finally, add our canvas as a child of the frame
> glFrame.add(this.canvas);
> This all works fine. I created a new class that subclasses Composite to
> create a GLComposite. I then create an instance of that:
> GLComposite glView = new GLComposite(composite);
> ViewItem.setControl(composite);
> This all "works" fine - there are no exceptions thrown and I can debug
> through my GL routines, but nothing gets painted on the tab. And my GL
> renderer only gets called if I explicitly call redraw on the glView object.
> So... Any suggestions? What is the proper approach to this? I'll keep
> TIA, Ric
| Solved - Re: Painting in a composite [message #335645 is a reply to message #335644] |
Fri, 17 April 2009 19:36  |
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3322830980_71983404
Content-type: text/plain;
charset="US-ASCII"
Content-transfer-encoding: 7bit
Turned out to be one of those Doh! Moments. I cloned the TabFolder code
from an excellent tutorial by Dejan Glozic (
http://www.eclipse.org/articles/Article-Forms/article.html).
However, the way he demonstrates CTabFolder usage is a little weird. He
essentially uses the tabs as selection buttons to swap the text in a static
Composite. This isn't obvious until you study the code carefully. But I
didn't use that static composite piece anyway. But I DID simply cut and past
the first part of his createFormControl, which included:
GridLayout gd = newGridData(GridData.FILL_HORIZONTAL);
TabFolder.setLayoutData(gd);
Since he was using a static composite to paint on, the fact that the
TabFolder had no height didn't matter. And since mine too thus had no
height Eclipse felt I didn't have any space to paint, so why send messages?
Once I added GridData.FILL_VERTICAL, everything worked as expected. And even
the GL stuff now works fine (see attachment).
Ric
On 4/17/09 9:32 AM, in article C60DFD20.27609%riwright@adobe.com, "Ric
> TIA, Ric
>> TIA, Ric
Content-type: application/octet-stream; name="tab_gl.jpg"
Content-disposition: attachment;
filename="tab_gl.jpg"
Content-transfer-encoding: base64
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAMRBLwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD0C5vbLVoxe6mkt4kx8y3t CSscUfO0lQcF
yDyeepA44qps0D/oX7f/AMe/xplhEW0uzbHH2eP/ANAFVtclmtreM2EMzufv YhLf0rqhDmdk
LpcubNA/6F+3/wDHv8aNmgf9C/b/APj3+NY+gajeX8stve2M0MiDcsjxFQwz jv3q9rV0dH0W
81Ew+b9njMnl7tu7HbODiiceR2YlrsWtmgf9C/b/APj3+NGzQP8AoX7f/wAe /wAagF9Yfa47
Nry1W8kUMtuZl8w5GeFzk8e1PFzZGGGYXdsYpn8uJ/MXa78japzyeDwPSp0C 5Js0D/oX7f8A
8e/xo2aB/wBC/b/+Pf41FaXlhfySx2d7a3LxHEiwyq5T6gHjoatfZz6UaARb NA/6F+3/APHv
8aNmgf8AQv2//j3+NZet61Do9zZWY+zteXsmyKOecRKBj7zNgkDsODkkCr6X Vk981it3ateo
Nz26yqXUeu3rjkdu9CaYyXZoH/Qv2/8A49/jRs0D/oX7f/x7/Go7a6sryeaC 1vLaeaE4ljil
VmjPT5gDkdO9Z8Gvacbb7Re3VpYxPNJHAbidU81UbaWGcdx78Y9aLoDU2aB/ 0L9v/wCPf40b
NA/6F+3/APHv8aglv9Ngginm1CzjhlQvHI8yhXUYyQSeRyOfelN7p4uobY31 p9onUPFF5y75
FPQqM5I4PSjQVybZoH/Qv2//AI9/jRs0D/oX7f8A8e/xqha6nDcXepozWq21 iVDTrdI3Ylty
g5j2kEfN6VYS+06Swa/S/tGs1+9cLMpjH1bOKLoZPs0D/oX7f/x7/GjZoH/Q v2//AI9/jWVc
+JNFtrqwge/tyL4MYpVlQx4XuWzjk8D1PFa04itYHnuJI4oUG55JGCqo9ST0 o0EJs0D/AKF+
3/8AHv8AGjZoH/Qv2/8A49/jVRNX0iS3Nwmq2DQBipkW4QqCBuIznGcAn6Cp IL/TrqdILe/t
JZpE8xI45lZmT+8ADyPejQLk+zQP+hft/wDx7/GjZoH/AEL9v/49/jUVneWG otItle2ty0RA
kEEquU+uDx0P5Va+zn0o0Ai2aB/0L9v/AOPf40bNA/6F+3/8e/xrKudQvv7f k0qxsLaV47Zb
hpJ7lohhmK4AEbelX5buztriG1uru0hu5gNkLTAM5PHyg4J546UJpj2Jtmgf 9C/b/wDj3+NG
zQP+hft//Hv8awovEQmEgFvAki6mdPVJbpULgEAuu7GTznaMmtOPVNKmvfsU Wp2L3e4r5Czo
XyOo25zkYNCaYPQtbNA/6F+3/wDHv8aNmgf9C/b/APj3+NQxXlhPeS2cN7ay XUQJkhSVS6Ad
cqDkdaWyurLUkd7G8trpUOGMEquFPocHijQRLs0D/oX7f/x7/GjZoH/Qv2// AI9/jWSmqXN1
rN3YWNjBKtlJHHcNJc7HG/B3Km05ABzyRnBAqpF4jm+e5uNOjj09b5rIzpcF nVg+wMyFQApO
OjEjPShNMb0Oh2aB/wBC/b/+Pf40bNA/6F+3/wDHv8a5+LxN9ovBYW9iJL1r 2W2WLzcARxkb
pWOPlHPTByeK6X7OfShNNXFs7EWzQP8AoX7f/wAe/wAaNmgf9C/b/wDj3+NS /Zz6UfZz6UaA
RbNA/wChft//AB7/ABo2aB/0L9v/AOPf41L9nPpR9nPpRoBFs0D/AKF+3/8A Hv8AGjZoH/Qv
2/8A49/jUv2c+lH2c+lGgEWzQP8AoX7f/wAe/wAaNmgf9C/b/wDj3+NS/Zz6 UfZz6UaARbNA
/wChft//AB7/ABo2aB/0L9v/AOPf41L9nPpR9nPpRoBFs0D/AKF+3/8AHv8A GjZoH/Qv2/8A
49/jUv2c+lH2c+lGgEWzQP8AoX7f/wAe/wAaNmgf9C/b/wDj3+NS/Zz6UfZz 6UaARbNA/wCh
ft//AB7/ABo2aB/0L9v/AOPf41L9nPpR9nPpRoBFs0D/AKF+3/8AHv8AGjZo H/Qv2/8A49/j
Uv2c+lH2c+lGgEWzQP8AoX7f/wAe/wAaNmgf9C/b/wDj3+NS/Zz6UfZz6UaB ci2aB/0L9v8A
+Pf40bNA/wChft//AB7/ABqX7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+ 3/8AHv8AGpfs
59KPs59KNAItmgf9C/b/APj3+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2a B/0L9v8A+Pf4
0bNA/wChft//AB7/ABqX7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8A Hv8AGpfs59KP
s59KNAItmgf9C/b/APj3+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L 9v8A+Pf40bNA
/wChft//AB7/ABqX7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8A Gpfs59KPs59K
NAItmgf9C/b/APj3+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A +Pf40bNA/wCh
ft//AB7/ABqX7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs 59KPs59KNAIt
mgf9C/b/APj3+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf4 0bNA/wChft//
AB7/ABqX7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KP s59KNAItmgf9
C/b/APj3+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA /wChft//AB7/
ABqX7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59K NAItmgf9C/b/
APj3+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wCh ft//AB7/ABqX
7OfSj7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAIt mgf9C/b/APj3
+NGzQP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft// AB7/ABqX7OfS
j7OfSjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9 C/b/APj3+NGz
QP8AoX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ ABqX7OfSj7Of
SjQCLZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/ APj3+NGzQP8A
oX7f/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ABqX 7OfSj7OfSjQC
LZoH/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/APj3 +NGzQP8AoX7f
/wAe/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ABqX7OfS j7OfSjQCLZoH
/Qv2/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/APj3+NGz QP8AoX7f/wAe
/wAal+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ABqX7OfSj7Of SjQCLZoH/Qv2
/wD49/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/APj3+NGzQP8A oX7f/wAe/wAa
l+zn0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ABqX7OfSj7OfSjQC LZoH/Qv2/wD4
9/jRs0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/APj3+NGzQP8AoX7f /wAe/wAal+zn
0o+zn0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ABqX7OfSj7OfSjQCLZoH /Qv2/wD49/jR
s0D/AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/APj3+NGzQP8AoX7f/wAe /wAal+zn0o+z
n0o0Ai2aB/0L9v8A+Pf40bNA/wChft//AB7/ABqX7OfSj7OfSjQCLZoH/Qv2 /wD49/jRs0D/
AKF+3/8AHv8AGpfs59KPs59KNAItmgf9C/b/APj3+NGzQP8AoX7f/wAe/wAa l+zn0o+zn0o0
AhA0FphDH4ciklYZCRxu7Y9cAk4qX7Hpn/QoTf8AgJN/hVrR3a21O8xwTDF/ 6FJW39tf+8aT
YzlpotFt033HhcwpkDfLbyouT7nikRNCllaKHw2k0ijLLDFI5Ue+3OK3NZu2 k0O/UnINvJ1/
3TWbZ3kmmaTrtxG6I8AkmBZSwBSBW5AIJHHTNHQRF9j0z/oUJv8AwEm/wqOW PRICgn8MiDec
KZoZEDH0BbHNN+3/ABD/AOeGjfp/8fqYanqGp+FQdTSJLxbzyZUiGFDR3Ozj k/3fU0f1uMrC
Tw+8jRx+GxMyHDeTBLJtPoSueaft0X/oU5v/AACn/wAKyNOuI0vJYLi7uLWA 3MqvNbhS6fvG
5AYEdevB4zjmtwWesi6khu54rexiQSSapGAY3iP3TEDnLt02nO08ncNvmcbx FRt8qPTngqcE
uZvVX9fJaEUMnh37Usb6E9rMPnRgksMikfxKTg5HHTpxWmPHFp4fH2DUWvLw gBoJkRSzRHpv
JYZYHIz3AHU5Ncr5/wBp1qyjWSWVBM21pQN7ARvgttwM4644rN8XqV1O3B/5 9x/6G1b0Ze1j
eRzYugqE1FdVc9C0XTzP4esGx961j5/4CK43xN4T8UmZ30q0s7lGP3WhgBH4 uOa7DR9dng02
ysLbTXuGgsrd2YOo++gI6sPQ/lWh/bupf9AOT/v7H/8AF1tCpODujl3Vjj/A /gvVtL8++1pb
RbuVdixW8Ea7Fzk5ZFGScD24qfxbYaxf2OoaJbaJK8d1GscN6kqGNQ33y6kh lI5wAGzx05x1
P9u6l/0A5P8Av7H/APF0f27qX/QDk/7+x/8AxdTOUpu8gWmx5xrfhfxJcao2 bG8uVgvLaa0e
O6CwLCm0suzcMyZ3HJU8dD0FasHgfUYfFs86sv8AZSB7uzjbolzIMPkegwSO P+Wh6812X9u6
l/0A5P8Av7H/APF0f27qX/QDk/7+x/8AxdRZ/wBf15feGn9f1/SPPvDXhvX4 fE9hfalYXyuL
OSC8nuLkSBpSytlAGICHBwABjuBxXcSaFcNqEdyt/cJCow1qEjMb9eSSu/PP Zuw96s/27qX/
AEA5P+/sf/xdH9u6l/0A5P8Av7H/APF09Q0MHXfD97ceIfDt1b25kgtbiVp2 BHyK0ZUHHU8n
tXNf8IfrbNbaV9ikiNvqc15/agZCro28gDB3bjvAOQB8vU8Z9D/t3Uv+gHJ/ 39j/APi6P7d1
L/oByf8Af2P/AOLpWf8AXy/yHf8Ar7/8zze38NeI4INNS30d7e70jT57cSGR Nl1IwCqVIbO3
I3ndg89M1b1HT28PeIvCVrb2Nxd+VZXEYhg2ByAIxn52UfrXe/27qX/QDk/7 +x//ABdV5r+4
nuoLqXw3vuIM+VKXi3JnqAd2QDgZ+lP3r3/rr/mLQ4jSPBurQ6poV3c6eqwp cXs8se5T9l83
BRffuMgYzntyTVvCWrtcavp8OnPKmo3sFzDfqybYFXZkMM7sjYQMDHzDkc13 /wDbupf9AOT/
AL+x/wDxdH9u6l/0A5P+/sf/AMXRqrW6A9TzbV9Av9Y1zxTa6dlriF7GXYrK PMKDcUBYFc4x
jPGcZ4qx/wAIfqn7rWVtNQuZ01GO6nsrx4FllVYzHuUIBGHGQcZ5CjnPFdrp 9w2lRNFp/hdL
WNiWKQtEq5PJ4DYFXP7d1L/oByf9/Y//AIukk1/Xp/kD1OO1HR9Tm1TQtbh0 KdUtZbjz7SNo
/NAkXAY5YLnI5AJ68E1H4xi1Gfw/eb9N+yvbX9ubJpLhNtz+8XBIJA65+QkE 46iu1/t3Uv8A
oByf9/Y//i6iutTur21ktrrw559vKu2SKV4mVh6EFuaLMZ5rp2j3Gp6qcWcp 1O21qK61KF4k
jEamIhWVRI+RyP4ic5PFX7fwdq0Uenq+nHEOt3M8oDL/AKhxIAeDyDuXgc+v Suy0yT+xYTDp
nhVLSInJSFolGfoGq9/bupf9AOT/AL+x/wDxdFv6+7/IX9fn/mcf4N0PVtPu 57WayvLfSkhR
beO+aJ5I2yxKK8ZO6MZGN3NdPHoVwmoSXLX9xJC4wLVkj2IeOQQobt3Y9T7Y s/27qX/QDk/7
+x//ABdH9u6l/wBAOT/v7H/8XT94NDjdX8Pzx+Of7Ul8NzaraizjSJ4lhYxS q7HIEjqQcEci
pLbR9SsNf1OV9EkvINUlhmjmLIBCAoUpICdwKlcjaGBz1HJrrv7d1L/oByf9 /Y//AIuj+3dS
/wCgHJ/39j/+LpJNf18wep53L4P1tYrmMae5I8SJfqQ64aAtksOe3cdfaqdj p2oazYahpNpp
c5xr0khvmZBHEEm3HHzb93GB8oHPUCvUP7d1L/oByf8Af2P/AOLqva39xZGX 7L4b8nznMkgj
eJQznqxAbqe570RTX9en+Q27/wBev+ZwFx4Q12WbVtM060u7Swu4rnIu3jeN ZWI2mFlJdVbB
JVuBk962vCfhq+S/k1HUIdRhuPsyWxS7MGCFJPAhUAgE4BJyeeBxnrf7d1L/ AKAcn/f2P/4u
j+3dS/6Acn/f2P8A+Lpq6/r+u4nr/X9dji/Efhu71DXYZrHRLq11GCeMxavF IgjaL5S4cBtx
43LtKkdOQCaoR+GNduLe50STSpYIptXa7e8d0MZh83eAu1i244HUAAZ5zxXo f9u6l/0A5P8A
v7H/APF0f27qX/QDk/7+x/8AxdJJr+vT/IHr/Xr/AJnnFn4H1nSNW1DxDZWc j6gdTlZ7bzVx
dWjnovO0MPvDODkYPpXpC6eWUNtIyM4I5pP7d1L/AKAcn/f2P/4uj+3dS/6A cn/f2P8A+Lpq
6VgeruO/s0/3aP7NP92m/wBu6l/0A5P+/sf/AMXR/bupf9AOT/v7H/8AF0e8 A7+zT/do/s0/
3ab/AG7qX/QDk/7+x/8AxdH9u6l/0A5P+/sf/wAXR7wDv7NP92j+zT/dpv8A bupf9AOT/v7H
/wDF0f27qX/QDk/7+x//ABdHvAO/s0/3aP7NP92m/wBu6l/0A5P+/sf/AMXR /bupf9AOT/v7
H/8AF0e8A7+zT/do/s0/3ab/AG7qX/QDk/7+x/8AxdH9u6l/0A5P+/sf/wAX R7wDv7NP92j+
zT/dpv8Abupf9AOT/v7H/wDF0f27qX/QDk/7+x//ABdHvAO/s0/3aP7NP92m /wBu6l/0A5P+
/sf/AMXR/bupf9AOT/v7H/8AF0e8A7+zT/do/s0/3ab/AG7qX/QDk/7+x/8A xdH9u6l/0A5P
+/sf/wAXR7wDv7NP92j+zT/dpv8Abupf9AOT/v7H/wDF0f27qX/QDk/7+x// ABdHvAO/s0/3
aP7NPpTf7d1L/oByf9/Y/wD4uj+3dS/6Acn/AH9j/wDi6PeAd/Zp9KP7NPpT f7d1L/oByf8A
f2P/AOLo/t3Uv+gHJ/39j/8Ai6PeAd/Zp9KP7NPpTf7d1L/oByf9/Y//AIuj +3dS/wCgHJ/3
9j/+Lo94B39mn0o/s0+lN/t3Uv8AoByf9/Y//i6P7d1L/oByf9/Y/wD4uj3g Hf2afSj+zT6U
3+3dS/6Acn/f2P8A+Lo/t3Uv+gHJ/wB/Y/8A4uj3gHf2afSj+zT6U3+3dS/6 Acn/AH9j/wDi
6P7d1L/oByf9/Y//AIuj3gHf2afSj+zT6U3+3dS/6Acn/f2P/wCLo/t3Uv8A oByf9/Y//i6P
eAd/Zp9KP7NPpTf7d1L/AKAcn/f2P/4uj+3dS/6Acn/f2P8A+Lo94B39mn0o /s0+lN/t3Uv+
gHJ/39j/APi6P7d1L/oByf8Af2P/AOLo94B39mn0o/s0+lN/t3Uv+gHJ/wB/ Y/8A4uj+3dS/
6Acn/f2P/wCLo94B39mn0o/s0+lN/t3Uv+gHJ/39j/8Ai6P7d1L/AKAcn/f2 P/4uj3gHf2af
Sj+zT6U3+3dS/wCgHJ/39j/+Lo/t3Uv+gHJ/39j/APi6PeAd/Zp9KP7NPpTf 7d1L/oByf9/Y
/wD4uj+3dS/6Acn/AH9j/wDi6PeAd/Zp9KP7NPpTf7d1L/oByf8Af2P/AOLo /t3Uv+gHJ/39
j/8Ai6PeAd/Zp9KP7NPpTf7d1L/oByf9/Y//AIuj+3dS/wCgHJ/39j/+Lo94 B39mn0o/s0+l
N/t3Uv8AoByf9/Y//i6P7d1L/oByf9/Y/wD4uj3gHf2afSj+zT6U3+3dS/6A cn/f2P8A+Lo/
t3Uv+gHJ/wB/Y/8A4uj3gHf2afSj+zT6U3+3dS/6Acn/AH9j/wDi6P7d1L/o Byf9/Y//AIuj
3gHf2afSj+zT6U3+3dS/6Acn/f2P/wCLo/t3Uv8AoByf9/Y//i6PeAd/Zp9K P7NPpTf7d1L/
AKAcn/f2P/4uj+3dS/6Acn/f2P8A+Lo94B39mn0o/s0+lN/t3Uv+gHJ/39j/ APi6P7d1L/oB
yf8Af2P/AOLo94B39mn0o/s0+lN/t3Uv+gHJ/wB/Y/8A4uj+3dS/6Acn/f2P /wCLo94B39mn
0o/s0+lN/t3Uv+gHJ/39j/8Ai6P7d1L/AKAcn/f2P/4uj3gHf2afSj+zT6U3 +3dS/wCgHJ/3
9j/+Lo/t3Uv+gHJ/39j/APi6PeAd/Zp9KP7NP92m/wBu6l/0A5P+/sf/AMXR /bupf9AOT/v7
H/8AF0e8A7+zT/do/s0/3ab/AG7qX/QDk/7+x/8AxdH9u6l/0A5P+/sf/wAX RqA7+zT/AHaP
7NP92m/27qX/AEA5P+/sf/xdH9u6l/0A5P8Av7H/APF0agO/s0/3aP7NP92m /wBu6l/0A5P+
/sf/AMXR/bupf9AOT/v7H/8AF0agO/s0/wB2j+zT/dpv9u6l/wBAOT/v7H/8 XR/bupf9AOT/
AL+x/wDxdGoDv7NP92j+zT/dpv8Abupf9AOT/v7H/wDF0f27qX/QDk/7+x// ABdGoDv7NP8A
do/s0/3ab/bupf8AQDk/7+x//F0f27qX/QDk/wC/sf8A8XRqA7+zT/do/s0/ 3ab/AG7qX/QD
k/7+x/8AxdH9u6l/0A5P+/sf/wAXRqA7+zT/AHaP7NP92m/27qX/AEA5P+/s f/xdH9u6l/0A
5P8Av7H/APF0agO/s0/3aP7NP92m/wBu6l/0A5P+/sf/AMXR/bupf9AOT/v7 H/8AF0agO/s0
/wB2j+zT/dpv9u6l/wBAOT/v7H/8XR/bupf9AOT/AL+x/wDxdGoDv7NP92j+ zT/dpv8Abupf
9AOT/v7H/wDF0f27qX/QDk/7+x//ABdGoDv7NP8Ado/s0/3ab/bupf8AQDk/ 7+x//F0f27qX
/QDk/wC/sf8A8XRqA7+zT/do/s0/3ab/AG7qX/QDk/7+x/8AxdH9u6l/0A5P +/sf/wAXRqA7
+zT/AHaP7NP92m/27qX/AEA5P+/sf/xdH9u6l/0A5P8Av7H/APF0agO/s0/3 aP7NP92m/wBu
6l/0A5P+/sf/AMXR/bupf9AOT/v7H/8AF0agO/s0/wB2j+zT/dpv9u6l/wBA OT/v7H/8XR/b
upf9AOT/AL+x/wDxdGoDv7NP92j+zT/dpv8Abupf9AOT/v7H/wDF0f27qX/Q Dk/7+x//ABdG
oDv7NP8Ado/s0/3ab/bupf8AQDk/7+x//F0f27qX/QDk/wC/sf8A8XRqA7+z T/do/s0/3ab/
AG7qX/QDk/7+x/8AxdH9u6l/0A5P+/sf/wAXRqA7+zT/AHaP7NP92m/27qX/ AEA5P+/sf/xd
H9u6l/0A5P8Av7H/APF0agO/s0/3aP7NP92m/wBu6l/0A5P+/sf/AMXR/bup f9AOT/v7H/8A
F0agZUqJa+IjFKwRJIoAzZxgb5ATXOpceMY5YmmTSGgEi+aI5EDbMjcR++PI GT0PTpW9rFvN
rVxHcTaTeQyomzfBPECVznByT3JrO/sCT/n01b/wJgrRWtqIlv73fpt2uesD j/x00upQu0Xi
HTotnmzwTxRhnCgs1qAoySAMkgc1GmgkOpk0/U5UByY3uYdrexxg1a1Owl1S +e8fS7+CVwA/
kXEIDYGATkntQ2gIP7T1H/oDz/8AgZZ//Hqht2lMTQzReU8+ptMIy6OVWS7L qCUJXOGHQml/
sCT/AJ9NW/8AAmCp7PSHtLyG5Om6jO0Th1SW4hK7h0PBFGgHLFIX8Q3Nrc3f 2S2+2zCWcIWZ
FDt90YPJ4AyMDOSDjB2v7f0i8UaPPY/ZtDXAt2j/ANdbOM/vt3OWJYls5zk5 3ZYNLqXhiLUt
RmvTpepW7zMXdILmEKWPU4JPJqp/whcX/PprP/gXBXF7Gaeh7f1zDTiue90v u815lLQV83xZ
Y24lSYLLKFkRSokAjfDbTyMjnHOM4yetN8fxeTr8Kelsv/oTV0OiaEuhait9 DpN/cToCENxc
wsEyMEjBHOOK5zxzfrqmpWF+kZjWeyVwp/33H9K3oQcNGcOOrxr1FKPRWOv8 N/8AHy//AGDb
H/0W1U5PEOonxJd2azpHbQXKRBF0S5nLKURjmdHEan5j1HHU1c8N/wDHy/8A 2DbH/wBFtT5Y
Nbs76/On6dp89vdSiUvcai8bZ2Kp+UQMAPl/vH19hUr3OMxo/iBaWFs02pS+ Y08oNvHuht/k
8mJ2OZZFXrJ03FueMgEjsbO7g1CxgvLZ98E8ayxt6qwyD+RrEi8H21qkRsdR 1Czni+VZ4mjL
bdiIVIdGUg+Wh6ZyOCM4rfiRo4URpHlZVAMjgbmPqcADP0AFPQRl+JdSuNJ0 Vrq1KCXzoowW
t3nADuqk+WhDMcHoDms238SXcdoqyw3Op3sxcxx22mPYsqIFyzLcyDgFhznn PAODWr4hsLnU
dHkgs223QkjkibzRFhlcMDuMcgHT+4c9OOtZFjoGtXR8zWNSuIbmLKxXFtdR Su8b43xsPs0a
hcqpBALdcEd5d7ND00INO8V38tppA+yS3slxMkNwY0jQrm2EpPMgB5OcgDgE YzjPZVgweFLS
1treK2u7yJreZJo5VZCwKxCLBypBBQc5HckY4xvVbtfQSMHxFqt7pz2q28sF pBIHaa+ubWSe
KHbjAcIy7Ack72YKNvPUU0eKoI5o4pbeaWMGKKa+g2m2SV1BVQSwYg7lwQpH zDJHOHeI7LW7
prZtFuDCyhxKftawgg4xw0EoPQ84Uj1OarWHhKNYrc3BktY1aN5NNt7gTW7P GAsbbmjV8gKh
wNoyoyDyTKuMtXHiqytrWxnNvdyC9hSaJI0BbDMigEZ65kX2680s3iaOAzNL p16kFtF5l5cH
ytlqdm8q3z5ZgMZ2BhyOagg8H20MlsZNR1CdLUKlvHK0e2JFdHCjCAkZjUZY k4zzVq78OxXd
1dSG+vI7a7UrdWkZTy5srsySVLqcY+6y9BQ/L+uwK19Rnh3xXp/ib7SLI4kt 9u9POhlwGzg7
ondecHjOeOnStyqOm6fPYI6Tare34ONpuhECgHpsRc/jmr1NiOP0rxRd3uti 2N9pd0puZ4Zb
S2jIntEQvtkkbzG4OxRyq8uOexhk+ItjfaXqr6MhuLy2tHuIF86F/MAwNxVZ CVAJUkOFbHQZ
yK3/APhHrVRbmKa4imgmklSZGXcRI5Z4zkYKHPQjsD1AIhh8MrDp9xpzarqE thLAYEtpDERC
h4G1gm84HA3M3vml5Mq6vcz7XxVFpVzp+kau179tusYkvZrMSAsSACkTgkZG MqhHqeDie88V
XS6ct7ZaHfSQvcQpFI5hAnR3C7kBlBGQeNwXqMjri1P4Xgn1CS5+3XkcUs8d xJbJ5YjeRNuG
J2b+iKMbse1U77w5fQ6Q1lpt7Pcp5kZgiublIVtAjblMbrA5bBCjDhgR19zz f9f1/wAOSiSb
xnZ24lknsL+O3QShJyiFZZIwS8agPuLDa/JAU7TgnjO7aXD3Vssz201sWz+7 m27gM8E7SRz1
6555weK59fB0NxBi+vLsq6SMbUSo8UE0ikSOjeWGJ+Z8Z4+Y4UcAdOBgYpgU NbvJtO0K/vbc
IZoIHkQSAldwBIyAQcfiKyV8TyRuBcwIGgtZ5LuNXVSskZjHDOyqFIfcCxHB HIrZ1a0N/o95
aKoZpoXjAL7ASQQBu2tj64OPQ1zVx4d1HWNYW71GwtLPMQiae01JpWQq6yI4 je3ClgyLyT06
g4ApdRmhpXjHTNWhjliDpG5lUuZInRGjAYqWjdlJKncNpIwDkgjFRx+LVclY tNv7m4ZsraxR
RpJGgjjdi5eQLx5ijqDk4AOCasjwtavZTW9xd3ly01wLiWaRkDs20IR8qgBW UbSABwxxiqWu
eHL17hr3Q5TFfyyOZJWuViwrIilQDDKCP3ankAgjg84of9ev/D/gCJD4201N Q0y0kjkjbUY4
5IWeaAH9590GPzPM68ZCke+ATVFviDb2FisurWUttNJcTxxI09vEJEjcqWBe YLx8oIJBJzgE
DIu2fgyG1S3T+0rzYhgkkhQRrHLLEEAc/IX52Lxux7VOfCqJMZrXV9StZRLK 8bRGI+WsjbnQ
B42BUthvmyRjggcU35f1/X5eYl5mxZ3cGoWMF5bPvgnjWWNvVWGQfyNVtbvL qw0ie5s4DNOu
0KojaTaCwBbYvzNtBLbRycYHWrsSNHCiNI8rKoBkcDcx9TgAZ+gAqK+tWvLR oUup7VyQVmgI
DqQc8bgQenQgg0peQR8zl5fHFnpGnwvqV/ZX080jqhs2jthhAu4MJ5QFdSwB XcW9uuLcvjjS
YdQ0+1O4rfxxyW8wmhG4P9392ZPMOemQhHvwcS/8IqqstxFq+ox6hvZnvl8n zJAwUEMpj8vG
ETogI2j1OcrUPDmtNqk0lp5c9pJLDO6y6gsJmlQJ87qtqxB+QDAfbxnA7H9f 1/W4zWi8Urc2
drPbaPqU0l2vmQW4ESyPEApMnzSAKuWA+Yg56AjmodE8SS3MsVteWd4rTXNx FFdOkYjZkd8J
w27IVeu3Bx1Jq5L4ej+y2EVpqF5ZS2MXkRXEHllymACrB0ZTnap6dRxipoNE t7dbQCWZza3E
lwpYjLM+/dnA6fvD0x2p9RdDTrkPEHie60vW5rSG+0xDFbxzRWM8bNcXrMzg pERIMH5QB8jc
muvrFvINWttYlvNMsbK5E8Ecchub54cFS5ACrC/97rn8BjldRkX/AAlUbRF4 tL1GQtcNbQIq
xgzyKXDBcuMAbGJLbRjGCTxVWfxvZWyLdTxTQWn2d5CZRGP3iyLGYy3mYVlY 4ORt5zvwDV4a
AsulW0LTz2d1FM10sttIrtFK5YuFLJhl+dl+ZOR2zVEeEzJOtvI/l2VvCywz xzZuJJnkSVpW
+QKrB0zgbgc9AOKF/X3f5hp/Xr/X4j7LxtZapaJJptnc31w0joba2lgdl2hS SXEnl4+dOjn7
wHUHF7SNXutQ1HVLafT5oI7ScRxysUw42K2OHJz8xPQDBHfNMk8PzSJC7a9q f2yEsFvAtuJN
jYyhHlbCuVB+7nI61cs9LWyv7u6S6uGF0VaSF9pTeFC7x8uQSFGRnHHAFC3F 0L9ctc6zrIs7
3Wbf7Cum2byhraWJzLKkTEOwkDYU/KxC7D0GSM8dTXFXug69Le3SW9vbjS55 mkezGrGOObJy
Sw+yl13cFlV8E565OTqPQ0X8a2MGZbqzvray3zRreSonls0QcsAAxfpG5BKg HHXOBVex+IGm
akNlla3NzcmURLb28tvMxJVmB3JKUAIRurAjHOMg0th4Qaa0K65dy3Cs88gs o5FMEDSl8lGE
aSEhXYZY9yQBxjUtdCeGW3kutXv75raTzIvtAhG07GTHyRrkYY9cnIHvkB+R ly+Jp75XeyuL
TSoLeES3Vxqke8RkuyeWQsigEFGy24jpjOcjW0PUpdSS7MrW7iGVUV7cko4M SPkHPIyxwfTF
V38Lwg+ZZ6he2M58wPNB5ZaRXdn2sHRlIDMcHGRk88nLtM8OLpF15lpql8tt 8u6zYRGNisax
gk+Xv6KDw3UfhTXW/wDX9f13EzbrkPEHia70zWp7S3vtLjaK2jmhsriNmnvX JcbIyJBgnaAM
K3LdO1dfXOa3pV/dXdybXT7O6iuoI43afUHt2jZGYqUCwuQQWBDbs5AwBjJQ 0X5ddtoY7h3j
m/0e5jtXAA+++zBHPT5x+tQ6R4ki1eaKNbC9thPb/aYHuFQCVOMkBWJGNy8M B14zVK18LTzx
JLqWoXccryRz3FvDPHJFJLGVCuW8lGyQi5ACr1471r2mj29k9i0byk2dqbWP cRyh28njr8g/
WmvP+tP8/wABGhXJN4g1FvE9zZC4SK1guUi2DRbmfcpRGOZ0by0PzHqOOprr arW1jFbS3ciF
mN1L5sgYjAO1VwPbCil1H0MMeNbPYrvp+ooswR7XdGmbpGdUDIA2QMumQwU4 YcdaWTxekVyb
c6LqjTBvK2qsR/e+WJDHnzMZCknOdvBGc4y+38H2cLxF729nW32LapKyEW6K 6vsUhQSCUQEs
WOFHNXjodsbw3XmTbzcm5xkY3GLysdOm3n6/lR0/r5f8HzDS4l5q4Xw8NTsg HaeNDbLICNzy
YCAjr1YZqlp/iY3EenwSWU8t9cCQTLbqoSJo3EchJZhgBjnHJI6ZNW5vDmn3 WlWOmXUZubOz
2YhmCssu1dq7wRg+v1ApmmeGNO0e/e5sEMCEOEtowqwx79m7aoAxkxg/Ut60 /tPsLoZll4wl
cM1/p9xbkGdY4wiMZykwjUIRIcElguGABJzkAcsuvGa6VdXMurW89nF5cCw2 k8luj72Mufn8
zyxlUzy/bHU4N5vCNo0kzG9vcMZGiXcn+js8iyEoduch1DDcW9OnFOfwssre fLq+ovfAoUvP
3KyIV34wBGEPEjAgqRjHcZpdB6akN74oWbwjHrWkuhEsscas0JuduZRG3yRN 85HP3WOccE1H
b+JLuO0VZYbnU72YuY47bTHsWVEC5ZluZBwCw5zzngHBrWutHa80hLCbUrxp EdJBdgRCXcrh
gcbNnUD+Gqr+G5ZTFJLr2qPcx7lFxiBXMbY3RkCILtJUHONw7EUn1sC6XMnT /Fl89npGbSW9
kuJUhuGRI0K5thKTzIAeTnIA4BGM4zeHjWz2K76fqKLMEe13Rpm6RnVAyANk DLpkMFOGHHWp
ofCdpbWsENvd3kTQTJMkoZC2ViEWDlSCCgwcjuSMcYbb+D7OF4i97ezrb7Ft UlZCLdFdX2KQ
oJBKICWLHCjmqdnLy/r+vv8AIXQmtPEsd5rL6ZHp94JoQn2liYiLdmTeFcBy 3TjcAVJ4DHmt
usiXw/DPr0OrT3dzK1uxeCBxGUhYrtJVtm8ZHUbse3StejoD3OU1nXtStvEL 6fazpDEkEcmf
7Gub0sWZwcmJwEHyjr71Fq3i2eGaJrW1uktI5Z0lvGijMUpjikJVVLhzhl9F B2n5sddi90KW
51N7621nULCSSJInW3WBlYKWIP7yNjn5j0NVLjwda3JkWXUdQNszyutuGj2R tIrByPk3c72O
CSATwAOKSGxi+Kp476/tptIvJDFdi2tRB5WZz5YcjmTggbmy20YwOvFW9O8T W+q3iW1rZXhb
yw8zMqBYDl1Kud33g0bKQu7nHbmkufDEU93NdRajf20kky3CeS0eIpQmwuu5 D1T5SGyvcAHm
rGk6Fa6OztbvM7yRqkjSEEuQzsXOAPmZpGJ7egFC21EzGufFd1Z6tqdlJFAz bxDpoAIMsoRC
ytzz/rA3GPlDehNR2nxE0szWFldugvJ44fNKSxKqSSIrBQjP5hzuHKqwGeTw cXrix1WHUbuS
z0nTLqKWbz0lur9kdHMYjJVRA23gEfePBPrgN0jw1PZwQN9uurFtqLcWlvNH PDKUUICWeENk
oq527en4lK9vu/r+vIeg628Y2twbYvp2oW6XSRvbvMiASq7omQA5IwXXO4A8 8Zratb2O7mu4
o1cNay+S+4DBO1W49sMKzJ/C1nPaWcAuLqM2dusEEiMu5drIytypBYGNeox1 yDV3S9LXS0uB
9quLqS4l82WW4K7mbaq/wqoHCjgCq0/r8PwEXznBx17ZrlovFFwr2TXKQJEb VmvCobKTAOcL
6KPKl689K6muHl0DXJbW8t/7K05Eu7n7S+3WZAQc5Kj/AEXhT82R33tzzUsa sX7bxXOmLW40
66vNRCbpIbOJEC7UiZ+ZJAOsoxkg9sHGSl54t+0Lb/2Xa3jwtcWqy3myMRRi RkOwhmDElGH3
VON3UEHGhp2ilbuTU7tBDfTiQSxQz+bEu7YPlYopPESnkcEnrxVePwfawmJI 7+/W2RoXa2DJ
skeIKFZvk3ZwiggEA46Z5quz9BC2/i+0nKbrG+hSYI9u8qJieNnVPMUBiQoL oTuCkBgcdava
frtrqUyRQJKGYSn51AwEKjJ5/iDqw9j26VRh8IWkUM0TX19MhtmtbfzHQm0j JBxGQoPULy+4
/KOeudGx0a0066ee33ruiji2EjaoQYBHHUgKD/uigb8jQrlNS8YjT11uNre4 a4smKwGOwnki
P7tWG+RVKjljnkYGOnWurrmdS03V3/ta1tNPsZrTUDl5JtSeKTmNUOFEDAfd 9T6+wXUChqXx
B04nUdPspwt9DFMIpPNhbMsakkeXvMgxtblkCnHU5Gdi18UQXN9BbtYX0UU8 0lvDdSKnlySp
u3KMMWH3GIJUA461HH4ZaS1nhl1G9gt7tHM9hE8ckKPICX2O0XmY3EkcgewH FJpXhl7S4Se9
1C4uRFczT29sdnkws7PhhhA5O1yPmYj5j7GmugmdFRRRSAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACvIfEH/Htof8A2DU/9GSV69XkPiD/AI9tD/7Bqf8AoySriB3v hpyly+NvOm2H
VQf+WbetdH57+if98L/hXNeHf+Plv+wbY/8Aotq6Bd5Z8ptRcbW3D5s5zx1G OOvrWctykS+e
/on/AHwv+FHnv6J/3wv+FQSypDC8shIRFLMQCeBz0HWqdvrNjc7vKkkwoLMW hdQABkkkgChR
bV0iXKKdmzT89/RP++F/wo89/RP++F/wqnHc7pFWSGWLfzGZEK7uSMcjg/KT jrjB9cWKiE4z
V4stprck89/RP++F/wAKPPf0T/vhf8KjpEWWR8II8F9g3MRzt3eh7VQiXz39 E/74X/Cjz39E
/wC+F/wpHtrhGQEQ5dto/eHrgn+77VFG2+NXxjcAcUATee/on/fC/wCFHnv6 J/3wv+FRokks
wjjCZKlvmbA4x7H1puXWQxyxsjDOD2bHcH8vzoAm89/RP++F/wAKPPf0T/vh f8KjpPnMiKqZ
U53NuA24GRx3yeOKAJfPf0T/AL4X/Cjz39E/74X/AApsah5UU9GYA1ee0tIi BJMUJ6BnAzQB
T89/RP8Avhf8KPPf0T/vhf8ACrslhEkTuGckKSORWdQBJ57+if8AfC/4Uee/ on/fC/4VEN5k
I2fuwud+4dcgYx19T+FLQBJ57+if98L/AIUee/on/fC/4Vg/8JVpB1KO0j1C zkRoZJXmW4Ur
Ht28EjgZBY9f4TWra3Au7OG5VJIxLGsgSQYZcjOCOxoEmmWfPf0T/vhf8KPP f0T/AL4X/Co6
KBknnv6J/wB8L/hR57+if98L/hVDUdRh0y2E0wdtzBERBlmY9h27E8+lZkvi C6tJlF7pZjjZ
Q4Mc25ypHB2lQPyP61nKrCLtJkSqRi7M6Lz39E/74X/Cjz39E/74X/CoIZo7 iCOaJg0cihlY
dweQafWhZJ57+if98L/hR57+if8AfC/4VE7rGjO7BVUZJJ4ArEfxBKLRL5bA mxdiolMoDZHt
jA/E1E6kYfEyZTjHc6Dz39E/74X/AAo89/RP++F/wqtb3Ed1bxzwtujcZU1L Vlbknnv6J/3w
v+FHnv6J/wB8L/hUdIxIUkDcQOB60AS+e/on/fC/4Uee/on/AHwv+FRDdtXe oVioLKCDtJHI
yODjpSkgdTjnFAEnnv6J/wB8L/hR57+if98L/hWPZ6u94s+2zl3xTyx7Uy2V Qkbs44ztIA7k
Yz1I0o5FlQOhyDx0wQehBHYj0qeZczhfVAtVzdCbz39E/wC+F/wo89/RP++F /wAKpT31vbSe
XIzbtu4hY2bA554Hsaig1Jbm3inhtrhlaNZHXyiWjDbcAgZy3zA4HbJ9MzKr CO7KUJPoaXnv
6J/3wv8AhR57+if98L/hUSOrorowZWGQwOQRVO/1W309kjcSSTycpDEu52Hc 49Pc1d1a5DaW
rNHz39E/74X/AAo89/RP++F/wrMg1JrhCy2N2u3BdWjyVB24+7nJ+YHHXAJ9 M3kdXRXRgysM
hgcgipjUjJtJ7Dtpcl89/RP++F/wo89/RP8Avhf8KjoqwJPPf0T/AL4X/Cjz 39E/74X/AAqJ
N5Vi6bPmIX5gdw4546dT19KSSRYk3ucDIHTJJJwAB3JPAHelfqFibz39E/74 X/Cjz39E/wC+
F/wrI1HVPssDlCInSMuftETL06DB2nn5sH/ZPXBq9bStPawzNG0TSIrGNuqk jOD7iqSvHmWw
utiz57+if98L/hR57+if98L/AIVAGPnMueAoP6n/AApl1dQ2cDTTyKiKCck4 zgZwPU8Uh2LX
nv6J/wB8L/hR57+if98L/hXL6f4ysr6RgUKxgcMhMhz6EAZzjPAz0Nb9vcw3 cImgcOhyMjsR
wQR2PtTknF8r3FdXsWfPf0T/AL4X/Cjz39E/74X/AAqtLcQQFfOmjj3fd3sB n6Zqmmt2L3Rg
EoGCQHJAUkde+fXnp+YpLXYb03NXz39E/wC+F/wo89/RP++F/wAKjooAk89/ RP8Avhf8KPPf
0T/vhf8ACqFze+TIkUaq8rMFwzEAE/QE5xk9OgJOACaltZ/tMAk2hTuZSAc4 KkqefqKiNSMp
OKeqKcWldlrz39E/74X/AAo89/RP++F/wqOirJJPPf0T/vhf8KPPf0T/AL4X /Col3lnym1Fx
tbcPmznPHUY46+tLQBJ57+if98L/AIUee/on/fC/4VgS6lqPMkEMDQtI6o5I wQuec7vQH06V
JpmpXV1etBOsAAjLgxNu7gdQSKANvz39E/74X/Cjz39E/wC+F/wqJmVFLMQq gZJJwAKwm1PV
RHE/kW4V035chRjI77vdeuOtAHRee/on/fC/4Uee/on/AHwv+FZGk39xevcJ OsIMe3HlHI5z
3yR2q7dz/ZrOabKgohI3dCew/OgC157+if8AfC/4Uee/on/fC/4Vz02patC5 V4LZMBSS7Beu
f9v2P5Ve0q8lvbaR5hGHSQp+76cAe59aANPz39E/74X/AAo89/RP++F/wqJi QpIG4gcD1oG7
au9QrFQWUEHaSORkcHHSgCXz39E/74X/AAo89/RP++F/wqMAvJHGGClzjcRn HBPT8KarM27E
cjbWZNyxMQcEj09qVwJvPf0T/vhf8KPPf0T/AL4X/ColYMoYHIIyKWmBJ57+ if8AfC/4Uee/
on/fC/4VHUcCXUspDBEi8pZBJwc7scY3ZHfk+lAFjz39E/74X/Cjz39E/wC+ F/wqOSN4ZEVn
VgwbouCCMe59aKAJPPf0T/vhf8KPPf0T/vhf8KjqBryBLkQM+JCM4x/n3/I0 AW/Pf0T/AL4X
/Cjz39E/74X/AAqIEksCrKVOCGHsD/WloAk89/RP++F/wo89/RP++F/wqInA oU5ByCpBIIPY
g4oAl89/RP8Avhf8KPPf0T/vhf8ACo6KAJPPf0T/AL4X/Cjz39E/74X/AAqO kY4AwCxJAAHc
k4oAl89/RP8Avhf8KPPf0T/vhf8ACogciloAk89/RP8Avhf8KPPf0T/vhf8A Co6ZIzrGxjj8
xx0TcFz+J4FAE/nv6J/3wv8AhR57+if98L/hTGG1iMg4OMjvVG/vpLbEcFtN cTsMhY4y20Z6
nHb/APVxmlcDR89/RP8Avhf8KPPf0T/vhf8ACsi21O4a4EV3YXMKuQElaFlX Poc9/wDPatOn
1sHS5J57+if98L/hR57+if8AfC/4VHRQBJ57+if98L/hR57+if8AfC/4VHRQ BJ57+if98L/h
R57+if8AfC/4VHRQBJ57+if98L/hR57+if8AfC/4VHRQBJ57+if98L/hR57+ if8AfC/4VHRQ
BJ57+if98L/hR57+if8AfC/4VHRQBJ57+if98L/hR57+if8AfC/4VHRQBJ57 +if98L/hR57+
if8AfC/4VHRQBJ57+if98L/hR57+if8AfC/4VHRQBJ57+if98L/hR57+if8A fC/4VHRQBJ57
+if98L/hR57+if8AfC/4VHRQBJ57+if98L/hR57+if8AfC/4VHRQBJ57+if9 8L/hR57+if8A
fC/4VHRQBJ57+if98L/hR57+if8AfC/4VHRQBJ57+if98L/hSrJI7bVVSfQR j/CmxxtI+0fi
ewpXkwPLjyE7/wC19aAJS4Xh5Ez6JED/AIUnmp/f/wDIK/41XooAsean9/8A 8gr/AI0ean9/
/wAgr/jWFb+ItNutphkuCrDcHa1lVcYzksVwBjvV2O63yKrwyxb+YzIhXdyR jkcH5ScdcYPr
hTfJJRno2KNpK8dTQ81P7/8A5BX/ABo81P7/AP5BX/GotNs7a+e8a6t4p/Lm CIJVDBRsU8A+
7GsW113Qrq9jhHh1UilFvskMcBOZWIXKhsgcDpk9cgYGVKcY7sqMZS2Rv+an 9/8A8gr/AI0e
an9//wAgr/jVK7bS7XxLp2j/ANi2bfbI5H83y1GzYM4xt5z9a1v7G0v/AKBt n/34X/CqasQn
crean9//AMgr/jR5qf3/APyCv+NWf7G0v/oG2f8A34X/AAo/sbS/+gbZ/wDf hf8ACldDK3mp
/f8A/IK/40ean9//AMgr/jSanplhbaXd3FvZW8M0ULujxxBSCASOQKgpgWPN T+//AOQV/wAa
PNT+/wD+QV/xqvRQMsean9//AMgr/jR5qf3/APyCv+NV6KALHmp/f/8AIK/4 0ean9/8A8gr/
AI1XooAsean9/wD8gr/jR5qf3/8AyCv+NV6KALHmp/f/APIK/wCNeN+IP+Pb Q/8AsGp/6Mkr
1yvI/EH/AB7aH/2DU/8ARklXTEzu/Dv/AB8t/wBg2x/9FtW9GmJJ28rbuKfv C+d+AeAM8Y+g
zn2rB8O/8fLf9g2x/wDRbV0Cois7BfnfG5sk9M44zgdT0qZbjRW1PH9k3m4A jyHyD3+U1p22
i6bblZINPtYmx1SFVP6CqcsSTwvFIu5HUqw9QeDTkDJAYRLMUIx80rMfzJzU 3kr8onFStcgk
sLOw1OH7NbrH5kUuCM4ChlOAOw3Ox49uwFZfibw6/iK1gih1jU9LlilDedYX DRlkyNykA4OQ
OCfunB6ZB1Y7SOOcTb53kClQZZ3kwCQTjcTjoPyqes6VNU42RcpcwyGJbeCO FC5WNQgMjl2I
AxyzEkn3JJNJvKJIwfYyTAqcZ5KhcfrUlRPBvJ/eOAWDYGOoxjt7CtSR8VxJ Jcqs0oLJ84UB
fTHUMfWmwf8AHvF/uD+VMFtiUyCWTeeM8e3t7CpkUIiqOijApAJEqmPcMFjv Vtzf7XGAQR29
Ka0SRwSE7RtR2XYQDuIH90D0qF9PgkkZznLHJ6U0aZb5B+bg57f4UCLlMKbr mJvK3bQ3zl8B
PlIzjPOenfrmn0mxDIkjLlkzt5PGRg8Z54PehjJIf9fHj+8P51z0Gk6vZXc/ 2m0S6nkZibt4
ROHGflwCQUwOMdK30Yo6sOqnIq3/AGjN/dT8j/jVJtEyjcoWVjq0G+WSeNLY hs22zbtGO2CQ
PpT6tPfyujKVTDDB4P8AjVWkNKwxU/0ln8r/AJZY80v0+YfKFz175x2p9IEQ SGTbmQrs3ZPA
yD0zjsOaWkM4m/lFh4hn/tNxeaWIYo5J5IuBMS2wTbcIdoPHA/1iZB4ajw8y Ta7cXWnWIktQ
UWSaK4KhWwV2gD5ZVVdpAY5QHgdFrrryyivo44p8mJJVlKcYcqdyg+wYA8Y6 DtkGcAKoVQAA
MADtStrcy9n717mX4i0Z9e0aayh1K806c/NFdWczRvG46E7SNy+qnr7HBFvT bBdM02CyS4ub
gQrt866mMssh7lmPJJP4DoABgVaoqjU4v4gxXfkWE9uQERnRz7sBj/0E/wCT Vrxpr9m2lW2l
QRRXF8saM0hJxb/KO47+3T1rp5oYriJopo0kjYYZHUEH6g1mQ+GdHhmEq2YZ gcgSSM6j/gLE
j9KwqUnJu3U5qlKbbcXuHhqOWLw9aicYdg0gHorMWX9CKrWvhc2viu51o6zq 0sMq/u9PkvJG
gic53MFJwQRjCnhTnH8O3forZKysbxjyxSIL22F5YXFqWKCaJo9w6jIIz+tc Y82raV4XTw+s
EsYeVhcXbqWXazcBTgjn8+wGa7qqmp6dBq2nTWNzu8mUANtxngg9/pWdSHMt AdKM5LmbS627
GB4c1q2t7PT7B3U+dEZEkyScll+U8Y6yAZUsOOvIzq+ItGfXtGmsodSvNOnP zRXVnM0bxuOh
O0jcvqp6+xwRmWXgLR7G+hu4jOZYpBINxTlh0JwoNdRRSU0rSOquqCaVDYq6 bYLpmmwWSXFz
cCFdvnXUxllkPcsx5JJ/AdAAMCrDjMbDaWyDwDjP406kZQylT0IwecVqc4Iu yKNfLEe2NRsD
btvA4zk5x65rOlnNpdajKJZvNSCNoSMP5bMWX5UJAJ+UcdTkgdcVogKqqiKF VVCqAScADA68
1RvNJjvLpLkTzwTKu3MRXBHOOGBGRluRz8xoST0YMy4tMWHSpYGsbq4vHklm 89jEgLyZ3DAk
OFIOCMk9wQcY2rCRJbGFo0ZE27VDBRwOAfl4wcZGOMYxVZdHG4ede3U8f8UU mza3scKCR7Z5
6HI4rSqpxpqTlHd7smHMo8r2Rz2oG9/ti9WK9t4l+yxlVeEk4y/B+bnkE9uo 9Mmjp0LzW+jR
Xk1vOZY1jwsWDsA37G55GVB+vsSD09xYWd4ytc2kE7KMAyxhiB+IqKz0jTtP Ef2WygiZF2K6
oN+MY5bqfqTzXHLD80rvY6lWSjYu1zJupbPxZqqPPFbz3NkBYTTcKGAxjPbn P5+9dNVW+060
1KIRXcCyqDlc8FT7Ecj8K6JxujjqRclocmjahLqOnWupXVrqFzN8siREMY4w 4ch2Gdw4zjPG
MdCQezmiW4gkhcuFkUoTG5RgCMcMpBB9wQRVWw0mw0zd9jtljZvvNksxHpk5 OPartTTpqF31
Y6alGNpO5h+GfDr+HbWeKbWNT1SWWUt51/cNIVTJ2qATgYB5I+8cnpgDcoor QsZEmxH/AHXl
7pWPL7i/A+bqcDtjjp71S1O6js5tPlkOF+0EdM5PlScAdz7VfREjVgi43MXY 5JyTgdz7DgU2
aGK4iaKeJJY26o6hgfwNZVYOcHFFwkoyuzNX7W1xJdI9tA0gwEeAuyL6ZDAe 5468ZIApdES4
jhkVpUltcj7ORHs47gDJ+T0/HHy7am/sXSv+gZZ/9+F/wq9WVCjVpv35XXYu pOEvhRGP+Ph/
9xf5mqE9zBHqV1FcRmUPaxxrGOrB2k3KPrtGe2FyeBWiFIlZ+xUD8s/41Vut LtLydZ5Y3Eyr
sEkcjRttznBKkEjPY1eIpznC0HZk05RjL3tjjrrwi8cQa0litEjLM2+7LAKQ O4jU8Y6kmuj8
L6dLpukbJ2cyyyNKwbPHQDrz0UHnnnt0q5HpFpFKsgE7lTkCS5kdc9jhmI46 /Wr1RRp1VJzr
SuyakaLlzQjr/XmY8s8bvqlsF3XMr+THzyB5SHk9lBcn/gXcnBt6hqt8+nXE clvaRrJGY932
l2OWGBgeXycngDr0pJtIsp7l7hkkSZwA7RTPHvx0ztIyfc06DS7W3mWVRKzr 90yzvJtPTIDE
4OCRnrgn1rL2OJU3yySTf9dDbnpOKutSzCzvBG8kflyMoLJnO045Ge9Q3Ed5 dZhskDbQTK2/
aQP7qnpuP1GPbINWakjnkiUqjbQTk8V1zjJq0WYpq9zmNMuLia/msYXdbcgv MXyWRsgYyeQT
zwf7p9DnoY40ijCIoVR0ApkFtDbBxDGE8x2kfHVmJySalqadGMHzW1ZU5uSt 0MDQfC50PUr+
7bWdWvluG/cQXl5JKlsnBKqGJyc5+Y84wP7xbfoorYzGRpiSdvK27in7wvnf gHgDPGPoM59q
hvrpbSBZGmSIFsbnjLjoeMAirCois7BfnfG5sk9M44zgdT0paSA5mfECRWlo 8lzG0JcoiElC
UKg+wO7OO340vh61uIb+RpYJY1MRGXQgZyK3LKwgsIjHCDycszck/WrNMDP1 W4jig8qW5SFZ
lZTuiZyRjHGDx1rIvw2+aythLcRxptXYpYxksp2k+g28fl2rpJolmgkiYkK6 lTjrgjFMtbWK
zgWGFcKOp7k+poAyPDlvNB9p86GSPO3G9SM9fWreoywyTR2U1wirKVJjMbEt 8394HAzjFaVQ
3dsl5bPBIWCPjJXrwc/0oA5m9M10JYoRNdIjoqTKhOQobqR1Pzde+M1reHoZ YbCRZY3jYyk4
dSDjArThhjgiWKJQqKMACn0ANcZjYbS2QeAcZ/GlRdkUa+WI9sajYG3beBxn Jzj1zQyhlKno
Rg84oAVVVEUKqqFUAk4AGB15pARSBlmSRUkkZcnamTgYOTjv1/ljmrljbvAG Z94MjhjEWLBO
SeOoycnOMDp9TUnt0uUKSZ2kYI45GQe/uBTo0eJERJWCoAF+VeAOnalbW4CQ f8e8X+4P5Uoj
xKX3sR/dzwKcihEVR0UYFLVAI2dp243Y4z0zUP2nyooRDHFFOZWAkeTAzg5L HHIO0cfTGMAi
eoxEofdk8EkDsCf/ANZqWrgTXE0cs8YjkV8B+jZxyvuajkTehAYqexBp1FMB FXaoGScdycmo
HtYvtSXRj3SJg5BOeMYPHp6e5/GxRQAxrhJpHb7IkhyMvsU7uB6n0xSxghOR jknA7DPApQoX
OABk5OB1NLQlYASQQy+awyoGAf7vv/np+JpPOgkLN9hVssctsTk55PWlpFUK MKAB6AUWASMF
Y1DHLAAE+ppEj2Mx3s2egJzin0UwGyAtGwU4YggH0NL9ohjKt/Z6KQwwQicH PBpaRlDDDAEe
hFJq4CvL9ol80KFBGCf73v8A56/gKZJH5gADspB6qafRRYAAwMVFcp5lu6eS ZsjHlh9m723Z
GPzqWmSRJNG0ci7kbgjcRn8RzQBLJ/rX6H5j93p+FYOo61d6RriLbaZJdzXN v5VsUPyiUsTi
T+6oA3Z9mrdZtzFsAZOcCqd3ptpfMrXMO9lGAdxH8jVwaTvJXInFyjZOxQEV 3Y28UV7PLc3E
19HLLO2AruykEIAchQFUAEDp3zW1WfDomnQTJLHbAOhyp3McH8TWhUyblNyf UqMVGKigoooo
GFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFHU09Ip
HGVQkeuOPzp25IvuNuf+9jgfSgBXxChiByx++fT2qGiigAooooAwdE0uzKaR LbaDZrK1kZPM
kVE3n938wKhjnnuB1q5a2S2Wt3Uf2eKEiCNkWN94RWeQkAlRgZBOP6YAWPRL SERiKS+QRJsj
C3042LxwPn4HA49hVi3sYbWWSVGneSRVVnmneU4GcDLk4HzH86hx5mnLWwR9 29upFfXp0/wz
r1wsCT4mCGN03qQyRqcr3ABJIPHFcDph0q4uXNzYIIYfKmkc20RZwsijyyfl GGB+pwc7u3pd
tcfYvtKPaPcR3D7yEK8fKqkEMRx8v61zXiDw3YavHClnp82nRxks0UUEPluT /EVWRfm7Zz3p
+yjOonJ6Gf7xTUoysjoNP0watrVr4lOptcwJG4tIRCE8sNwQxz82OR0FZ3in UdHg8R6fcRfZ
7jWNOE0s0dsI3u4ofs8h5B5VSSuN2FJI9a0tGnh0TSLbTrfT75o4F2hmMWSS ck/f9Sav/wBu
f9Q28/OL/wCLqp6vT5FqyOK0HxPqrQ3tzca1bX9nYPBcSzQXMVyrQPvWQGSO CNfk2h8KM/KQ
WIOBH4j8UazpkVrjU1tb1bc3r29zPDCJlZ2ZYkQwu8pRRtbaycYO7JyO5/tz /qG3n5xf/F0f
25/1Dbz84v8A4ujrcOn9f1/XkT6wc6Dfn1tZP/QTWdT73UmvbGe1WyuIzNG0 e+QphcjGeGJ/
SmUAgooooGFFFFABRRRQAUUUUAFeR+IP+PbQ/wDsGp/6Mkr1yvI/EH/Htof/ AGDU/wDRklXT
Ezu/Dv8Ax8t/2DbH/wBFtW/BHcXrH7N5aRKcGaQEgnuFAxn0JyPxwawPDv8A x8t/2DbH/wBF
tXVaUwXSLPAAzCrHHckZJ+pPNTLcaGf2Xef8/wBB/wCAx/8Ai6P7LvP+f6D/ AMBj/wDF1x97
Lq0OiaGY9QhjhNvHgI/kHGYuCTMu75dw49e2QR2elSS/2PZee++b7PH5jbt2 W2jJzk5575NY
qpebhbYtwtBSvuM/su8/5/oP/AY//F0f2Xef8/0H/gMf/i6xtK8X3NwIW1PT Y7YXFl9ugFlM
925jG3IZBGrBvnXAUNnn05vHxfpItI7gSXbb5GjEK2M7ThlGTmEJ5gwCDkrj keozo7ogt/2X
ef8AP9B/4DH/AOLo/su8/wCf6D/wGP8A8XWdpviu3ubaQ3HmG4jMztFb20sj LGkrIpKqCQx2
8DqSGwODiR/GWjpbRzGW6JkdkEC2M7TgqAWzCE8wAAqSSoHzL6jI9ALv9l3n /P8AQf8AgMf/
AIuj+y7z/n+g/wDAY/8AxdVYvFukTT28MVxK/nhCkgtpTGC4BRWk27UYgrhW IPzDjkVma741
bSdeOmKdEiIhjlDanq32QvuZhhF8t92NvXPcUa7Abv8AZd5/z/Qf+Ax/+Lo/ su8/5/oP/AY/
/F1Vm8WaRbRTPPdFDA8iTL5UhMZRdzkjbkKAQd2MHcuD8wzTk8a2D3ltHBN5 cYlYXf2uCSBo
o/KkcOA4X5SYz82CDg+lAGt/Zd5/z/Qf+Ax/+Lo/su8/5/oP/AY//F1QXxro jQiTz7lS0giW
J7KdZWYqXGIym8gqrEEDBwcdK3RJkZo1AoPpd8EYpeWxfHyhrdgCfc7zis6V NUtQTdCJUHWW
OIunTOfvZA9yAKt2zao11dQpdRyzhyxjnUBI4mZvLdCoBbABBVjklfvKMFpt ImmktXmkupLi
CV99tJKqhzEVXBIUAcncRxnBGcHICuBRC3hGRcW5H/XE/wDxdLsvf+fiD/vw f/i6sXNoLUma
zjHlf8tIEH/jyj19R3+vVqOsiK6MGVhkEd6oCHZe/wDPxB/34P8A8XUUEs1y he3vrSVAcFo4
ywz6cPVi5t1u7Sa2csElRo2KnBAIxx71yFlfR+HhNvMtzczSPGS6tHGEiYrw cHJ5zx9OMVMp
cuvQznPld3sdZsvf+fiD/vwf/i6Nl7/z8Qf9+D/8XT7W4S7tIbmMMElRZFDD BwRkZrl1+IGk
TWVlJbXlhNcTxGSW3S8DNbgRM53BQWwCu0/L36dqpK5dzpdl7/z8Qf8Afg// ABdGy9/5+IP+
/B/+LrPl8UaRbyzpNcyIIFdnlNvJ5XyAlwsm3azDByoJI2njg06XxHp0EME0 v2xYZs7ZDYz7
FAOMu2zCD3bAI56c0DL2y9/5+IP+/B/+Lo2Xv/PxB/34P/xdUD4n0ryp5RNM 6wy+S3l2srFp
NxUogC/OwKnIXJGMniqdj4usrjULi1nM0R+0rDAWtJlA3RoyiQlcIxLEANtJ 44oWoPQ1pf7Q
jwyyQOn8eIW3D6Ddz/nrUii7dQy3NuykZBEJII/77qO21ayu5II4Ji7zo8iD Yw+VGCtnI+XB
IGDg/kalsv8Aj2I7LJIoHoA5AH5UAGy9/wCfiD/vwf8A4ujZe/8APxB/34P/ AMXVBdG2NJ/o
+jzb5Xk33GneZJ8zFsFt4zjOOnQVb0+x+wrccW6+dL5my3h8qNflVcBcn+7n r1NLUCTZe/8A
PxB/34P/AMXSFb1eRJbv/s+WyZ/HJx+VV10W31jXrrz22+Vaw4/cxSdWl/56 I2OnbFDaLb6P
r1r5DbvNtZs/uYo+jRf880XPXvmi4FyGdZUJwUZeHVuqn3pI/PuhviaOKE/d d1LF/cLkce+f
wwc1VujsOolflP2UNxxz84z9eB+VLf6pBptuXfcka8DYvCqOvsOBxmqjFyaj HcC79muf+fyH
/wABj/8AF0fZrn/n8h/8Bj/8XXkb+JNdg1T7da3ziLOfs010JEK+hycZ9xj2 r06PV45NMF/t
k8sxebtVSzYxnAAGW9sde1aV6EqOsgVnsXvs1z/z+Q/+Ax/+Lo+zXP8Az+Q/ +Ax/+Lrj9F8d
Qz2EM+qTmOW5CyrDHp86fZ0bGPMY5G3Jx5h2qcHHQ1tweJdOuNSbT4p3adSy 58pxGzL95VkI
2sw7gEkYPoax1A1fs1z/AM/kP/gMf/i6jmt78IPIuLR2zyJImUY+oY1FdTTP aTLbSBJyjCNm
6K2OCfxpmZf7N+1/bpfsPTzdi/afM3bPKxt8vO/jd07Y/jpXAFkvQ6pM0cLt 93fASCfQMHIz
weM5qbZe/wDPxB/34P8A8XUULu1jFFeFJpPLUS5UFWYAZOMevPSiKb7Owjdi YScIxOSh9CfT
0P4H1LuBLsvf+fiD/vwf/i6Nl7/z8Qf9+D/8XViimBX2Xv8Az8Qf9+D/APF0 bL3/AJ+IP+/B
/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+/B/+LqxRQBX2Xv8Az8Qf9+D/ APF0bL3/AJ+I
P+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+/B/+LqxRQBX2Xv8Az8Qf 9+D/APF0bL3/
AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+/B/+LqxRQBX2Xv8A z8Qf9+D/APF0
bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+/B/+LqxRQBX2 Xv8Az8Qf9+D/
APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+/B/+LqxR QBX2Xv8Az8Qf
9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+/B/+ LqxRQBX2Xv8A
z8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5+IP+ /B/+LqxRQBX2
Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdGy9/5 +IP+/B/+LqxR
QBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg//ABdG y9/5+IP+/B/+
LqxRQBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8Afg// ABdGy9/5+IP+
/B/+LqxRQBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8Qf8A fg//ABdGy9/5
+IP+/B/+LqxRQBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l7/z8 Qf8Afg//ABdG
y9/5+IP+/B/+LqxRQBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUUAV9l 7/z8Qf8Afg//
ABdGy9/5+IP+/B/+LqxRQBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/B/wDi6sUU AV9l7/z8Qf8A
fg//ABdGy9/5+IP+/B/+LqxRQBX2Xv8Az8Qf9+D/APF0bL3/AJ+IP+/J/wDi 6sUUAV9l7/z8
Qf8Aflv/AIujbe/8/EH/AH5b/wCLqxRQBX23v/PxB/35b/4ujbff8/MH/flv /i6sUUAQYvv+
fmD/AL8t/wDF0Yvv+fmH/vy3/wAXU9FAEGL7/n5h/wC/Lf8AxdH+n/8APzD/ AN+W/wDi6nqC
9tvtlhcWu/Z50TR7sZxkEZx+NAB/p/8Az9Q/9+W/+Lo/0/8A5+of+/Lf/F1R /sr/AKcfD/8A
4Kf/ALZV6ytvsdhb2u/f5MSx7sYzgAZx+FIA/wBP/wCfqH/vy3/xdBmvofmd lmQfeEYKsPoM
nP6fjVTS/DFnqNrLdSvh5Lq4yPstu/SZx1eMsenc07TrKPTrrU7WI5SO6GDs ROsMZ6IAo69h
QmBeN4BCJRKzI2Nu0k7s9APUmop7wWjhL/WdP06VlDLDPKC231OWXvkcZHHU 1DZBfMs0IGwX
coC44AHmY/LAx9BUt/a6uNakvdPFo0ctvHEwmmZCCjSHsjZHz/pVwim7NmdS Uoq8VcvRWl3P
EksWqW8kbqGR0hJDA8gg+ZyKf9g1D/oIxf8Afhv/AIuuStLoW1yNEbWdXhuN Ps4lljs44ZU+
VIgdi+W0pB8xTkjH3sdDjqdX1WTToIRb232m6uZRBBEX2KXILZZsHaoCsScH pwCcCicOV6BT
nzL0JPsGof8AQRi/78N/8XR9g1D/AKCMX/fhv/i6z9P8Ru+oNpmrW0dlqO5d kcMxnjlVldgV
fap/5ZuDuUcr3yCaGueOYNPDx2kMs8htbiaOX7PK0YeJgpVsLgDOckkAYH94 VGt7Ghv/AGDU
P+glF/34b/4uj7DqH/QSi/78N/8AF1lf8JtpEO5Lm4KyoT5ghgmlWNd7oGdg mEGUbJOAMHkj
BN6HxHp1xqZ0+OaUzbmQMbeQRMy/eVZSuxmGDlQxI2njg4ALH2HUf+glH/34 b/4uop7PWFQG
3vreR88iRHQY+oY1ZvGuHsp0tJFjuWjYRO3RXxwTwe+O1Zv2m7/s3zvtsn2X ds87Yn2rzN+z
ytu3y87+N/THGP46VwIvtGqxusdxL5Dt93fESCfQMHIzweM59qk8zUv+f2P/ AL9N/wDF1oQR
vJpsMGoeVcS+WomJUFXcAZOMevPSqEsZsHCklrZjhHJyUP8AdY+nofwPPJYD G+3uctdQsfeF
j/7PSbL3/n4g/wC/B/8Ai6sUUwK+y9/5+IP+/B/+Lo2Xv/PxB/34P/xdWKKA K+y9/wCfiD/v
wf8A4ujZe/8APxB/34P/AMXViigCvsvf+fiD/vwf/i6Nl7/z8Qf9+D/8XVii gCvsvf8An4g/
78H/AOLo2Xv/AD8Qf9+D/wDF1YooAr7L3/n4g/78H/4ujZe/8/EH/fg//F1Y ooAr7L3/AJ+I
P+/B/wDi6Nl7/wA/EH/fg/8AxdWKKAK+y9/5+IP+/B/+Lo2Xv/PxB/34P/xd WKpRyzLI/m7A
+CVj8z5m9OKQEuy9/wCfiD/vwf8A4ujZe/8APxB/34P/AMXTLW9FxK0eOVGf u4qa5toby2kt
7iNZIZBhlbvTAZsvf+fiD/vwf/i6Nl7/AM/EH/fg/wDxdUv7FtZRHDPpumiK Ig+bFborzY6b
sKAuO+PvH+6MqdWkgK+y9/5+IP8Avwf/AIujZe/8/EH/AH4P/wAXVBdG2NJ/ o+jzb5Xk33Gn
eZJ8zFsFt4zjOOnQVb0+x+wrccW6+dL5my3h8qNflVcBcn+7nr1NGoEmy9/5 +IP+/B/+LpCt
6vIkt3/2fLZM/jk4/Kq66Lb6xr1157bfKtYcfuYpOrS/89EbHTtihtFt9H16 18ht3m2s2f3M
UfRov+eaLnr3zRcC5DMsyngq6nDoeqn0ryjxB/x7aH/2DU/9GSV6nGANRuAO Mxxk+5ywz+QH
5V5Z4g/49tD/AOwan/oyStKYmd34d/4+W/7Btj/6Lauh02TGl2g/6Yp/6CK5 7w7/AMfLf9g2
x/8ARbVtaeT/AGba/wDXFP5CpluNGTN4WaazsI1vpYpbeNFk/ezOrFSjfLh1 2jKdvXsQMdBY
xfYtPtrXfv8AJiWPeeN2ABn9KbuNG41moRUnLqynNuKj0Rgp4OsLTwudI0+K ztJHSJZ547UK
twUxnzVUgurYIILchiM81X07wjdaN+/0u+061ujI7FU03bbhHWMMqxLICOYw Qd3c5z1rptxo
3Gr63JOZbwbIlldW9rqMUS3sjzXaNbExzyGTeCVDjjHyMM/OuAcYrPfw3qfh uNbnQooZruR5
Q0NnYRR26I6xggRtPHt+aMEEMTycg9a7bcaNxpWA5LTfAy2V7Z3jpo00qJAZ mudNE0yvGiof
Km3KUHyAjIbBye+K2rzTtX/tqbUNM1OxtxNDHFJHc2LzfcLkEFZUx988YPSt PcaNxpt3BHMa
z4XvJ/7V1K2u0k1K8tZbZ08najxbT5aDLcFW53E87mGANu19x4Qn1Wd7rVtT jkuXj8lmtLYw
qIvLlUABnf5szMckkcAY9ek3GjcaOlguYln4duhrEOrajqUVzexuoJhtjEhj WORVXaXbnMrE
nPoMCuk8yq240bjQ9QK8NlcJ5qvfuFMzzIYAY33E5BdsnftGFAI24ABBwMT2 MU1v9oaeaORp
pTLiKMxomQAQFLHqQWPPJYml3GjcaVgLPmVRmheGUzWyblc5kiBAyf7y54z6 jv169Zdxo3Gg
CKGeOdS0bA4OGHdT6EdjXK6mNTWzES6cJbf7VO+RGJXz5jFSUZSADk8jPbkZ rqZraGdg0kYL
gYDjhh9GHIqMWsg4W8uAvYfKcfiVJ/OiSurEzjzKxJatM9pC1yipOUUyIpyF bHIH41h3vhf7
ZoFhpf2zZ9khMXmeVnfmFo84zx97PXtj3rZ+zS/8/s//AHzH/wDE0fZpf+f2 f/vmP/4mnfSx
S0OVbwFCLm+aP+ygt15xE7aWDdoZAc/vg4yAWP8ADnHGe9WfEfg//hILoyPP abDB5IF1Z+e0
JyTviJcCNjkZOCTtHTFdD9ml/wCf2f8A75j/APiaPs0v/P7P/wB8x/8AxNHb yAym0CeOwgjt
L1I7u2upLmGaSAumXZyVZAwJGJCOGHOD7UqaDO1vMtzexvPNew3bvHAUXKeX 8oUsSAfL9TjP
fFan2aX/AJ/Z/wDvmP8A+Jo+zS/8/s//AHzH/wDE0LR3/r+tAMzRtIay1TVb x0KC4mxAhcEL
H94kY6bnZ29eR9Bp2X+ob/rtL/6G1ILeQ5xfT8deI/8A4mkSzeNSqXk4BJbo nUnJ/h9TR0sH
W5aoqv8AZpf+f2f/AL5j/wDiaPs0v/P7P/3zH/8AE0AJLYxSzmffcRyFQhaG 4kjyASRnawzj
cfzoisYopxPvuJJApQNNcSSYBIJxuY4ztH5Uv2aX/n9n/wC+Y/8A4mj7NL/z +z/98x//ABNK
wFa8/wCYh/16D/2pVO5WK5LpOm5TkZ7gHrirNwjRrqIaV5D9lBy4Gf4/QCpr XRbm8t1njeIK
+cBic9celNScXdAecweCr0XoSfVJPsC9NrsZWHoSen15rttwWExRqETBAA6C tb/hHLz/AJ6Q
f99H/Cj/AIRy8/56Qf8AfR/wp1KkqnxMDh5vDlw9olpFqCpBJZx2V2rQbjJG mRlDuGxiGYZO
4cjjjmxbaLPDqMMj3qyWVtPLc28Hk4dZH3Z3Puwyje+BtB5GScc9h/wjl5/z 0g/76P8AhR/w
jl5/z0g/76P+FTd7gZFw0k1tLEkhjZ0Kh16qSOop/wBrvcZ82HHl+T9n8o/Z vLxjb5W7p75z
2zt+WtT/AIRy8/56Qf8AfR/wo/4Ry8/56Qf99H/CkBkW7SQ20UTyGRkQKXbq xA6mnmYkEEAg
jBB71qf8I5ef89IP++j/AIUf8I5ef89IP++j/hQBStr/AMgbJtxiHR85KD39 R7/n61qI6ugZ
GDKeQQcg1B/wjl5/z0g/76P+FNHhm7Ri8c0UbnqyOy5+vHP407gWqKi/sXV/ +f8AT8h/8RR/
Yur/APP+n5D/AOIouBLRUX9i6v8A8/6fkP8A4ij+xdX/AOf9PyH/AMRRcCWi ov7F1f8A5/0/
If8AxFH9i6v/AM/6fkP/AIii4EtFRf2Lq/8Az/p+Q/8AiKP7F1f/AJ/0/If/ ABFFwJaKi/sX
V/8An/T8h/8AEUf2Lq//AD/p+Q/+IouBLRUX9i6v/wA/6fkP/iKP7F1f/n/T 8h/8RRcCWiov
7F1f/n/T8h/8RR/Yur/8/wCn5D/4ii4EtFRf2Lq//P8Ap+Q/+Io/sXV/+f8A T8h/8RRcCWio
v7F1f/n/AE/If/EUf2Lq/wDz/p+Q/wDiKLgS0VF/Yur/APP+n5D/AOIo/sXV /wDn/T8h/wDE
UXAloqL+xdX/AOf9PyH/AMRR/Yur/wDP+n5D/wCIouBLRUX9i6v/AM/6fkP/ AIij+xdX/wCf
9PyH/wARRcCWiov7F1f/AJ/0/If/ABFH9i6v/wA/6fkP/iKLgS0VF/Yur/8A P+n5D/4ij+xd
X/5/0/If/EUXAloqL+xdX/5/0/If/EUf2Lq//P8Ap+Q/+IouBLRUX9i6v/z/ AKfkP/iKP7F1
f/n/AE/If/EUXAloqL+xdX/5/wBPyH/xFH9i6v8A8/6fkP8A4ii4EtFRf2Lq /wDz/p+Q/wDi
KP7F1f8A5/0/If8AxFFwJaKi/sXV/wDn/T8h/wDEUf2Lq/8Az/p+Q/8AiKLg S0VF/Yur/wDP
+n5D/wCIo/sXV/8An/T8h/8AEUXAloqL+xdX/wCf9PyH/wARR/Yur/8AP+n5 D/4ii4EtFRf2
Lq//AD/p+Q/+Io/sXV/+f9PyH/xFFwJaKi/sXV/+f9PyH/xFH9i6v/z/AKfk P/iKLgS0VF/Y
ur/8/wCn5D/4ij+xdX/5/wBPyH/xFFwJaKi/sXV/+f8AT8h/8RR/Yur/APP+ n5D/AOIouBLR
UX9i6v8A8/6fkP8A4ij+xdX/AOf9PyH/AMRRcCWiov7F1f8A5/0/If8AxFH9 i6v/AM/6fkP/
AIii4EtFRf2Lq/8Az/p+Q/8AiKP7F1f/AJ/0/If/ABFFwJaKi/sXV/8An/T8 h/8AEUf2Lq//
AD/p+Q/+IouBLRUX9i6v/wA/6fkP/iKP7F1f/n/T8h/8RRcCWiov7F1f/n/T 8h/8RR/Yur/8
/wCn5D/4ii4EtFRf2Lq//P8Ap+Q/+Io/sXV/+f8AT8h/8RRcCWiov7F1f/n/ AE/If/EUf2Lq
/wDz/p+Q/wDiKLgS0VF/Yur/APP+n5D/AOIo/sXV/wDn/T8h/wDEUXAhGnQq W2S3kYZmcrHe
SouWJJwA2Bkkmpbe1itRJ5ZkJkbe7SStIzHAHJYk9AB+FL/Yur/8/wCn5D/4 imS6TqsMLytf
qVRSxwFzgf8AAKNAIbY4ktT/ANPc3/tSqerWbS67JcyaFHqcTW0UaM6wtsZW kJHzsMcMvSpr
RmMFizHLG5kJJ78SVq7jWkJuDujOpTVRWZk6faa7b6VYwR31lbiK2ijMUlo0 jKwQAgsJQDyD
0FX9WspNQhhMFz9muraUTwSld6hwCvzLkblIZgRkdeCDg1PuNG41MpOTuVGC irIwZPD2oy3K
6m+r251hJFZZfsZ8gIquoTy/M3YxI5z5mdx9PlqGfwndS2KQJq0YkMV1DO72 uQ6zvvO0BxtI
IGDkjGePTpC2BknAFMimSaJJYpFkjdQyuhyGB6EHuKRRjReFvLs9Wt/t2f7Q haLd5X+rzJK+
evP+tx2+778R6Z4Rh0vxBJqMUekOrTSTCRtMH2tS+SR54fpliPu528Z710G4 0bjR1uHSw+7V
7izngjmaF5I2RZV6oSMAj6darfZbjycfaYt+zyvK8k/ZvLxjZ5O7GMd85z32 /LU240bjSsA+
0V7ezggkmaZ441RpW6uQMEn69alZldGRwGVhgg8giq+40bjQBWbdY5DBnthy Hzkxj0buR7/n
0zU6OroGRgynkEHINO3GqckFobjYGWG5dWceW+x2GRlsD72CR1yOfemBboqo UImWE6jKJWUs
qfu9xAxkgbegyPzFCIZGkWPUZXaNtrhfLJU4Bwfl4OCD+NAFuiq/2aX/AJ/Z /wDvmP8A+Jo+
zS/8/s//AHzH/wDE0AWKKr/Zpf8An9n/AO+Y/wD4mj7NL/z+z/8AfMf/AMTQ BYoqv9ml/wCf
2f8A75j/APiaPs0v/P7P/wB8x/8AxNAFiiq/2aX/AJ/Z/wDvmP8A+Jo+zS/8 /s//AHzH/wDE
0AWKKr/Zpf8An9n/AO+Y/wD4mj7NL/z+z/8AfMf/AMTQBYrnrnS9Rk1FzHKR C8m7dkYA9x1z
Wz9ml/5/Z/8AvmP/AOJo+zS/8/s//fMf/wATQBKkSI7Mq4Zzlj60+q/2aX/n 9n/75j/+Jo+z
S/8AP7P/AN8x/wDxNAFiiq/2aX/n9n/75j/+Jo+zS/8AP7P/AN8x/wDxNAFi iq/2aX/n9n/7
5j/+Jo+zS/8AP7P/AN8x/wDxNACS2MUs5n33EchUIWhuJI8gEkZ2sM43H86I rGKKcT77iSQK
UDTXEkmASCcbmOM7R+VL9ml/5/Z/++Y//iaPs0v/AD+z/wDfMf8A8TSsAJ/y Ep/+uMf83ryv
xB/x7aH/ANg1P/RkleoW6NHfzhpXkPlRnLgZ6v6AV5f4g/49tD/7Bqf+jJK0 piZ3fh3/AI+W
/wCwbY/+i2rZ0/8A5Btr/wBcU/kKxvDv/Hy3/YNsf/RbVs6f/wAg21/64p/I VMtxosUUUUgC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAjnLCMBWKlnRcjGRlgD 1+tV7aHUrq1i
uIwuyVA65uBnBGf+eVWJlZkGwAsHVgCcA4YH+lULa00qWzt2up9ainEKK6Qz 3caghQOFQhR0
7VcbW1Mp819C5bPN+8iuFUTQsEYq2Qx2hs9B60krR/aoo7oH7K/B9HfPCt6A /wDjx4OOjJah
BJc+T5xh3qI2m3b2AjRckv8AMeQeTyafdxvNaSxoELOpXDjIPqDwf5H6HpWF eLlBpG1N2auY
1le3kdlZiOM+S6okLSxom8EcZPnEjI9FJ9j0rfrnpY2tns49UjR7MuY1RZgw B8t8AKsSntgA
HOSMVtWglEH70FcklUZtzKvYMe5/zk9Ty4WUlJwaeltzaslbm0Hx/fm/3/8A 2UUy5lkj2CON
mLH+Ec0+P783+/8A+yiqurrctYEWoy+4bh1yv079uK7mYEk14Lbasw2tjJ3H H5VZVg6hh0Iy
KxtKtbia1kW9Qqm4FF27e3PB6dvTpWyAFUADAHAFJAU7yzEs8dyftEgQbXgj uXiDr7bWA3Dt
ng9DjgqWdmIp5LkfaIw42pBJcvKEX33MRuPfHA6DPJa7RRYDOvP+Yh/16D/2 pWvpNrNJpkLr
f3ESndhEWPA5PqpP61kXn/MQ/wCvQf8AtStWCxtNS8K/ZL61gurZ1bfDPGHR sMSMqeDggH6i
lJ2VxpXZf+xXH/QTu/8AvmL/AOIqOOB5WkWPWLh2jbY4UQko2AcH5ODgg/iK 89kmg8NeD9At
9Eez0O4vrVJ5LhZLe0jmYRqNrM8MpeQlgQoXJweRjBbo3iG5n1ATwa3GNTu7 20eTRoxEfNjk
hg8yQqQZAFBZgQQBt5B5qlG8nHt/mTeyueh3KXFjay3f26ebyUMhjkWPawAy R8qgj6549+la
Nc5Y2/2bwhqUYMZzJfNmNgwOZZD2J555HUHrzXR1IwooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAKr3//ACD7n/rk38jViq9//wAg+5/65N/I0Acn Z/8AHvY/9fMn
8pK4ZtY1CyuL/Wo7O5tF1S3n8m7m8po3dAWtyqhy3+rViQyiu5s/+Pex/wCv mT+UlatUt7gY
elPfQatqFlc38t8scMU8bSxorKXLgqNigbfkGM5PJ5Ncta+Kb5RFMdZF0pSK XUlaONRpreci
tGQFBQbWkz5hJAjzkc16LRQtHcOljz/UtWj1O6t7xdcMNhBqrRRXMPleWVNr kDcykEFiQD33
YBzjEHhybUbpYLC21J7CIWnmM9vBEXYrDbbcllIP326gnGBxgV6PRS7+gHnN j4l1q81uxSbV
NNtFcWxFrcXSwm5R40ZmSMxFnOWcArIBlQCODnQ8Uatcadqtz5Wo22nx7Lbz JXaKKRlPnkqk
kism47RgPx1GVJzXbUU27gjmpru/u9O8PLb39xavfMBNM0EfmkeS7fdIZVbI B4BH1Fc/c+I9
TgiZZtaMNzbxuLOIxRA6nKs0ibDleThEBEe0gvnoRj0WijrcOhzOgsIvEXiG N9Qlkm+0LJ9i
fy/kUxJhwAoYjquSSPl9c1gaV4i1fUb28FpqSXCNbtdRQ+fDNJEUdD5LhIVE bFWKlSzkeoxk
+i0Ul08kBwWteIr37DBPbaoLMX0sktpLLNDbx+UoVVTc8UhZnPzhQuSCeRgA 50WvzmSXVJWE
Mz2jfvIvLiEbOlp8zMykBQWyWYNgDocAV6dRTWjA8sttelnu4X1LxRb2TxR3 MUV9FNBJ5/8A
qHUKzRKj/eP3UBOOPUrJrutW6bpLq10h7qXzLqa5nW2VJhbwER73ilUZy52k AnbweCD6lRR0
AztL1JbqKK3luIJb5bWKef7OS0ZDg4ZGI5UlWx7CtGiih6sAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigCun/ISn/64x/zevK/EH/Htof/AGDU/wDRkleq J/yEp/8ArjH/
ADevK/EH/Htof/YNT/0ZJV0xM7vw7/x8t/2DbH/0W1benW13Nptq1ukDIIkB MkpU5wOwU1ie
Hf8Aj5b/ALBtj/6Laus8Pf8AIFt/9xf/AEEVMtxor/YdS/55Wn/f9v8A4ij7 DqX/ADytP+/7
f/EVjeLNcudK3yxWF7et9vt7YeRciNI0doVII81Ms3mNtPIBxuIUV0Oh3L3N tOWSaMLIAsUz
h3jBjRirMC2SCx7kehxipAqS297AgaYWMak4Be5IGfxSnLZ6i6Bljs2VhkEX DEEf98Vmzaku
majqW/7XdP8AbRDGolyyh40k2qCwAALHp2AJ4GRSvr9/sztFaara/OHkkF8q hE3AuQPNwDt3
dRjPWoi6kp2UdO45ckVq7M6D7DqX/PK0/wC/7f8AxFH2HUv+eVp/3/b/AOIp viTUb6LwPqGo
6bGYbz7E0sS3HyNESucsMNhl64x1GPesbTtdvNFiW1uNMAsra6jtLq5fVpbq RZpdu3Z5ibnT
MiAklcZOFIAzYulzb+w6l/zytP8Av+3/AMRR9h1L/nlaf9/2/wDiKg0PxNc6 ne28N3pyWiXt
qbyyZbjzWeIFQfMG0BG+dDgFhyeeOejod0Bh/YdS/wCeVp/3/b/4ij7DqX/P K0/7/t/8RW5R
RcDD+w6l/wA8rT/v+3/xFH2HUv8Anlaf9/2/+IrcoouBh/YdS/55Wn/f9v8A 4ij7DqX/ADyt
P+/7f/EVuUUXAw/sOpf88rT/AL/t/wDEUfYdS/55Wn/f9v8A4ityii4GH9h1 L/nlaf8Af9v/
AIij7DqX/PK0/wC/7f8AxFblFFwMP7DqX/PK0/7/ALf/ABFH2HUv+eVp/wB/ 2/8AiK3KKLgY
f2HUv+eVp/3/AG/+Io+w6l/zytP+/wC3/wARW5RRcDD+w6l/zytP+/7f/EUf YdS/55Wn/f8A
b/4ityii4GENP1EEkQ2mScn/AEhv/iKX7DqX/PK0/wC/7f8AxFblFFwMP7Dq X/PK0/7/ALf/
ABFH2HUv+eVp/wB/2/8AiK3KKLgYf2HUv+eVp/3/AG/+Io+w6l/zytP+/wC3 /wARW5RRcDkL
1WU6irgBxaAMFORn950Nef658dP+EO1ifQP+Ec+2fZdv7/7d5e7cof7vlnGN 2OvavQ9U/wCP
jVf+vb+slfLnxS/5KPq3/bH/ANEpQwPT/wDhpr/qUf8Aypf/AGqj/hpr/qUf /Kl/9qrwCikB
7zd/tJ/arKe3/wCET2+bGybv7RzjIxn/AFVQ/wDDS2pf9C5af+BDf4V4ZRQB 7n/w0tqX/QuW
n/gQ3+FH/DS2pf8AQuWn/gQ3+FeGUUAe5/8ADS2pf9C5af8AgQ3+FH/DS2pf 9C5af+BDf4V4
ZRQB7n/w0tqX/QuWn/gQ3+FH/DS2pf8AQuWn/gQ3+FeGUUAe5/8ADS2pf9C5 af8AgQ3+FH/D
S2pf9C5af+BDf4V4ZRQB7n/w0tqX/QuWn/gQ3+FH/DS2pf8AQuWn/gQ3+FeG UUAe5/8ADS2p
f9C5af8AgQ3+FH/DSupf9C5af+BDf4V4ZRQB7s/7Sl+Gwnh61YepnYf0pn/D S2pf9C5af+BD
f4V4ZRQB7n/w0tqX/QuWn/gQ3+FH/DS2pf8AQuWn/gQ3+FeGUUAe5/8ADS2p f9C5af8AgQ3+
FH/DS2pf9C5af+BDf4V4ZRQB7n/w0tqX/QuWn/gQ3+FH/DS2pf8AQuWn/gQ3 +FeGUUAe5/8A
DS2pf9C5af8AgQ3+FH/DS2pf9C5af+BDf4V4ZRQB7n/w0tqX/QuWn/gQ3+FH /DS2pf8AQuWn
/gQ3+FeGUUAe6D9pXUcHPhy0z/18N/hSf8NLal/0Llp/4EN/hXhlFAHuf/DS 2pf9C5af+BDf
4Uf8NLal/wBC5af+BDf4V4ZRQB7n/wANLal/0Llp/wCBDf4Uf8NLal/0Llp/ 4EN/hXhlFAHu
f/DS2pf9C5af+BDf4Uf8NLal/wBC5af+BDf4V4ZRQB7n/wANLal/0Llp/wCB Df4Uf8NLal/0
Llp/4EN/hXhlFAHuf/DS2pf9C5af+BDf4VuaV8dNS1Oxubn+xrSPybaW42+a xzsBOM++OtfO
Fdp4Ymjj0XUA7qpOnXSgE9SUbApNpbibS1Z3/wDw0tqX/QuWn/gQ3+FH/DS2 pf8AQuWn/gQ3
+FeGUqqWYKoyScADvTGe8Wv7R2pXNwsP/CPWabgfmNw2BgE+lPm/aK1W2iP2 jw3BHNuwqGZs
MPXOK8beCG1jWGZAska7mljOdysSp+uMjFZLuzkbmZsDAyegrOMnJ3WxKd2e 8p+0bqDRBzoN
mCf4RO5P8quP8ftRXTnu/wCxLQhSMr5rdCcdcfSvntZWRcDFDzSSKFd2KjoM 8Cm1K+jNE49U
e6P+0nfqilfD9qzEnI89gAO3OPrUf/DS2pf9C5af+BDf4V4ZRVknuf8Aw0tq X/QuWn/gQ3+F
H/DS2pf9C5af+BDf4V4ZRQB7n/w0tqX/AELlp/4EN/hR/wANLal/0Llp/wCB Df4V4ZRQB7n/
AMNLal/0Llp/4EN/hR/w0tqX/QuWn/gQ3+FeGVreGtIj13xDaaZLM0KTlgZF GSuFJ6fhTSu7
EykopyfQ950X45avrNlf3C6JYwm0hMwV53O8DrzjjpTLz4563pxhe98Nwx28 oBEyyMw55x2G
fbNcPJ4K1Lw5LnTdZiZRlGEkRXcPQjkGo216bSNIu9J1KFHjlikWGSE5VQRg Ag9hkD8q7Y4e
Kheat5niyzCpKp+5aku2z/FfM7PV/wBoW9024hSHRbS5iliEiyeaydSRjGD6 VVP7SN95Bk/s
C1znAXzm5/SvDbuf7RPuGdoGBmoK5JNczsj2KanyLmep7n/w0tqX/QuWn/gQ 3+FH/DS2pf8A
QuWn/gQ3+FeGUVBoe5/8NLal/wBC5af+BDf4Uf8ADS2pf9C5af8AgQ3+FeGU UAe5/wDDS2pf
9C5af+BDf4Uf8NLal/0Llp/4EN/hXhlFAHuf/DS2pf8AQuWn/gQ3+FH/AA0t qX/QuWn/AIEN
/hXhlFAHuf8Aw0tqX/QuWn/gQ3+FH/DS2pf9C5af+BDf4V4ZRQB7n/w0tqX/ AELlp/4EN/hR
/wANLal/0Llp/wCBDf4V4ZRQB7n/AMNLal/0Llp/4EN/hR/w0tqX/QuWn/gQ 3+FeGUoBJAAy
T0AoA9y/4aW1L/oXLT/wIb/Cj/hpbUv+hctP/Ahv8K8f07R3vbowTSrasBnE qkNjGQcHHFXB
YxxrLaPHDKsZJ81T19waxlXinYtQb1PYYP2g9XuLR508PWQK87GuWGR6g4oh /aH1GVc/2Dah
sA485j/SvH7i5jtWW2bC5AyPQVTe/S1k/wBHxIQv3mHAOP1qFOpLb5DcYo9y H7QF/wB9FtAc
ZH71uf0rPl/aS1SKVo28N2oKnHNww/pXif8AaFyYyhcEE5GQMj6elViSxJYk k9zWsFNfEyW1
0Pcv+GltS/6Fy0/8CG/wq1pv7Qeoa1qlppT6BaxJezJbNIs7EqHYLkDHbNeB VseE/wDkctD/
AOwhb/8Aoxa0JPrOz/497H/r5k/lJWrWVZ/8e9j/ANfMn8pK1aoAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKAK6
f8hKf/rjH/N68r8Qf8e2h/8AYNT/ANGSV6on/ISn/wCuMf8AN68r8Qf8e2h/ 9g1P/RklXTEz
u/Dv/Hy3/YNsf/RbV1nh7/kC2/8AuL/6CK5Pw7/x8t/2DbH/ANFtXWeHv+QL b/7i/wDoIqZb
jRPc6RZXcxllifeepSV0z7kKRk+/sKntbSCyh8q3TaucnJJJPqSeT+PpU1FR cDndR8H2moar
LqK319azyqBIIGQqSABnDq2CQqg4wDtHpTrDwla2d4lxNfXt75Z3JHcmPYrD o2FRckds5APO
MgEdBRWvtqnLy30I5I3vYhu7SC/s5rS5TfBMhjkXJGVIwRkc1Ql8N6VNq66o 9u/2oMrnE8gj
dlGFZow2xmAxhmBIwMHgY1aKyLMrS/Dml6NcST2Nu8buuwBp5JFjTOdsasxE a5/hQAcDjgVq
0UUB5hRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAcnqn/Hxq
v/Xt/WSvlz4pf8lH1b/tj/6JSvqPVP8Aj41X/r2/rJXy58Uv+Sj6t/2x/wDR KU2Bx9FFFIAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooxmigAoo
ooAKKKKACiiigAooooAKKKKACt3SmI026I4/0aUfoawq3NL/AOQbd/8AXvJ/ KsMR8BzYv+H8
zDq5ZxSmKR44BK7YRQVzw2QSPyxmq8EXnXEcecBmAJ9BWst1uEN5Asqxxjyp 44jzsGSD+X4Z
HvV1JNaI3kzPlvDJZxQFF3pkGTuV7D8Of0qrUtxKssg2AhEUKu7rgetRVcVZ DQUUUUxhRRRQ
AUUUUAFFFORGkcIoyTQA6GIyyKMHbuAZgOma9J03wNpN5oAv7O/ubfUY2wp3 gr0HUAZH4HvW
TpBg8KtLBqTFodTssCWJc4DgEcNjOM9q1IrLSNS0RtR064ey1G2iLMkL8ttH OV64PqPx9K7a
NONtdWeLjMVNtcjaXRrVa9y9DbTT6ZdmTVr5L20Vd8DzCQKcgdxnBByDXmt9 q15fkC4kJK5F
S63qUl/qTzscOyKr46EgYzWXWdetze7HY6cFhPZrnnq35bd9QooormPRCiii gAooooAKKKKA
CiiigAooooAKKKmt4w7lmGVXt60m7K4FjT9JutSkCwphf77dP/r1q22mPpsj s2ySVTgY5I54
47GpLC/mM3lKSu1csRxjjp7VHbFXkdo3LXHmZwT3rhqVKkm09jeMYq3chn1a 61FjDcYQxkBF
xhgKjvrpYI9kUoaRxzj+H61T1OVpLwu7kyYwwyDg+2KpVvCjGya0XYiU2SSz PMwZ8ZAA4qOi
iuhKxmFFFFABWx4T/wCRy0P/ALCFv/6MWsetjwn/AMjlof8A2ELf/wBGLQB9 Z2f/AB72P/Xz
J/KStWsqz/497H/r5k/lJWrVAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBXT/kJT/9cY/5vXlf iD/j20P/ALBq
f+jJK9UT/kJT/wDXGP8Am9eV+IP+PbQ/+wan/oySrpiZ3fh3/j5b/sG2P/ot q6zw9/yBbf8A
3F/9BFcn4d/4+W/7Btj/AOi2rrPD3/IFt/8AcX/0EVMtxo1KKKKgAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAOT1T/ AI+NV/69v6yV
8ufFL/ko+rf9sf8A0SlfUeqf8fGq/wDXt/WSvlz4pf8AJR9W/wC2P/olKbA4 +iiikAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUVJFBJNnYucdaYysjFWBBHY07O1xXV7CUU UUhhRRRQAUUU
UAFFFFABRRRQBbiVPKUsevYVVYYYj3ro7LTVntooriA2j4yJJV2b/Xr97+lY +pWzWt0UbGfU
dD71fPGcFboPmTRToooqBBRRRQAUUUUAFFFFABRRRQAV0Oj28sulXjouVW1l YnPYA1z1dj4c
/wCQBqX/AF4z/wAjUTgpqzIqU1NWZydrMLe6jlI3BWyR6jvVm4ltoI5IbOV5 FlOWYqVwvZff
3NUaKbim7lW1CiiiqGFFFFABRRRQAUUUUAFb2maJco9rezxSCxdtksyrkRc8 5PbiszTIDc6h
FCoBdztQH+8eB+tdjo3iW88IPPp2paa5t3Y7lbPORjg9CDit6UV8UtjhxlWo lyUtX2628i14
z0i1hi04R31xcwpCvkpI6sEBAyAQMkcCqOneHRpvipYtfRINOnDtGTOFGCCV 5B4/HFdLD/wh
PiOD92iWNyAXUofKYMBwP7p+lcB4h1+91KVIriaOXy40AkVQD90ccdxnH4Vt UcF7xw4b21WL
pK63Tvo1fqjDkG2RlDbsEjd6+9NooriPcCipbe2mu51gt4nllboiKSTS3CRx sI4zuKj5m7E+
1axoylTlV6L8W+i/MV9bENFFFZDCiiigAooooAKKKKACiiigAq3ZSIDsc4yw NVKKUldWGnY6
OZdP0+ASpcsbh+SByeexHbrWDJNumeSPKbuwNRUVnTpcm7uxylcKKKK1JCii igAooooAK2PC
f/I5aH/2ELf/ANGLWPWx4T/5HLQ/+whb/wDoxaAPrOz/AOPex/6+ZP5SVq1l Wf8Ax72P/XzJ
/KStWqAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigCun/ISn/wCuMf8AN68r8Qf8e2h/9g1P/Rkl eqJ/yEp/+uMf
83ryvxB/x7aH/wBg1P8A0ZJV0xM7vw7/AMfLf9g2x/8ARbV1nh7/AJAtv/uL /wCgiuT8O/8A
Hy3/AGDbH/0W1dZ4e/5Atv8A7i/+gipluNGpRRRUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQByeqf8fGq/wDXt/WS vlz4pf8AJR9W
/wC2P/olK+o9U/4+NV/69v6yV8ufFL/ko+rf9sf/AESlNgcfRRRSAKKKKACi iigAooooAKKK
KACiiigApyIznCqTTaekjRk7cc+1NW6id+g5C0QypIY+lSJbNMC3mqX7gmoo 5Ar7nG4emakL
KQ0ilUJ6AHnNWrdSHfoQvG8Z+ZSPT3ptW5X3rH5pJAPPrTBbtM5MahF7BjzS cddBqempXop/
kyeb5e0l/QU1lZThgQfQ1NmVdCUUUUhhRRRQAVPZkC6RuMqcgHoTUFdv4S1I 2FtPbw2Udyzx
knplj9f6d6yrTcIXSuTN2Rd16XUrrwpZ3F4kRtiM+b1df7vPb/A/lwk43qWw xI/iNWNWvJpp
2h3ssCncsAYlUPoAaW2iN2Y4wwXzPlrTB0+Wm4v1CkrR1M2irV/YS6fcGGXB 7gg9R61VoTT1
Q001dBRRRTGFFFFABRRRQAUUUUAFdj4b/wCQBqf/AF4z/wAjXHV0uiXbw6Nf RqoO60lXJ9CD
Uymoq7InNQV5HNUUUVRYUUUUAFFFFABRRRQAUUUUAS21w9rcRzxnDowYEdjX pWmfE+2/smWx
1KxLl0I3pgjOMfdPT868worSFWUNEc1fCUq7TmtUbOsarDdXDtartRumVAx+ ArLgjWWXa7lV
6khcn8sioqntf9YfpT5nOd5GkKcaUOWJpppdiYWP2iZ3AGMKFByePWsiVQs7 ogbAYgA9a3Ui
bZuU8FVYkjGMdf6VLpEunaTZXGrXIjuL9mKWdq65Az/y0YHqB2FdWIpLlTjG yW9hU5Nt3ZXs
tVXQtMuoreHGpXKhDcZ5ijPUAdieOawqVmLMWYkk9SaSuWvKnKo3TVo9F/XX uaq9tQooorIY
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVseE/wDkctD/ AOwhb/8Aoxax
62PCf/I5aH/2ELf/ANGLQB9Z2f8Ax72P/XzJ/KStWsqz/wCPex/6+ZP5SVq1 QBRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAV0/5CU//AFxj/m9eV+IP+PbQ/wDsGp/6Mkr1RP8AkJT/APXGP+b1 5X4g/wCPbQ/+
wan/AKMkq6Ymd34d/wCPlv8AsG2P/otq6zw9/wAgW3/3F/8AQRXJ+Hf+Plv+ wbY/+i2rrPD3
/IFt/wDcX/0EVMtxo1KKKKgAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKAOT1T/j41X/AK9v6yV8ufFL/ko+rf8AbH/0 SlfUeqf8fGq/
9e39ZK+XPil/yUfVv+2P/olKbA4+iiikAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAOU
jeC2SKsDa7F4gV2j7xNVaKpSsS43LcClXJZnWQjIA7053SefE/3U4ytQNcyO qqxAA7gVKsAk
hJjdRz0J5rRO+kTNqzvIbLabVMkTB0/UVWqbeYo2TOS3XFQ1nK3Q0jfqFFFF SUWLMDzgxPK8
ge9bTa1YHTGt/sflXSDCz25EYYgjGQBycjrXOgkHIODRWc6Sm7slxT3Hu7zz F5HZndsszHJJ
Pc1qQW8DYhguHSdTykyhM/Q9vxrIq/HqTtsE6q5UbRJt+cjsCe/StqeklrYG pXVi94jiRDB5
JYxKCPmOfmP/AOqsKupuF26MJREs4lAPlsOnHUHrkZrn7ixlt4klLRvG2PmR s7SRnB9D/kVH
KouydyKckvduaWjWsUkDSPEsvPIIyfyqS50mylmRraVo0fOQRkKR9e/tWRZ3 stjMJIj9VPQi
tO71mC4hykJSRhhx2Poa9CnUoulyyWq/rc9KnOk6dpLVEb6Li0inScNuYKw/ wp8mjQRyEC4J
ATfzjH/16ktr5Li3CgCOSNcu2eMDv9RVc6lbSWuHibz9xYv9fT0HtTccPa/c bjQtfub8dhZ6
iqkxQRXoi3xvCgRJAvVSo43Y5BHXFZNxM6TpCbUiVc5b1HqD3FOtr+MmO6wY wikybfXpkfpV
u1mbXUaCGP8AfpnyyXC7/YAnkn0FTTlTipJSstLHNRlSoqa5rRVrX9NTP1TT xLCL22JZdo3r
7Dv/AI1h1vrrMcV0VaJkTGJEI53Dg8VTnurI2k6RRASSMCMDAFTXjSm+eMv6 /wCCbVo05vmj
L+v+CZlbulf8gy7/AOvaT+VYVb2kKzaZeYUnFtKTgdsGvMxHwHl4r+H8zBoo orc6QooooAKK
KKACiiigAooooAKKKKACpoLhoCMKrDOcHvUNX9P0q51CK4njjP2a2TfPJ0Cj /H2rSlGUpqMX
qxO1tTb0u2Nzplxq+qStb6bACkSxABppDyEXPUZ61zM0zTytI/U/pU11fS3E aW/mP9miJ8uI
twuepx6mqta16kk5UlPmjffvb+tBRit7BRRRXMUFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABWx4T/5HLQ/+whb/APoxax62PCf/ACOWh/8AYQt/ /Ri0AfWdn/x7
2P8A18yfykrVrKs/+Pex/wCvmT+UlatUAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFdP8AkJT/ APXGP+b15X4g
/wCPbQ/+wan/AKMkr1RP+QlP/wBcY/5vXlfiD/j20P8A7Bqf+jJKumJnd+Hf +Plv+wbY/wDo
tq6zw9/yBbf/AHF/9BFcn4d/4+W/7Btj/wCi2rrPD3/IFt/9xf8A0EVMtxo1 KKKKgAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKAOT1T
/j41X/r2/rJXy58Uv+Sj6t/2x/8ARKV9R6p/x8ar/wBe39ZK+XPil/yUfVv+ 2P8A6JSmwOPo
oopAFFFFABRRRQAUUUUAFFFPWKRxlUYj2FNK+wDKKmW2cnDEJ7N1qRbaLcyP KVcDPIwKpU5M
lyRVoooqCgoqe2tvtDY8xV9j1rQW1toBlwDxyXrroYKpVXNsu5LkkZFFWJ1g OWhJ46g/0qvX
PUhySte/oNO4UUUVAwooooAKKKKACiiigAooooA6mxbzvDtw7ZdhlEUYG3OP 8awReP5kIYKo
jK5Kr97HQn1qTSbq3trvfdqWiCn5QM5PaqUm3zG2Z25OM+lK7cncyUbydzRF vaXQZt8sTMzM
JWAKHuRgcj9apmzn82WNEMhjG5jHyNvr9ORTIJ5LaZZYm2uvQ1YS5ZIjMlwY 7gN2Bye3XtTC
0o7FOiirNlPBA8nn2qTq67RuLDYfUYI5+tBpJ2V0rk8/7nTkj6M5A/Lk/qRS u72lnbSRNtYt
kEHpgA/1FO1OFfslndRzROkispVW+ZWBOcjr0K89Pxq3bae2taJHHZMr39rI xa2zhpEIXBX1
IwcjrUnK5xUVKW19S1cQ2GoXn2zUZ5o/tdssgnT5gkgJUllPJB254Pf8K568 txaXcsCzxTqh
wJYjlW9xVucvBp4jkDB+E2t/D3P0/wDrmqdtF5soyMqOWoWg6EXBN307ENdl 4a/5AGp/9eFx
/I1zWr28dtqs8cK7ISQ8a5JwrAMBk8kYIro/Dsip4e1QnP8Ax5TLx6nj+tUt TohJSipLqcfR
RRQUWLGOGW8jS4bZCT87f3R6/Wt6Pw0kUgu4bqy1OwTJlCTGN1X3U4Oe/wAp asvRRcPdyRWb
ItzLE0ab2Chgwwy5PHKkitGazudN0OWO+0ee1uE/1d1KHRsE8qB0KkE84PJ4 rkrSlz8sZW8v
16P7jaCVrtHOUUUV1mIUUUuDjOKADBxmkpzfcU/hTabGwoop8UTzzJDEpaR2 Cqo7k9KQgiia
aQIg5P6VtalritoltotjF5NtH81wwOTPJn7xPp0wKt69bWHh/TotIiCy6qTv vJ1PEfH+rH9a
5et5So+xUYr373b/ACS/Nv8AprW4UUUVgMKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigArY8J/8AI5aH/wBhC3/9GLWPWx4T/wCRy0P/ALCF v/6MWgD6zs/+
Pex/6+ZP5SVq1lWf/HvY/wDXzJ/KStWqAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigCun/ISn/6 4x/zevK/EH/H
tof/AGDU/wDRkleqJ/yEp/8ArjH/ADevK/EH/Htof/YNT/0ZJV0xM7vw7/x8 t/2DbH/0W1dZ
4e/5Atv/ALi/+giuT8O/8fLf9g2x/wDRbV1nh7/kC2/+4v8A6CKmW40alFFF QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFAHJ6p/wAf
Gq/9e39ZK+XPil/yUfVv+2P/AKJSvqPVP+PjVf8Ar2/rJXy58Uv+Sj6t/wBs f/RKU2Bx9FFF
IAqe1FszMLlpFBHysmOD7jvUFFJq6sXTnySUrX9TQGj3EwJsit2Ou2Ll8f7v X8s1XjtT5rpP
uiZM7lK4I+tRRyyQuHidkYd1OK1f+EgluITDfwQ3YK7RJIv7xR7N1pw934tR 1HCpJci5b/Nf
5/mUZ7Ty4xLE/mR9z6UyNIlj3yhyCccdq0YFtWP+izlc/eim7/Q0+4snsyUm iIt3/iHIB+tb
0+Sp70dPJ/1sRXpTo2Ummns09yiLSCdc28vzf3WpHWVbdZI2baOGAPSlNnLB IHUlk6gqe1a6
2SYEscjfOPnQrxVqN21yu/kmzmlO3W5jtcRSRjzA3mqOGXv9alEf9oQ5Ufvk GM9jSyw2iTFX
R0J6gdvp7U2Z1hlje3JVSMbhxk1tGnb3qjTXW25XoQR2rJNi4Qqo7ev41oo8 USgogHoFFQzT
vcQZJ6dcd6rPk2uQTlWya6YOGHv7JX0vd7j1luSSBJmYpHskXnjjNINzFopc /MO/ao4pppAV
3ruA4Zuv0z/jSrFKSd5/eA5AJ5/CsVPn96Keu/b/AIcdrFVlKsVPUUlWrmLI 83IU45U8HNVa
4KtN05WLTuFFFFZjCiiigAooooAKKKKACiiigAooooAKKKKACiiren6ZeanO IrWB5CTgsBwO
M8noKTkoq7Gk27IqU5JHjcOjFWHQiutg8KWY0Ce9nvR5xjJQk7VjYfwnPft+ NchWdOtGpfl6
F1KUoJc3U0Yp7O5gaO8SUSj/AFTxuAoPfII78d+MVDPMiL5UAwvcg9aqVJDs 81TIMoDlhnGR
6VpY5/ZpO/4GpqKJNFps7ZLS24Qgeqkj+W2tvRZY5NOudHSCNZLmJo4ph97e 3QNk4wTge2a5
95RO1uIyCkWeO/Na9uJLW6vQUw0Wdu4dgRg/oDWVRuMdDhrc0YKKdn0+/Q5y SyuYrSG7kgdb
eYkRyEfKxBwRn1qCtyfWJ7N7iK3KmC5DeZE4DKc5wSOmR1B61Da6PHfWyC1u 1N/gk2sgC7h2
2NnBOOxx7ZrS/c6o1mo81TRf1v29dizol/NpVlJewabBdjftkeWIOI+46g4z 6+1VtZ1GfUBF
OzSJDJkiEk7VI649ufwzitXw/renaUcS/b7G+UbDdW7+nZkPUDGMDH1qn4sk uZtUWee6+1Ry
o
Current Time: Sun Nov 30 11:57:40 EST 2025
Powered by FUDForum. Page generated in 0.03684 seconds
