Home » Archived » OHF » OHF Bridge Mesa test 10501
OHF Bridge Mesa test 10501 [message #34065] Fri, 05 October 2007 17:15 Go to next message
I'm trying to do the first MESA PIX test "10501" using the bridge, but I'm
getting an error. It appears to be trying to do a PDQ query instead of a
PIX query, though I'm pretty new to IHE so that may be a misunderstanding
on my part.
I'm sending the following XML to the bridge:
<SOAP-ENV:Envelope
xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:tns1="http://ws.bridge.ohf.eclipse.org"
xmlns:tns2="http://type.bridge.ohf.eclipse.org"
xmlns:impl="http://localhost/bridge/services/ohf-bridge-wrapped">
<SOAP-ENV:Body>
<tns1:SearchPatient>
<tns1:sessionContext>
<tns2:returnLogLevel>WARN</tns2:returnLogLevel>
<tns2:rhioName>mesa</tns2:rhioName>
<tns2:sessionID>1111</tns2:sessionID>
<tns2:useSecuredConnectionWhenAvaliable>true</tns2:useSecuredConnectionWhenAvaliable >
<tns2:user>patientsearcher</tns2:user>
<tns2:userApplicationName/>
<tns2:userFacilityName/>
</tns1:sessionContext>
<tns1:patientInfo>
<tns2:genericAdtValues>
<impl:item>
<tns2:data/>
<tns2:path/>
</impl:item>
</tns2:genericAdtValues>
<tns2:patientAddress>
<tns2:city/>
<tns2:country/>
<tns2:countyParishCode/>
<tns2:otherDesignation/>
<tns2:stateOrProvince/>
<tns2:streetAddress/>
<tns2:zipOrPostalCode/>
</tns2:patientAddress>
<tns2:patientDateOfBirth/>
<tns2:patientIdentifier>
<tns2:assigningAuthorityType>
<tns2:namespaceId>HIMSS2005</tns2:namespaceId>
<tns2:universalId>1.3.6.1.4.1.21367.2005.1.1</tns2:universalId >
<tns2:universalIdType>ISO</tns2:universalIdType>
<tns2:universalIdTypeCode>PI</tns2:universalIdTypeCode>
<tns2:useDefaultAssigningAuthority>false</tns2:useDefaultAssigningAuthority >
</tns2:assigningAuthorityType>
<tns2:idNumber>PIX10501</tns2:idNumber>
</tns2:patientIdentifier>
<tns2:patientName>
<tns2:familyName/>
<tns2:givenName/>
<tns2:otherName/>
<tns2:prefix/>
<tns2:suffix/>
</tns2:patientName>
<tns2:patientPhoneBusiness>
<tns2:unformattedTelephoneNumber/>
</tns2:patientPhoneBusiness>
<tns2:patientPhoneHome>
</tns2:patientPhoneHome>
<tns2:patientSex/>
</tns1:patientInfo>
<tns1:queryPreferences>
<tns2:domainsReturned>
<impl:item>
</impl:item>
</tns2:domainsReturned>
<tns2:quantityLimit>1</tns2:quantityLimit>
<tns2:withoutDemographics>false</tns2:withoutDemographics>
</tns1:queryPreferences>
</tns1:SearchPatient>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
I get back:
<soapenv:Envelope
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<SearchPatientResponse xmlns="http://ws.bridge.ohf.eclipse.org">
<SearchPatientReturn>
<ns1:failMessage xmlns:ns1="http://type.bridge.ohf.eclipse.org">
Error location: QPD^1^3^1^4^ Error code: 204 Error severity:
Warning</ns1:failMessage>
<ns2:log xmlns:ns2="http://type.bridge.ohf.eclipse.org"/>
<ns3:sessionID
xmlns:ns3="http://type.bridge.ohf.eclipse.org">1111</ns3:sessionID>
<ns4:success
xmlns:ns4="http://type.bridge.ohf.eclipse.org">false</ns4:success>
<ns5:successMessage xmlns:ns5="http://type.bridge.ohf.eclipse.org"/>
<ns6:patients xsi:nil="true"
xmlns:ns6="http://type.bridge.ohf.eclipse.org"/>
</SearchPatientReturn>
</SearchPatientResponse>
</soapenv:Body>
</soapenv:Envelope>
Tracing the network shows that the bridge sends the following HL7:
MSH|^~\&|XDSDEMO_ADT|XDSDEMO|XDSDEMO_ADT|XDSDEMO|2007100 5133800-0700||QBP^Q22^QBP_Q21|0886784820993939999|P|2.5
QPD|QRY_PDQ_1001^Query By
Name^IHEDEMO|1903342086890395431720417949101|@PID.3.1^PIX105 01|||||^^^&1.3.6.1.4.1.21367.2007.1.2.400&ISO
RCP|I|1^RD
The mesa PIX server replies:
MSH|^~\&|XDSDEMO_ADT|XDSDEMO|XDSDEMO_ADT|XDSDEMO|||RSP^K 23|MESA4706a0c4|P|2.5||||||||
MSA|AE|0886784820993939999||||
ERR||QPD^1^3^1^4|204|W||
QAK|1903342086890395431720417949101|AE
My rhio config has the same entry for the pix as I used to successfully
test against the IBM PIX Manager except the url is to a local machine (the
one running the mesa server):
<pix>
<id>mesa</id>
<mllp>
<unsecured>mllp://192.168.1.127:3600</unsecured>
</mllp>
<pixServerPropertiesId>IBM PIX Server</pixServerPropertiesId>
<pixSourcePropertiesId>IBM PIX Server</pixSourcePropertiesId>
<pixConsumerPropertiesId>IBMPIXPDQClient</pixConsumerPropertiesId >
<pdqServerPropertiesId>IBM PIX Server</pdqServerPropertiesId>
<pdqConsumerPropertiesId>IBMPIXPDQClient</pdqConsumerPropertiesId >
<defaultMessageQueryNameId>IHEDEMO</defaultMessageQueryNameId >
</pix>
Any ideas? Is the bridge even supposed to do PIX queries or just PDQ?
thanks,
Jesse
Re: OHF Bridge Mesa test 10501 [message #34204 is a reply to message #34065] Mon, 08 October 2007 08:44 Go to previous messageGo to next message
Hi Jesse,
One note I want to add is that the bridge has mesa test junits you can
reference under project org.eclipse.ohf.bridge.ws. This can provide some
guidance.
The distinction to do pix vs pdq is based on a flag in the bridge,
method "setWithoutDemographics". If this flag is set to true, it will
perform a pix query. If this flag is set to false, it will perform a pdq
query. The default is false and I suspect this is your problem.
Sondra
Jesse Pangburn wrote:
> I'm getting an error. It appears to be trying to do a PDQ query instead
> of a PIX query, though I'm pretty new to IHE so that may be a
> misunderstanding on my part.
> <SOAP-ENV:Envelope
> <SOAP-ENV:Body>
> <tns1:patientInfo>
> <impl:item>
> <tns2:data/>
> <tns2:path/>
> </impl:item>
> <tns2:city/>
> <tns2:country/>
> <tns2:patientName>
> <tns2:familyName/>
> <tns2:givenName/>
> <tns2:otherName/>
> <tns2:prefix/>
> <tns2:suffix/>
> </tns2:patientName>
> <tns2:patientSex/>
> </tns1:patientInfo>
> <impl:item>
> </impl:item>
> </SOAP-ENV:Body>
> I get back:
> <soapenv:Envelope
> <soapenv:Body>
> <ns1:failMessage
> xmlns:ns1="http://type.bridge.ohf.eclipse.org"> Error location:
> QPD^1^3^1^4^ Error code: 204 Error severity: Warning</ns1:failMessage>
> <ns3:sessionID
> <ns4:success
> <ns5:successMessage
> </soapenv:Body>
> </soapenv:Envelope>
> RCP|I|1^RD
> (the one running the mesa server):
> <pix>
> <id>mesa</id>
> <mllp>
> </mllp>
> </pix>
> thanks,
> Jesse
Re: OHF Bridge Mesa test 10501 [message #34371 is a reply to message #34204] Mon, 08 October 2007 15:27 Go to previous messageGo to next message
Hi Sondra,
Ah, I didn't really know what that parameter was for. I assumed it meant
whether I wanted the results returned with or without demographics
information- so I set it to false to indicate I wanted demographics
information :-) Now I understand its use.
So I set it to true and tested and got an error in the bridge:
[DEBUG][12:14:44][on.hl7v2.message.PixPdqMessage] PixPdqMessage:
changeDefaultRecievingFacility
[DEBUG][12:14:44][on.hl7v2.message.PixPdqMessage] PixMsgADT: setField
QPD-3-5 :
QPD-3
[ERROR][12:14:44][clipse.ohf.bridge.ws.OHFBridge] failed at SearchPatient
org.eclipse.ohf.ihe.common.hl7v2.message.PixPdqMessage.setFi eld(PixPd
qMessage.java:385)
org.eclipse.ohf.bridge.ihe.pixpdq.IhePatientConsumerBridge.c reatePixC
onsumerQuery(IhePatientConsumerBridge.java:184)
I saw a similar problem regarding setting "QPD-3-5" when reading over the
more recent posts on this newsgroup last week. I just reread and see that
you and Graham fixed it. The last time I tried pulling the source trunk,
I couldn't get it to compile. I ended up pulling the branch/tag
"OHF_IHE_POST_2007EUCTHON" which was a lot easier to get running. So, the
fix you guys made, is it in the trunk or is there a branch you're working
on?
thanks,
Jesse
Sondra Renly wrote:
> Hi Jesse,
> guidance.
> Sondra
>> <SOAP-ENV:Envelope
>> <SOAP-ENV:Body>
>> <tns1:patientInfo>
>> <impl:item>
>> <tns2:data/>
>> <tns2:path/>
>> </impl:item>
>> <tns2:city/>
>> <tns2:country/>
>> <tns2:patientName>
>> <tns2:familyName/>
>> <tns2:givenName/>
>> <tns2:otherName/>
>> <tns2:prefix/>
>> <tns2:suffix/>
>> </tns2:patientName>
>> <tns2:patientSex/>
>> </tns1:patientInfo>
>> <impl:item>
>> </impl:item>
>> </SOAP-ENV:Body>
>> I get back:
>> <soapenv:Envelope
>> <soapenv:Body>
>> <ns1:failMessage
>> <ns3:sessionID
>> <ns4:success
>> <ns5:successMessage
>> </soapenv:Body>
>> </soapenv:Envelope>
MSH|^~&|XDSDEMO_ADT|XDSDEMO|XDSDEMO_ADT|XDSDEMO|20071005 133800-0700||QBP^Q22^QBP_Q21|0886784820993939999|P|2.5
>> RCP|I|1^RD
MSH|^~&|XDSDEMO_ADT|XDSDEMO|XDSDEMO_ADT|XDSDEMO|||RSP^K2 3|MESA4706a0c4|P|2.5||||||||
>> <pix>
>> <id>mesa</id>
>> <mllp>
>> </mllp>
>> </pix>
>> thanks,
>> Jesse
Re: OHF Bridge Mesa test 10501 [message #34405 is a reply to message #34371] Mon, 08 October 2007 15:40 Go to previous messageGo to next message
The update was made in trunk -
Update Segment.java from current which is the real fix is in Grahame's
HL7v2 code. The posted change in PixConsumerQuery is a temp workaround.
Sondra
> Hi Sondra,
> meant whether I wanted the results returned with or without demographics
> QPD-3-5 :
> QPD-3
> java.lang.NullPointerException
> at
> qMessage.java:385)
> at
> the more recent posts on this newsgroup last week. I just reread and
> see that you and Graham fixed it. The last time I tried pulling the
> source trunk, I couldn't get it to compile. I ended up pulling the
> branch/tag "OHF_IHE_POST_2007EUCTHON" which was a lot easier to get
> running. So, the fix you guys made, is it in the trunk or is there a
> branch you're working on?
> thanks,
> Jesse
> Sondra Renly wrote:
>> Hi Jesse,
>> some guidance.
>> pdq query. The default is false and I suspect this is your problem.
>> Sondra
>>> Hi,
>>> but I'm getting an error. It appears to be trying to do a PDQ query
>>> instead of a PIX query, though I'm pretty new to IHE so that may be a
>>> <SOAP-ENV:Envelope
>>> <SOAP-ENV:Body>
>>> <tns1:patientInfo>
>>> <impl:item>
>>> <tns2:data/>
>>> <tns2:path/>
>>> </impl:item>
>>> <tns2:city/>
>>> <tns2:country/>
>>> <tns2:patientName>
>>> <tns2:familyName/>
>>> <tns2:givenName/>
>>> <tns2:otherName/>
>>> <tns2:prefix/>
>>> <tns2:suffix/>
>>> </tns2:patientName>
>>> <tns2:patientSex/>
>>> </tns1:patientInfo>
>>> <impl:item>
>>> </impl:item>
>>> </SOAP-ENV:Body>
>>> I get back:
>>> <soapenv:Envelope
>>> <soapenv:Body>
>>> <ns1:failMessage
>>> <ns2:log
>>> <ns3:sessionID
>>> <ns4:success
>>> <ns5:successMessage
>>> </soapenv:Body>
>>> </soapenv:Envelope>
>>> RCP|I|1^RD
>>> successfully test against the IBM PIX Manager except the url is to a
>>> local machine (the one running the mesa server):
>>> <pix>
>>> <id>mesa</id>
>>> <mllp>
>>> </mllp>
>>> </pix>
>>> thanks,
>>> Jesse
Re: OHF Bridge Mesa test 10501 [message #34439 is a reply to message #34405] Mon, 08 October 2007 16:59 Go to previous message
Hi Sondra,
Great, I updated that file, recompiled and now test 10501 is working for
me. Thanks a lot!
BTW, is there a way to tell in buzilla which files were changed? I looked
at the bug referenced and did not see any reference to the files- I've
never really used bugzilla so maybe I'm missing something obvious. I
guessed that file was probably it when I was checking around in CVS, but
wasn't sure until I saw your post since there was no comment in CVS and
the change was slightly different than Graham's buzilla comment.
thanks again,
Jesse
> Sondra
>> Hi Sondra,
>> QPD-3-5 :
>> QPD-3
>> at
>> qMessage.java:385)
>> at
>> thanks,
>> Jesse
>> Sondra Renly wrote:
>>> Hi Jesse,
>>> some guidance.
>>> Sondra
>>>> Hi,
>>>> <SOAP-ENV:Envelope
>>>> <SOAP-ENV:Body>
>>>> <tns1:patientInfo>
>>>> <impl:item>
>>>> <tns2:data/>
>>>> <tns2:path/>
>>>> </impl:item>
>>>> <tns2:city/>
>>>> <tns2:country/>
>>>> <tns2:patientName>
>>>> <tns2:familyName/>
>>>> <tns2:givenName/>
>>>> <tns2:otherName/>
>>>> <tns2:prefix/>
>>>> <tns2:suffix/>
>>>> </tns2:patientName>
>>>> <tns2:patientSex/>
>>>> </tns1:patientInfo>
>>>> <impl:item>
>>>> </impl:item>
>>>> </SOAP-ENV:Body>
>>>> I get back:
>>>> <soapenv:Envelope
>>>> <soapenv:Body>
>>>> <ns1:failMessage
>>>> <ns2:log
>>>> <ns3:sessionID
>>>> <ns4:success
>>>> <ns5:successMessage
>>>> </soapenv:Body>
>>>> </soapenv:Envelope>
>>>> RCP|I|1^RD
>>>> <pix>
>>>> <id>mesa</id>
>>>> <mllp>
>>>> </mllp>
>>>> </pix>
>>>> thanks,
>>>> Jesse
Re: OHF Bridge Mesa test 10501 [message #581670 is a reply to message #34065] Mon, 08 October 2007 08:44 Go to previous message
Hi Jesse,
guidance.
Sondra
> <SOAP-ENV:Envelope
> <SOAP-ENV:Body>
> <tns1:patientInfo>
> <impl:item>
> <tns2:data/>
> <tns2:path/>
> </impl:item>
> <tns2:city/>
> <tns2:country/>
> <tns2:patientName>
> <tns2:familyName/>
> <tns2:givenName/>
> <tns2:otherName/>
> <tns2:prefix/>
> <tns2:suffix/>
> </tns2:patientName>
> <tns2:patientSex/>
> </tns1:patientInfo>
> <impl:item>
> </impl:item>
> </SOAP-ENV:Body>
> I get back:
> <soapenv:Envelope
> <soapenv:Body>
> <ns1:failMessage
> <ns3:sessionID
> <ns4:success
> <ns5:successMessage
> </soapenv:Body>
> </soapenv:Envelope>
> RCP|I|1^RD
> <pix>
> <id>mesa</id>
> <mllp>
> </mllp>
> </pix>
> thanks,
> Jesse
Re: OHF Bridge Mesa test 10501 [message #581749 is a reply to message #34204] Mon, 08 October 2007 15:27 Go to previous message
Hi Sondra,
QPD-3-5 :
QPD-3
qMessage.java:385)
on?
thanks,
Jesse
Sondra Renly wrote:
> Hi Jesse,
> guidance.
> Sondra
>> <SOAP-ENV:Envelope
>> <SOAP-ENV:Body>
>> <tns1:patientInfo>
>> <impl:item>
>> <tns2:data/>
>> <tns2:path/>
>> </impl:item>
>> <tns2:city/>
>> <tns2:country/>
>> <tns2:patientName>
>> <tns2:familyName/>
>> <tns2:givenName/>
>> <tns2:otherName/>
>> <tns2:prefix/>
>> <tns2:suffix/>
>> </tns2:patientName>
>> <tns2:patientSex/>
>> </tns1:patientInfo>
>> <impl:item>
>> </impl:item>
>> </SOAP-ENV:Body>
>> I get back:
>> <soapenv:Envelope
>> <soapenv:Body>
>> <ns1:failMessage
>> <ns3:sessionID
>> <ns4:success
>> <ns5:successMessage
>> </soapenv:Body>
>> </soapenv:Envelope>
>> RCP|I|1^RD
>> <pix>
>> <id>mesa</id>
>> <mllp>
>> </mllp>
>> </pix>
>> thanks,
>> Jesse
Re: OHF Bridge Mesa test 10501 [message #581759 is a reply to message #34371] Mon, 08 October 2007 15:40 Go to previous message
Sondra
> Hi Sondra,
> QPD-3-5 :
> QPD-3
> at
> qMessage.java:385)
> at
> thanks,
> Jesse
> Sondra Renly wrote:
>> Hi Jesse,
>> some guidance.
>> Sondra
>>> Hi,
>>> <SOAP-ENV:Envelope
>>> <SOAP-ENV:Body>
>>> <tns1:patientInfo>
>>> <impl:item>
>>> <tns2:data/>
>>> <tns2:path/>
>>> </impl:item>
>>> <tns2:city/>
>>> <tns2:country/>
>>> <tns2:patientName>
>>> <tns2:familyName/>
>>> <tns2:givenName/>
>>> <tns2:otherName/>
>>> <tns2:prefix/>
>>> <tns2:suffix/>
>>> </tns2:patientName>
>>> <tns2:patientSex/>
>>> </tns1:patientInfo>
>>> <impl:item>
>>> </impl:item>
>>> </SOAP-ENV:Body>
>>> I get back:
>>> <soapenv:Envelope
>>> <soapenv:Body>
>>> <ns1:failMessage
>>> <ns2:log
>>> <ns3:sessionID
>>> <ns4:success
>>> <ns5:successMessage
>>> </soapenv:Body>
>>> </soapenv:Envelope>
>>> RCP|I|1^RD
>>> <pix>
>>> <id>mesa</id>
>>> <mllp>
>>> </mllp>
>>> </pix>
>>> thanks,
>>> Jesse
Re: OHF Bridge Mesa test 10501 [message #581774 is a reply to message #34405] Mon, 08 October 2007 16:59 Go to previous message
Hi Sondra,
me. Thanks a lot!
thanks again,
Jesse
> Sondra
>> Hi Sondra,
>> QPD-3-5 :
>> QPD-3
>> at
>> qMessage.java:385)
>> at
>> thanks,
>> Jesse
>> Sondra Renly wrote:
>>> Hi Jesse,
>>> some guidance.
>>> Sondra
>>>> Hi,
>>>> <SOAP-ENV:Envelope
>>>> <SOAP-ENV:Body>
>>>> <tns1:patientInfo>
>>>> <impl:item>
>>>> <tns2:data/>
>>>> <tns2:path/>
>>>> </impl:item>
>>>> <tns2:city/>
>>>> <tns2:country/>
>>>> <tns2:patientName>
>>>> <tns2:familyName/>
>>>> <tns2:givenName/>
>>>> <tns2:otherName/>
>>>> <tns2:prefix/>
>>>> <tns2:suffix/>
>>>> </tns2:patientName>
>>>> <tns2:patientSex/>
>>>> </tns1:patientInfo>
>>>> <impl:item>
>>>> </impl:item>
>>>> </SOAP-ENV:Body>
>>>> I get back:
>>>> <soapenv:Envelope
>>>> <soapenv:Body>
>>>> <ns1:failMessage
>>>> <ns2:log
>>>> <ns3:sessionID
>>>> <ns4:success
>>>> <ns5:successMessage
>>>> </soapenv:Body>
>>>> </soapenv:Envelope>
>>>> RCP|I|1^RD
>>>> <pix>
>>>> <id>mesa</id>
>>>> <mllp>
>>>> </mllp>
>>>> </pix>
>>>> thanks,
>>>> Jesse
Previous Topic:OHF Bridge Mesa test 10501
Next Topic:PatientInfoType problem- patientSuffixName
Current Time: Sun Aug 31 16:16:52 EDT 2025
Powered by FUDForum. Page generated in 0.04779 seconds
