Home » Archived » BIRT » Using Stored-Procedures in BIRT
Using Stored-Procedures in BIRT [message #34061] Wed, 04 May 2005 01:14 Go to next message
Can BIRT handle stored-procedure?...Does it support MySQL 5.0?...
thanks,
wins
Re: Using Stored-Procedures in BIRT [message #34779 is a reply to message #34061] Thu, 05 May 2005 17:58 Go to previous message
Support for Stored Procedures in limited in release 1.0 of BIRT. You can
create a JDBC Select data set and type in a stored procedure call as the
query text. However, output parameters are not supported. Only a single
result set from a stored procedure call is accessible in BIRT reports.
BIRT can access any JDBC data source. You do need to supply your own JDBC
driver for the database. See the BIRT Download & Install instructions page
on how to set up JDBC drivers. At the time being we do not supply a list
of BIRT certified database platforms. If you have problem connecting to a
particular database, please feel free to file a Bugzilla report.
Gary Xue
BIRT Data Engine Team
Previous Topic:press inquiry - BIRT user testimonial
Next Topic:Problems Opening Editor after Upgrade from M3
Current Time: Wed Jul 30 18:14:08 EDT 2025
Powered by FUDForum. Page generated in 0.29860 seconds
