Home » Eclipse Projects » GEF » Unwanted selection events in MultiPageEditor
Unwanted selection events in MultiPageEditor [message #34054] Mon, 21 October 2002 13:29 Go to next message
Originally posted by: zacw.acaciatel.com
I'm having a problem with my MultipageEditor relating to extraneous
selection events. I have a MultiPageEditor with each page displaying a
subset of the entire model (so all viewers share the same model) and all
viewers sharing a single pallette.
The problem I'm having is this:
whenever I select an editpart on GraphicalViewer #X, it is correctly
selected (visibly) but the RootEditPart of the the original
viewer(GraphicalViewer #0) ALSO registers a selectrequest and fires.
I wonder if I'm not disconnecting something that I should be when a new
sub-page of the editor is selected...
Right now I have a lousy workaround where I check to see if the source of
the selectEvent was generated by the currently selected GraphicalViewer and
ignore the event if it wasn't. Optimally I'd like to avoid the overhead of
having multiple unwanted events firing.
Any help is appreciated and I'll provide more detail if you need it.
Zac
Re: Unwanted selection events in MultiPageEditor [message #34158 is a reply to message #34054] Mon, 21 October 2002 13:44 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Are you using a SelectionSynchronizer?
"Zac Wolfe" <zacw@acaciatel.com> wrote in message
news:ap1bgm$3fm$1@rogue.oti.com...
and
of
> Zac
Re: Unwanted selection events in MultiPageEditor [message #34221 is a reply to message #34158] Mon, 21 October 2002 14:17 Go to previous message
I am-- but probably incorrectly.
More on my situation:
Each of my sub-editors in the MultiPageEditorPart is equipped with 2
graphical viewers, both of which observe the same subset of the same model
(just observing different things). Should each of these sub-editors have a
single SelectionSynchronizer for it's 2 graphicalViewers, outlineveiwers,
etc. ? Or, should there be a single SelectionSynchronizer for the entire
MultiPageEditorPart since all the viewers are observing portions of the same
parent model?
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:ap1crq$4fi$1@rogue.oti.com...
of
> and
> of
> > Thanks,
> > Zac
Previous Topic:need some help, new to gef
Next Topic:Create a "Separator Figure" in the graphic Editor/figure
Current Time: Sun Aug 31 05:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.04562 seconds
