Re: A handler conflict occurred. This may disable some commands. [message #335452] |
Wed, 08 April 2009 21:51  |
You have two handlers for the paste command and the framework can't
figure out which one has priority. Most likely you need to make one of
them activate under more specific conditions.
You can turn on tracing support in your launch configuration to see more
information in the Console window.
http://www.developer.com/java/ent/article.php/3702056
The org.eclipse.ui plugin has trace flags for handlers.
This question belongs on the eclipse.platform newsgroup, copying the
response there.
-Ben
mowry wrote:
> I am using command framework to enable/disable commands.
> I am seeing the follwoing exception in the client log. Can you please
> help me to remove this error?
> Conflict for 'org.eclipse.ui.edit.paste':
> Thanks
Re: A handler conflict occurred. This may disable some commands. [message #335557 is a reply to message #335469] |
Tue, 14 April 2009 14:54   |
I'm not an expert on handlers but from the trace it looks as though you
have defined two handlers with the same id, if you change the id of one
of them I would expect the conflict to go away.
mowry wrote:
> Thanks for your response. I am using different conditions for two
> different handlers. Functionality works fine, but I see warning in the
> logs.
> Can you please correct me if I am doing any wrong?
> Here is how I am using handlers.
> 1. Activate com.ui.test1.actions.OpenAction when object is insatnceof
> BaseItem and Item1.
> <handler class="com.ui.test1.actions.OpenAction"
> commandId="com.ui.open">
> <activeWhen>
> <iterate>
> <and>
> <instanceof
> value="BaseItem">
> </instanceof>
> <instanceof
> value="Item1">
> </instanceof>
> </and>
> </iterate>
> </activeWhen>
> </handler>
> 2. Activate com.ui.test2.actions.OpenAction when object is insatnce of
> BaseItem and Item2.
> <handler class="com.ui.test2.actions.OpenAction" commandId="com.ui.open">
> <activeWhen>
> <iterate>
> <and>
> <instanceof
> value="BaseItem">
> </instanceof>
> <instanceof
> value="Item2">
> </instanceof>
> </and>
> </iterate>
> </activeWhen>
> </handler>
> This is the message in the logs:
> !MESSAGE Conflict for 'com.ui.open':
> HandlerActivation(commandId=com.ui.open,
> handler=com.ui.test1.actions.OpenAction,
> expression=org.eclipse.core.internal.expressions.IterateExpression@d63a0e3c,sourcePriority=1073741824)
> handler=com.ui.test2.actions.OpenAction,
> expression=org.eclipse.core.internal.expressions.IterateExpression@395d27b6,sourcePriority=1073741824)
> Thanks
> Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335969 is a reply to message #335688] |
Tue, 12 May 2009 00:15  |
Originally posted by: eclipsenews.cs-guy.com
In case you never resolved this issue, I think I can help.
I encountered the same warning in Eclipse 3.4.1 when I had a very similar
set of handlers defined. After a little experimentation I was able to get
the warning to go away by adding an extra condition to made the conditions
more explicit.
In my case I had a structure like this:
<handler class="Handler1" commandId="command">
<activeWhen>
<iterate operator="and">
<instanceof value="class1">
</instanceof>
</iterate>
</activeWhen>
</handler>
<handler class="Handler2" commandId="command">
<activeWhen>
<instanceof value="class2">
</instanceof>
</iterate>
</activeWhen>
</handler>
Which gave me the warning about a handler conflict (even though it all
worked fine in my application).
To get rid of the warning I changed my handler definitions to look like
this:
<activeWhen>
<with variable="selection">
</instanceof>
</iterate>
<count value="+">
</count>
</with>
</activeWhen>
</handler>
<activeWhen>
</instanceof>
</iterate>
<count value="+">
</count>
</with>
</activeWhen>
</handler>
Hope that helps,
Chris
"mowry " <mowry_889@yahoo.com> wrote in message
news:1a07b231744e6898d25e707d8f4b8808$1@www.eclipse.org...
> Yes it works fine though it logs with those errors/warnings.
> I am using eclipse Version: 3.3.1.1
> Build id: M20071023-1652
> Are there any know issues with this release?
> I will open a defect with details.
> Mowry
FUDForum. Page generated in 0.05428 seconds
