Home » Eclipse Projects » Eclipse Platform » Re: A handler conflict occurred. This may disable some commands.
Re: A handler conflict occurred. This may disable some commands. [message #335452] Wed, 08 April 2009 21:51 Go to next message
You have two handlers for the paste command and the framework can't
figure out which one has priority. Most likely you need to make one of
them activate under more specific conditions.
You can turn on tracing support in your launch configuration to see more
information in the Console window.
http://www.developer.com/java/ent/article.php/3702056
The org.eclipse.ui plugin has trace flags for handlers.
This question belongs on the eclipse.platform newsgroup, copying the
response there.
-Ben
mowry wrote:
> I am using command framework to enable/disable commands.
> I am seeing the follwoing exception in the client log. Can you please
> help me to remove this error?
> Conflict for 'org.eclipse.ui.edit.paste':
> Thanks
Re: A handler conflict occurred. This may disable some commands. [message #335469 is a reply to message #335452] Thu, 09 April 2009 14:22 Go to previous messageGo to next message
Thanks for your response. I am using different conditions for two
different handlers. Functionality works fine, but I see warning in the
logs.
Can you please correct me if I am doing any wrong?
Here is how I am using handlers.
1. Activate com.ui.test1.actions.OpenAction when object is insatnceof
BaseItem and Item1.
<handler class="com.ui.test1.actions.OpenAction"
commandId="com.ui.open">
<activeWhen>
<iterate>
<and>
<instanceof
value="BaseItem">
</instanceof>
<instanceof
value="Item1">
</instanceof>
</and>
</iterate>
</activeWhen>
</handler>
2. Activate com.ui.test2.actions.OpenAction when object is insatnce of
BaseItem and Item2.
<handler class="com.ui.test2.actions.OpenAction" commandId="com.ui.open">
<activeWhen>
<iterate>
<and>
<instanceof
value="BaseItem">
</instanceof>
<instanceof
value="Item2">
</instanceof>
</and>
</iterate>
</activeWhen>
</handler>
This is the message in the logs:
!MESSAGE Conflict for 'com.ui.open':
HandlerActivation(commandId=com.ui.open,
handler=com.ui.test1.actions.OpenAction,
expression=org.eclipse.core.internal.expressions.IterateExpression@d63a0e3c,sourcePriority=1073741824)
handler=com.ui.test2.actions.OpenAction,
expression=org.eclipse.core.internal.expressions.IterateExpression@395d27b6,sourcePriority=1073741824)
Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335534 is a reply to message #335469] Mon, 13 April 2009 16:46 Go to previous messageGo to next message
Any help on this please?
Mowry
Any Help please ! A handler conflict occurred. This may disable some commands. [message #335556 is a reply to message #335534] Tue, 14 April 2009 14:08 Go to previous messageGo to next message
Can somebody help on this issue please?
Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335557 is a reply to message #335469] Tue, 14 April 2009 14:54 Go to previous messageGo to next message
I'm not an expert on handlers but from the trace it looks as though you
have defined two handlers with the same id, if you change the id of one
of them I would expect the conflict to go away.
mowry wrote:
> logs.
> BaseItem and Item1.
> <activeWhen>
> <iterate>
> <and>
> <instanceof
> value="BaseItem">
> </instanceof>
> <instanceof
> value="Item1">
> </instanceof>
> </and>
> </iterate>
> </activeWhen>
> </handler>
> BaseItem and Item2.
> <activeWhen>
> <iterate>
> <and>
> <instanceof
> value="BaseItem">
> </instanceof>
> <instanceof
> value="Item2">
> </instanceof>
> </and>
> </iterate>
> </activeWhen>
> </handler>
> Thanks
> Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335558 is a reply to message #335557] Tue, 14 April 2009 15:54 Go to previous messageGo to next message
Thanks for your reply Chris.
We need to use same commandID. This is simiar to using
org.eclipse.ui.edit.copy.
Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335565 is a reply to message #335469] Wed, 15 April 2009 08:56 Go to previous messageGo to next message
You can use
http://wiki.eclipse.org/Platform_Command_Framework#Tracing_O ption to see
what's going on. Set org.eclipse.ui/trace/handlers.verbose.commandId to
your command id.
PW
Paul Webster
Re: A handler conflict occurred. This may disable some commands. [message #335642 is a reply to message #335565] Fri, 17 April 2009 11:57 Go to previous messageGo to next message
I tested with tracing option, but I didn't find any answers.
Here is the log:
HANDLERS >>> Command('com.ui.open') has changed to
'com.ui.test1.actions.OpenAction' as its handler
HANDLERS >>> resolveConflicts: eval:
expression=org.eclipse.core.internal.expressions.IterateExpression@9b3cba68,sourcePriority=1073741824)
expression=org.eclipse.core.internal.expressions.IterateExpression@39a07667,sourcePriority=1073741824)
HANDLERS >>> Unresolved conflict detected for 'com.ui.open'
HANDLERS >>> Command('com.ui.open') has changed to no handler
Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335670 is a reply to message #335642] Mon, 20 April 2009 12:59 Go to previous messageGo to next message
Maybe it has a transient state that is complaining about the conflict
before settling down and picking one (you said it actually works).
I would try opening a bug with as much info as you have:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
Also include what version you are running on, and the usecase the
reproduces the problem.
PW
Paul Webster
Re: A handler conflict occurred. This may disable some commands. [message #335688 is a reply to message #335670] Tue, 21 April 2009 16:28 Go to previous messageGo to next message
Yes it works fine though it logs with those errors/warnings.
I am using eclipse
Version: 3.3.1.1
Build id: M20071023-1652
Are there any know issues with this release?
I will open a defect with details.
Mowry
Re: A handler conflict occurred. This may disable some commands. [message #335969 is a reply to message #335688] Tue, 12 May 2009 00:15 Go to previous message
Originally posted by: eclipsenews.cs-guy.com
In case you never resolved this issue, I think I can help.
I encountered the same warning in Eclipse 3.4.1 when I had a very similar
set of handlers defined. After a little experimentation I was able to get
the warning to go away by adding an extra condition to made the conditions
more explicit.
In my case I had a structure like this:
<handler class="Handler1" commandId="command">
<activeWhen>
<iterate operator="and">
<instanceof value="class1">
</instanceof>
</iterate>
</activeWhen>
</handler>
<handler class="Handler2" commandId="command">
<activeWhen>
<instanceof value="class2">
</instanceof>
</iterate>
</activeWhen>
</handler>
Which gave me the warning about a handler conflict (even though it all
worked fine in my application).
To get rid of the warning I changed my handler definitions to look like
this:
<activeWhen>
<with variable="selection">
</instanceof>
</iterate>
<count value="+">
</count>
</with>
</activeWhen>
</handler>
<activeWhen>
</instanceof>
</iterate>
<count value="+">
</count>
</with>
</activeWhen>
</handler>
Hope that helps,
Chris
"mowry " <mowry_889@yahoo.com> wrote in message
news:1a07b231744e6898d25e707d8f4b8808$1@www.eclipse.org...
> I am using eclipse Version: 3.3.1.1
> Mowry
Previous Topic:Lost PDE resources
Next Topic:JUnit Test Case class Generator
Current Time: Tue Jul 22 02:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.06094 seconds
