Home » Eclipse Projects » Eclipse Platform » Problem with Navigator
Problem with Navigator [message #335435] Wed, 08 April 2009 07:36 Go to next message
I've got a problem in my navigator. I'd like to make the Undo action work
even if I don't have an element selected but the Navigator Action Service is
prepared to work only when something is selected. I've thought of
subclassing NavigatorActionService but I don't know which extension point I
can use to specify that I prefer to use my subclass rather than
NavigatorActionService. Does anyone know which extension point allow me to
do that? ...or any other solution to my problem??
Thanks in advance
Mario
Re: Problem with Navigator [message #335749 is a reply to message #335435] Sun, 26 April 2009 23:39 Go to previous message
Originally posted by: francis.oaklandsoftware.com
Instead of using the CNF actionProviders, I would consider the use of
commands instead. They are easier to use and give you much more
flexibility.
This will get you started:
http://help.eclipse.org/stable/topic/org.eclipse.platform.do c.isv/guide/workbench_cmd.htm
You can simply add your command to the popup menu associated with your
navigator under whatever conditions you like.
I think you can use the UndoActionHandler to actually run the undo.
HTH,
Francis
On Wed, 08 Apr 2009 04:36:20 -0700, Mario Cervera <mcervera@prodevelop.es>
wrote:
> Service is
> point I
> to
> Thanks in advance
> Mario
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:Querying for plugin location
Next Topic:Function to insert oder update @date in javadoc
Current Time: Fri Jul 25 00:45:40 EDT 2025
Powered by FUDForum. Page generated in 0.04241 seconds
