Home » Eclipse Projects » Eclipse Platform » Quick Fix Handler enabled when there are not resolutions
Quick Fix Handler enabled when there are not resolutions [message #335422] Tue, 07 April 2009 13:12 Go to next message
There is a strange behavior on the QuickFixHandler.
When I lunch my eclipse-based application, the ProblemsView is
displayed. I right-click on an Error and the QuickFix entry is enabled.I
decide to run the action... No resolutions found!. Ok it is normal I did
not implement any. I right-click again the QuickFix Handler is not
enabled any more.
I lunch again my eclipse-based application, but this time I play with
the application a little bit before right-clicking on an Error from the
Problems View. This time the Handler is not enabled.
While debuggin I found on the MarkerHelpRegistry class a method called:
hasResolution(IMarker marker, IConfigurationElement element)
which collects resolutions only if the plugin declaring the resolution
generator is active. Otherwise we assume the will be generators
procudinc resolutions for the marker.
Ok, ok, it is can be considered as a detail instead of a problem. But
here some users of my eclipse-base application don't like this behavior.
And I'm wondering why does the plugin need to be loaded to know if the
marker has resolutions?
I mean, why the plugin activation is not allowed when the
hasResolution is called?
Anyway, the plugin will be activated when we execute the QuickFixHandler.
And the big question is.... Is this a bug?
Jose Alfredo S.
Re: Quick Fix Handler enabled when there are not resolutions [message #335426 is a reply to message #335422] Tue, 07 April 2009 20:05 Go to previous messageGo to next message
I don't think so. Eclipse tries to lazy load the plugin as much as
possible. That is one main reason, why Eclipse scales well with thousands of
plugins without any performance issues.
> Ok, ok, it is can be considered as a detail instead of a problem. But here
(If you really need to) you can programatically activate the plugin with
the QuickFixHandler to make your clients happy
- Prakash
http://blog.eclipse-tips.com
Re: Quick Fix Handler enabled when there are not resolutions [message #335431 is a reply to message #335426] Wed, 08 April 2009 04:08 Go to previous messageGo to next message
I know about the lazy load. Each plugin is activated when any class of
it is needed.
In my opinion, the lines:
if (Platform.getBundle(element.getNamespace()).getState() ==
Bundle.ACTIVE) {
// The element's plugin is loaded so we instantiate
// the resolution
} else {
// The element's plugin in not loaded so we assume
// the generator will produce resolutions for the marker
return true;
has nothing to do in the private method hasResolutions from the
MarkerHelperRegistry class
The question is:
Why do we have to test the activation of the plugin on the
hasResolutions method? I think it is better to let the plugin with the
ResolutionsGenerator to be activated.
That was the solution I implemented.
Jose Alfredo
Re: Quick Fix Handler enabled when there are not resolutions [message #335434 is a reply to message #335431] Wed, 08 April 2009 07:11 Go to previous messageGo to next message
of
> it is needed.
> Bundle.ACTIVE) {
> // the resolution
> } else {
> return true;
> The question is:
with
> Jose Alfredo
To elaborate further what Prakash said and to answer your question:
Imagine a number of plug-ins (or tools) contributing
IMarkerResolutionGenerator for their marker types (and maybe others as
well ).When you start eclipse and the problems view shows up, it will show
the markers that have been previously created by all the plug-ins
available in the eclipse installation, regardless of whether they have
been activated or not.
Now, loading up a plug-in and executing the generators code to check if
the quickfix is to be enabled or not will certainly cause the UI to stall
a bit. More importantly a good number of these plug-ins may not be used at
all in a given run. Loading them and bloating up the memory just for this
purpose seems wasteful.
Hitesh.
Re: Quick Fix Handler enabled when there are not resolutions [message #335441 is a reply to message #335434] Wed, 08 April 2009 09:51 Go to previous message
>>> as possible. That is one main reason, why Eclipse scales well with
>>> thousands
> of
>> it is needed.
>> Bundle.ACTIVE) {
>> // the resolution
>> } else {
>> return true;
>> The question is:
>>>> But here some users of my eclipse-base application don't like this
>>>> behavior.
> with
>> Jose Alfredo
> show the markers that have been previously created by all the plug-ins
> stall a bit. More importantly a good number of these plug-ins may not be
> used at all in a given run. Loading them and bloating up the memory just
> for this purpose seems wasteful.
> Hitesh.
It's ok for me. Thank you guys for your answers
Jose Alfredo
Previous Topic:nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6
Next Topic:refreshing commands based on workbench selection
Current Time: Mon Jul 21 22:20:06 EDT 2025
Powered by FUDForum. Page generated in 0.19564 seconds
