Home » Modeling » TMF (Xtext) » Difficulty with a grammar
Difficulty with a grammar [message #34045] Wed, 25 March 2009 18:40 Go to next message
I'm running into a bit of trouble trying to create my DSL. In my case, I'm
trying to express than a Directions type can contain a list of
InstructionGroup types OR a list of Section types. I have tried to
represent it like this:
Directions :
'Directions' ':'?
(instructionGroups+=InstructionGroup)+ |
(instructionGroupContents+=InstructionGroupContents)+;
InstructionGroup :
'InstructionGroup' id=ID ':'?
InstructionGroupContents :
((sections+=Section)+);
Section :
'Section' ':'?;
but I get this error from Antlr when I go to generate:
warning(200):
../com.knitml.kel.grammar/src-gen/com/knitml/parser/antlr/in ternal/InternalKel.g:438:1:
Decision can match input such as "'Section'" using multiple alternatives:
1, 2
As a result, alternative(s) 2 were disabled for that input
Is there a better way to express this in the grammar so that I don't get
this warning?
I'm using XText with Eclipse 3.5M6 (the package downloaded from Itemis's
website yesterday evening.)
Re: Difficulty with a grammar [message #34091 is a reply to message #34045] Wed, 25 March 2009 19:26 Go to previous messageGo to next message
Hi Jonathan,
great to see that Sven and Jan gained some attraction :)
Your Grammar
> InstructionGroup :
> Section :
> 'Section' ':'?;
Is ambiguous since the given input
InstructionGroup Foo :
Section S1
Section S2
Could either lead to
InstructionGroup (
InstructionContents (
Section
Section
or to
InstructionGroup (
Section
Section
It is best practice to start from a given sample and to derive the
needed grammar from this. If you could provide such a sample I would
be glad to assist you.
Heiko
Re: Difficulty with a grammar [message #34125 is a reply to message #34091] Wed, 25 March 2009 23:57 Go to previous messageGo to next message
Hi Heiko,
I'm trying (ultimately) to model this type of structure:
<Directions>
<InstructionGroup>
<Section/>
<Section/>
</InstructionGroup>
<InstructionGroup>
<Section/>
<Section/>
</InstructionGroup>
</Directions>
OR
<Directions>
<Section/>
<Section/>
<Section/>
<Section/>
</Directions>
That is to say, the higher-level InstructionGroup is completely optional,
depending on the specific pattern being created.
Re: Difficulty with a grammar [message #34159 is a reply to message #34045] Thu, 26 March 2009 02:57 Go to previous messageGo to next message
Hi Jonathan,
seems to me, that the type InstructionGroupContents is superflous in
your grammar. The parser does not know, if the a section belongs to the
same InstructionGroupContents instance (is a child of), or if a new
InstructionGroupContent has to be instantiated for the section, that was
found.
Consider the following input:
Directions :
InstructionGroup :
Section : <- igc = new InstructionGroupContents() ..
Section : <- belongs this one to igc or igc2?
I would either introduce a keyword for InstrGroupContents or ommit it at
all (I'ld prefer the latter):
Directions:
'Directions' ':'? instructionGroups+=InstructionGroup+
| contents+=Section+;
InstructionGroup:
'InstructionGroup' id=ID ':'? contents+=Section+;
Section
'Section' ':'?;
Hope that helps,
Sebastian
> I'm trying to express than a Directions type can contain a list of
> Directions :
> 'Directions' ':'?
> InstructionGroup :
> Section :
> 'Section' ':'?;
> warning(200):
> ./com.knitml.kel.grammar/src-gen/com/knitml/parser/antlr/int ernal/InternalKel.g:438:1:
> alternatives: 1, 2
> this warning?
Re: Difficulty with a grammar [message #34297 is a reply to message #34159] Thu, 26 March 2009 03:10 Go to previous messageGo to next message
Must have been to eager and missed Heikos post, who mentioned almost the
same ...
- Sebastian
Sebastian Zarnekow schrieb:
> Hi Jonathan,
> found.
> Directions :
> InstructionGroup :
> Directions:
> | contents+=Section+;
> InstructionGroup:
> Section
> 'Section' ':'?;
> Hope that helps,
> Sebastian
>> Directions :
>> 'Directions' ':'?
>> InstructionGroup :
>> Section :
>> 'Section' ':'?;
>> warning(200):
>> alternatives: 1, 2
>> get this warning?
>> Itemis's website yesterday evening.)
Re: Difficulty with a grammar [message #34365 is a reply to message #34125] Thu, 26 March 2009 05:08 Go to previous messageGo to next message
Hey Jonathan,
this structure of the model can be built up with an Xtext parser that uses a
grammar similar to yours. Have a look at Sebastians suggestion. This should work
quite well in your case. In particular, take a closer look at his rule
InstructionGroup where he calls Section directly.
If you cannot do it without InstructionGroupContents since you want to compose
and reuse further features as your work continues, omit the +multiplicity when
calling the InstructionGroupContents:
Directions :
'Directions' ':'?
(instructionGroups+=InstructionGroup+ |
instructionGroupContents=InstructionGroupContents);
InstructionGroup :
instructionGroupContents+=InstructionGroupContents;
sections+=Section+;
Section :
'Section' ':'?;
Does this solve your problem?
> Hi Heiko,
> <Directions>
> <InstructionGroup>
> <Section/>
> <Section/>
> </InstructionGroup>
> <InstructionGroup>
> <Section/>
> <Section/>
> </InstructionGroup>
> </Directions>
> OR
> <Directions>
> <Section/>
> <Section/>
> <Section/>
> <Section/>
> </Directions>
Re: Difficulty with a grammar [message #34467 is a reply to message #34159] Thu, 26 March 2009 11:51 Go to previous messageGo to next message
Sebastian Zarnekow wrote:
> Directions:
> | contents+=Section+;
> InstructionGroup:
> Section
> 'Section' ':'?;
So I tried this format. The generator no longer complains, but when I go
to test the grammar, the validation doesn't recognize:
Directions:
Section:
as a valid grammar. It's still trying to insist that I have an
InstructionGroup first.
Re: Difficulty with a grammar [message #34501 is a reply to message #34467] Thu, 26 March 2009 12:40 Go to previous messageGo to next message
Hi Jonathan,
the problem is, that Groups (lists of tokens, kind of invisible 'and'
operator) have a higher precedence than Alternatives (or operator).
You should use parenthesis around your alternative:
Directions:
'Directions' ':'? (
| contents+=Section+
InstructionGroup:
Section
'Section' ':'?;
Sebastian
>> Directions:
>> | contents+=Section+;
>> InstructionGroup:
>> Section
>> 'Section' ':'?;
> Directions:
> Section:
Re: Difficulty with a grammar [message #34600 is a reply to message #34501] Fri, 27 March 2009 00:40 Go to previous message
Ah, that works! Thanks!
I'm sure I'll have a lot more questions as I go through the rest of the
grammar.
Jonathan
Previous Topic:[TCS] source campatible with ATL 3.0
Next Topic:xtext interpreting examples
Current Time: Sun Aug 31 08:29:43 EDT 2025
Powered by FUDForum. Page generated in 0.10840 seconds
