Home » Eclipse Projects » Plugin Development Environment (PDE) » API Tooling Filter IDs Explained?
API Tooling Filter IDs Explained? [message #34042] Thu, 20 November 2008 13:50
Hey all,
Is the mapping of PI Tooling Filter IDs to their descriptions documented
anywhere? With detective work I've been able to reverse engineer some but it
would be much more convenient if I had a central place to look.
Here's my problem specifically with an example. Say I have this bit in a
..api_filters file:
<resource path="META-INF/MANIFEST.MF" type="org.acme.Foo">
<filter id="305324134">
<message_arguments>
<message_argument value="org.acme.Foo"/>
<message_argument value="org.acme_1.0.0/>
</message_arguments>
</filter>
</resource>
I'd like to be able to extract the message:
"The type org.acme.Foo has been removed ..."
I can see this when I go to the project properties but I'd like to do this
automatically (and headlessly) for documentation purposes.
Thanks in advance for any ideas!
-phil
Previous Topic:How to change plugin.xml programmatically?
Next Topic:API Tooling Filter IDs Explained?
Current Time: Sun Aug 31 08:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.03051 seconds
