Home » Eclipse Projects » Eclipse Platform » global action (registration) listener
global action (registration) listener [message #335321] Wed, 01 April 2009 06:45 Go to next message
i want to track every called action in an eclipse application. is it
possible to add a action listener on every action? Where is the best
point to look at? every hint could help me.
Greetings
Re: global action (registration) listener [message #335332 is a reply to message #335321] Wed, 01 April 2009 14:57 Go to previous message
Your best bet is to use the ICommandService and
org.eclipse.ui.commands.ICommandService.addExecutionListener (IExecutionListener)
This will notify about all commands executed (command contributions and
keybindings) as well as all actions that have set their
actionDefinitionId to a matching command.
There's no similar hook in the action system, although you could
probably hack something into a display filter on SWT.Selection (but even
that's only part of the story)
PW
Paul Webster
Previous Topic:Displsxing message of marker at caret position in status line
Next Topic:Commands and Context Menus
Current Time: Tue Nov 25 14:19:32 EST 2025
Powered by FUDForum. Page generated in 0.04212 seconds
