Home » Eclipse Projects » Eclipse Platform » Unit tests on eclipse application
Unit tests on eclipse application [message #335271] Mon, 30 March 2009 06:51 Go to next message
Originally posted by: zhengxie.ie.ibm.com
Can you please point me to some articles about unit testing an Eclipse
based application?
I have downloaded eclipse-Automated-Tests-3.4.zip, try to learn from it.
But all the tests to org.eclipse.ui package have no source code. Where
can I download the source?
Thanks.
Zheng
Re: Unit tests on eclipse application [message #335289 is a reply to message #335271] Mon, 30 March 2009 19:43 Go to previous message
The source should be available in CVS. For example, this may be the
project you are referring to:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.test
Here is more info:
http://wiki.eclipse.org/index.php/CVS_Howto
-Ben
> based application?
> Thanks.
> Zheng
Previous Topic:Releng to checkout SDK head and build it from sources?
Next Topic:Delete project takes long time
Current Time: Mon Jul 21 21:51:37 EDT 2025
Powered by FUDForum. Page generated in 0.28389 seconds
