Home » Eclipse Projects » Eclipse Platform » [menus] submenu in popup menu does not show up when manually populated
[menus] submenu in popup menu does not show up when manually populated [message #335245] Fri, 27 March 2009 11:39 Go to next message
Submenu in popup menus does not show up when (manually) populated through
the IMenuService and the popup menu is not registered through a view's
site, i.e. IViewSite.registerContextMenu().
Is this a bug or is this not supported?
Code:
//this does not populate submenu in popup menus
ContributionManager contributionManager = ...
menuService.populateContributionManager( contributionManager,
"popup:my.unique.popupMenu" )
//this works when registering popup menu in a view site
getSite().registerContextMenu( "my.unique.popupMenu", ... )
Re: [menus] submenu in popup menu does not show up when manually populated [message #335246 is a reply to message #335245] Fri, 27 March 2009 11:44 Go to previous messageGo to next message
In addition:
Only submenus do not work in popup menu. Commands (actions) are shown
properly.
Re: [menus] submenu in popup menu does not show up when manually populated [message #335306 is a reply to message #335245] Tue, 31 March 2009 12:07 Go to previous message
> through the IMenuService and the popup menu is not registered through a
> view's site, i.e. IViewSite.registerContextMenu().
> Code:
This should work fine ... which submenu is not showing up? Or do you
mean you are populating that ID but no popup.any contributions show up?
Does your MenuManager have removeAllWhenShown set to true?
Please give an example of the XML that is not showing up for you.
PW
Paul Webster
Previous Topic:Command API and Global actions
Next Topic:Why is C'tor of UIElement protected?
Current Time: Sun Aug 31 00:55:29 EDT 2025
Powered by FUDForum. Page generated in 0.03113 seconds
