Project clean event? [message #335244] |
Fri, 27 March 2009 11:15  |
Is there a way to capture when a project clean occurs *other* than adding
a builder? We don't "build" anything, but we do want to know when it
occurs, especially a clean.
A resource listener isn't quite enough, because if no resource changes,
then there is no post build event.
Re: Project clean event? [message #335251 is a reply to message #335249] |
Fri, 27 March 2009 14:02   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Then capture pre_build instead of post_build.
Paul Fullbright wrote:
> You mean the getBuildKind() query? If so, I do know about that, but the
> problem is that the POST_BUILD event will not be broadcast if there are
> no resource changes (if there is no resource delta). So this method of
> capturing that a clean has happened is not reliable. I would like to
> know *every* time a clean has been invoked, whether or not resources are
> changed as a result.
> Rich Kulp wrote:
>> There is a clean event in the resources listener.
>>> adding a builder? We don't "build" anything, but we do want to know
>>> when it occurs, especially a clean.
>>> changes, then there is no post build event.
Rich Kulp
Re: Project clean event? [message #335252 is a reply to message #335251] |
Fri, 27 March 2009 14:17   |
I didn't mention pre_build because we're more interested in doing
something after the build has been launched, but it does suffer from the
same problem as post_build. If there are no resource changes since the
last build, there is no event.
>> Rich Kulp wrote:
>>> Hi,
Re: Project clean event? [message #335253 is a reply to message #335252] |
Fri, 27 March 2009 14:51   |
I don't think that's true, or something has changed. I was the one that
requested the Clean notification to be put in several years ago. It's
purpose was to let me know a clean was requested so that I could delete
some files in metadata area. I received notifications no matter whether
any files had changed or been deleted or not.
>>> the problem is that the POST_BUILD event will not be broadcast if
>>> there are no resource changes (if there is no resource delta). So
>>> this method of capturing that a clean has happened is not reliable.
>>> I would like to know *every* time a clean has been invoked, whether
>>> or not resources are changed as a result.
>>> Rich Kulp wrote:
>>>> Hi,
>>>>> know when it occurs, especially a clean.
Rich Kulp
FUDForum. Page generated in 0.05992 seconds
