Home » Archived » Test and Performance Tools Platform (TPTP) » XMI file
XMI file [message #34030] Thu, 06 October 2005 10:51 Go to next message
Originally posted by: cleliacangiano.hotmail.com
Can I convert the trcaxmi file in another form?
Have you used these files?
I' ve read the contents of the file with KWrite, under Linux.
Thanks.
Re: XMI file [message #34096 is a reply to message #34030] Thu, 06 October 2005 12:18 Go to previous messageGo to next message
Hi Clelia,
By default the trcaxmi file is saved in ZIP-ed form, you could use unzip to
extract the ResourceContents zip entry which is in XMI (XML) form.
What kind of information do you need to extract from the trcaxmi file and in
which form do you need to export it?
There is work underway to export trcaxmi (especially Trace and Test models)
to an XML format that eventually would be used to feed a BIRT report.
Marius
"clelia" <cleliacangiano@hotmail.com> wrote in message
news:9461332eb915d1dd92e11afadcdd7955$1@www.eclipse.org...
> Thanks.
Re: XMI file [message #34595 is a reply to message #34096] Sun, 09 October 2005 17:58 Go to previous messageGo to next message
Yes, I'd obtain an xml (or xmi) file from trcpxmi.
How can I export my tptp's UML traces in an image file?
Clelia
Re: XMI file [message #34697 is a reply to message #34595] Mon, 10 October 2005 23:19 Go to previous message
Hi Cleila,
To print UML SD, please take a look at (you could use that function to print
to a postscript file):
/org.eclipse.hyades.ui/src/org/eclipse/hyades/uml2sd/interna l/reports/PrintS
DViewReportWizard.java
and also at "org.eclipse.hyades.ui.reportGenerators" extension point defined
in /org.eclipse.hyades.ui/plugin.xml.
Marius
"Clelia" <cleliacangiano@hotmail.com> wrote in message
news:07d0ea786f8a3b0f91beb4af3f3b82d0$1@www.eclipse.org...
> Thanks
> Clelia
Previous Topic:Agent Controller on Linux
Next Topic:TPTP 4.0.1 Release Available
Current Time: Sun Aug 31 19:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
