Home » Eclipse Projects » GEF » Saving my diagram in GEF
Saving my diagram in GEF [message #34026] |
Mon, 21 October 2002 12:00  |
Originally posted by: truenoto.yahoo.com
If I want to implement save in GEF, what should I save ? the Model? the
EditPart? or the Figure?
In the logic editor example, I think it just saves Model (since it
implements Serializable). But the connection anchors are stored in Figure
(the hashtable for all connection anchors), so that do not need to be saved
in general? or that does not need to be saved in Logic editor example only?
If I want to save my connections anchors, what should I do? make all my
figures Serializable? or making Model to stored all my connection anchors?
Thank you.
Re: Saving my diagram in GEF [message #34187 is a reply to message #34089] |
Mon, 21 October 2002 13:47   |
Thanks for your help.
On a related subject, should Model have a reference to EditPart? I know
EditParts has a reference to Model, but not the other around. Why is that?
Is this the GEF's model also?
If Model of my application need to get a hold of its EditPart, what should
I do? Did I break the MVC architecture? or I need to add the reference (from
model to editpart) manually?
Thanks.
"Zac Wolfe" <zacw@acaciatel.com> wrote in message
news:ap1cc2$44k$1@rogue.oti.com...
> Takumi,
> I believe you want to save the model and only the model since it should
> contain all the information you need. If you're storing connection-related
> information in the figure you probably shouldn't be if you want to follow
> GEF's MVC (model-view-controller) architecture. Connection anchor
> information should be generated or fixed but not stored. If your
connections
> aren't getting persisted, you need to look at your model and revisit how
> your connection data is represented in there.
> "Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
> news:ap16m4$hi$1@rogue.oti.com...
> > Hi,
Figure
> saved
> only?
anchors?
> > Thank you.
Re: Saving my diagram in GEF [message #34255 is a reply to message #34187] |
Mon, 21 October 2002 14:29   |
Originally posted by: zacw.acaciatel.com
I don't think your models should ever have references to their editparts.
This would indeed break the MVC architecture. EditParts must have reference
to their model since that's what they're observing but not the other way
around. There are many reasons for this but that gets into the whole MVC
philosophy discussion. If you want to illicit a property change upon an
editpart or a figure, you should change that object's model, not the object
itself. If you can't change the object the way you want to by altering the
model, you probably need to rework your design.
Zac
news:ap1d04$4i7$1@rogue.oti.com...
should
(from
> Thanks.
> > Takumi,
connection-related
follow
> connections
> > > Hi,
the
> Figure
> > saved
> > only?
my
> anchors?
> > > Thank you.
Re: Saving my diagram in GEF [message #34289 is a reply to message #34255] |
Mon, 21 October 2002 15:22   |
Thanks again.
How about Figure? Should EiditPart/Model have reference from/to Figure also?
Thank you.
news:ap1f1j$5us$1@rogue.oti.com...
reference
object
the
> Zac
that?
> should
> (from
> > Thanks.
> > > Takumi,
should
> connection-related
> follow
> > connections
how
> > > > Hi,
> the
> > Figure
be
> > > saved
example
> > > only?
> my
> > anchors?
> > > > Thank you.
Re: Saving my diagram in GEF [message #34358 is a reply to message #34289] |
Mon, 21 October 2002 17:40   |
The figure should not know about the EditPart or the model. The model should
not know about the EditPart or the figure. But the EditPart knows about its
model and its figure (as long as it implements GraphicalEditPart or subclasses
AbstractGraphicalEditPart).
Eric
Takumi Fujiwara wrote:
> Thanks again.
> Thank you.
> reference
> object
> the
>>Zac
> that?
>>should
>>(from
>>>Thanks.
>>>>Takumi,
> should
>>connection-related
>>follow
>>>connections
> how
>>>>>Hi,
>>the
>>>Figure
> be
>>>>saved
> example
>>>>only?
>>my
>>>anchors?
>>>>>Thank you.
Re: Saving my diagram in GEF [message #34392 is a reply to message #34289] |
Mon, 21 October 2002 17:42   |
Eric
> Thanks again.
> Thank you.
> reference
> object
> the
>>Zac
> that?
>>should
>>(from
>>>Thanks.
>>>>Takumi,
> should
>>connection-related
>>follow
>>>connections
> how
>>>>>Hi,
>>the
>>>Figure
> be
>>>>saved
> example
>>>>only?
>>my
>>>anchors?
>>>>>Thank you.
Re: Saving my diagram in GEF [message #34460 is a reply to message #34289] |
Mon, 21 October 2002 16:59   |
Eric
news:ap1ii3$837$1@rogue.oti.com...
> Thanks again.
> Thank you.
> reference
> object
> the
> > Zac
> that?
> > should
> > (from
> > > Thanks.
> > > > Takumi,
> should
> > connection-related
> > follow
> > > connections
> how
> > > > > Hi,
> > the
> > > Figure
> be
> > > > saved
> example
> > > > only?
> > my
> > > anchors?
> > > > > Thank you.
Re: Saving my diagram in GEF [message #34771 is a reply to message #34123] |
Tue, 22 October 2002 12:40   |
Originally posted by: jayuen.alumni.uwaterloo.ca
Randy:
You mention that if anchors are to be saved, they should be saved in the
model.
In my app, I maintain a list of anchors in my model.
However, the follow-up post from Zac Wolfe says that:
Connection anchor information should be generated or fixed but not stored.
If your connections
So if I want to adhere to GEF's MVC conventions, should anchors be saved
anywhere?
Because if they aren't saved, I don't see how connections can be properly
restored if I require specific locations for my anchoring based on relative
locations of glyphs. For instance, if Glyph A is below Glyph B, the
connection will be anchored at the base of Glyph B and at the top of Glyph A
Jason
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:ap1cpg$4e0$1@rogue.oti.com...
> > Hi,
Figure
> saved
> only?
> Please don't be confused by other discussions on this newsgroup. You only
> save the model.
anchors?
> Must be in the model
> > Thank you.
Re: Saving my diagram in GEF [message #34904 is a reply to message #34089] |
Tue, 22 October 2002 15:53   |
Zac,
I try what you said, save all the connection anchors in my model (store in a
hashtable) and that is serialzed when my diagram is saved. Saving the
diagram work, but when I re-open my diagram, I got a NullPointerException in
AbstractConnectionAnchor.addAnchorListener.
During reopening the diagram, I put a breakpoint in my model which it reads
from the hash-table to get the
connection connection based on its key, it did return the right connection
anchor, but I still get this NullPoingerException.
I appreciate if you can give me some ideas how to trouble shoot this
proglem.
Thank you for your help.
<<<<< log file >>>>>>>>>>>>>>>>>>
!SESSION Oct 22, 2002
10:32:47.341 ---------------------------------------------
java.version=1.4.0
Command-line arguments: -dev bin -data
C:\eclipse0911\eclipse\runtime-workspace -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 4 2 Oct 22, 2002 10:32:47.341
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.draw2d.AbstractConnectionAnchor.addAnchorListene r(AbstractConnec
tionAnchor.java:53)
org.eclipse.draw2d.PolylineConnection.hookSourceAnchor(Polyl ineConnection.ja
va:139)
org.eclipse.draw2d.PolylineConnection.setSourceAnchor(Polyli neConnection.jav
a:227)
org.eclipse.gef.editparts.AbstractConnectionEditPart.refresh SourceAnchor(Abs
tractConnectionEditPart.java:175)
org.eclipse.gef.editparts.AbstractConnectionEditPart.refresh (AbstractConnect
ionEditPart.java:169)
org.eclipse.gef.editparts.AbstractConnectionEditPart.setSour ce(AbstractConne
ctionEditPart.java:202)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addSourc eConnection(Abst
ractGraphicalEditPart.java:154)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshS ourceConnections
(AbstractGraphicalEditPart.java:445)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphica
lEditPart.java:408)
org.eclipse.gef.editparts.AbstractEditPart.doInitialize(Abst ractEditPart.jav
a:369)
org.eclipse.gef.editparts.AbstractEditPart.initialize(Abstra ctEditPart.java:
669)
org.eclipse.gef.editparts.AbstractEditPart.setParent(Abstrac tEditPart.java:9
24)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:19
6)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.
java:765)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:726
lEditPart.java:407)
a:369)
669)
24)
6)
org.eclipse.gef.ui.parts.FreeformGraphicalRootEditPart.setCo ntents(FreeformG
raphicalRootEditPart.java:118)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPart
Viewer.java:311)
Viewer.java:371)
org.projectd.myeditor.Myeditor.initializeGraphicalViewer(Mye ditor.java:274)
org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalView er(GraphicalEdit
or.java:44)
org.eclipse.gef.ui.parts.GraphicalEditorWithPalette.createPa rtControl(Graphi
calEditorWithPalette.java:42)
at org.eclipse.ui.internal.PartPane$4.run(PartPane.java:135)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:839)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :177)
org.eclipse.ui.internal.EditorWorkbook.createPage(EditorWork book.java:230)
org.eclipse.ui.internal.EditorWorkbook.createControl(EditorW orkbook.java:190
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.ja
va:180)
va:180)
org.eclipse.ui.internal.PerspectivePresentation.activate(Per spectivePresenta
tion.java:95)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:635)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1574)
at org.eclipse.ui.internal.WorkbenchWindow$7.run(WorkbenchWindo w.java:1303)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1
290)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:11
73)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1281)
at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:12 50)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:888)
:839)
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:
840)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:649)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1396)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:432)
at EclipseRuntimeLauncher.main(EclipseRuntimeLauncher.java:24)
!ENTRY org.eclipse.ui.workbench 4 2 Oct 22, 2002 10:32:50.425
!STACK 0
org.eclipse.ui.internal.WorkbenchPage.getReference(Workbench Page.java:2590)
org.eclipse.ui.internal.WorkbenchPage.certifyPart(WorkbenchP age.java:581)
at org.eclipse.ui.internal.WorkbenchPage.bringToTop(WorkbenchPa ge.java:438)
org.eclipse.ui.views.navigator.ResourceNavigator.linkToEdito r(ResourceNaviga
tor.java:694)
org.eclipse.ui.views.navigator.ResourceNavigator.handleSelec tionChanged(Reso
urceNavigator.java:566)
org.eclipse.ui.views.navigator.ResourceNavigator$4.selection Changed(Resource
Navigator.java:295)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:147)
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.
java:1155)
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.jav
a:904)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:34 2)
org.eclipse.ui.views.navigator.ResourceNavigator.restoreStat e(ResourceNaviga
tor.java:780)
org.eclipse.ui.views.navigator.ResourceNavigator.createPartC ontrol(ResourceN
avigator.java:199)
:839)
at org.eclipse.ui.internal.ViewPane.createChildControl(ViewPane .java:202)
at org.eclipse.ui.internal.ViewPane.createControl(ViewPane.java :181)
org.eclipse.ui.internal.PartTabFolder.createPartTab(PartTabF older.java:249)
org.eclipse.ui.internal.PartTabFolder.createControl(PartTabF older.java:221)
va:180)
tion.java:95)
290)
73)
:839)
840)
a:775)
!ENTRY org.eclipse.ui.workbench 4 2 Oct 22, 2002 10:32:51.266
!STACK 0
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage
..java:2608)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1577)
290)
73)
:839)
840)
a:775)
!ENTRY org.eclipse.ui 4 4 Oct 22, 2002 10:32:51.407
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Oct 22, 2002 10:32:51.447
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2139)
at org.eclipse.swt.SWT.error(SWT.java:2071)
at org.eclipse.swt.widgets.Widget.error(Widget.java:371)
at org.eclipse.swt.widgets.Control.getDisplay(Control.java:720)
at org.eclipse.swt.widgets.Widget.isValidThread(Widget.java:574 )
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:301)
at org.eclipse.swt.widgets.Control.getFont(Control.java:755)
org.eclipse.draw2d.LightweightSystem$RootFigure.getFont(Ligh tweightSystem.ja
va:249)
at org.eclipse.draw2d.Figure.getFont(Figure.java:396)
at org.eclipse.draw2d.Label.calculateTextSize(Label.java:217)
at org.eclipse.draw2d.Label.getTextSize(Label.java:404)
at org.eclipse.draw2d.Label.getPreferredSize(Label.java:291)
org.eclipse.draw2d.StackLayout.calculatePreferredSize(StackL ayout.java:39)
at org.eclipse.draw2d.StackLayout.getPreferredSize(StackLayout. java:67)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:474)
org.eclipse.draw2d.ToolbarLayout.calculatePreferredSize(Tool barLayout.java:1
58)
org.eclipse.draw2d.AbstractLayout.calculatePreferredSize(Abs tractLayout.java
:30)
org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractL ayout.java:64)
org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractL ayout.java:73)
at org.eclipse.draw2d.ToolbarLayout.layout(ToolbarLayout.java:2 13)
at org.eclipse.draw2d.Figure.layout(Figure.java:778)
at org.eclipse.draw2d.Figure.validate(Figure.java:1320)
at org.eclipse.draw2d.Figure.validate(Figure.java:1322)
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManag
er.java:161)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager
..java:90)
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateMan
ager.java:37)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 1)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:94)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1599)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1372)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:563 )
at org.eclipse.jface.window.Window.open(Window.java:543)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:280)
org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:42)
at org.eclipse.ui.internal.Workbench$7.handleException(Workbenc h.java:899)
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalP
latform.java:439)
:841)
840)
a:775)
!ENTRY org.eclipse.ui.workbench 4 2 Oct 22, 2002 10:33:00.490
!STACK 0
tionAnchor.java:53)
va:139)
a:227)
lEditPart.java:408)
a:369)
669)
24)
6)
java:765)
lEditPart.java:407)
a:369)
669)
24)
6)
Viewer.java:311)
Viewer.java:371)
or.java:44)
:839)
at org.eclipse.ui.internal.EditorWorkbook.add(EditorWorkbook.ja va:85)
at org.eclipse.ui.internal.EditorArea.addEditor(EditorArea.java :46)
org.eclipse.ui.internal.EditorPresentation.openEditor(Editor Presentation.jav
a:352)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.ja va:546)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:535
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
614)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:427)
org.eclipse.ui.internal.EditorManager.openEditorFromInput(Ed itorManager.java
:304)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:392)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1757)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1643)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:91)
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.jav
a:91)
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGr
oup.java:112)
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGr
oup.java:183)
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigato
r.java:533)
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.ja
va:305)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:32
0)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:
494)
org.eclipse.jface.viewers.StructuredViewer$3.handleOpen(Stru cturedViewer.jav
a:581)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:204)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:199)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1622)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1368)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1420)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1403)
a:775)
!ENTRY org.eclipse.ui 4 4 Oct 22, 2002 10:33:01.932
!ENTRY org.eclipse.ui 4 0 Oct 22, 2002 10:33:01.952
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:319)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1772)
a:91)
oup.java:112)
oup.java:183)
r.java:533)
va:305)
0)
494)
a:581)
a:775)
!ENTRY org.eclipse.ui 4 4 Oct 22, 2002 10:33:03.864
!ENTRY org.eclipse.ui 4 0 Oct 22, 2002 10:33:03.874
!STACK 0
org.eclipse.ui.internal.WorkbenchWindow$12.shellDeactivated( WorkbenchWindow.
java:1482)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:161)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:849)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:854)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1236)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:1139)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2685 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1219)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2104 )
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:1680)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1362)
a:775)
!ENTRY org.eclipse.ui.workbench 4 2 Oct 22, 2002 10:34:15.517
!STACK 0
org.eclipse.ui.internal.WorkbenchWindow$12.shellActivated(Wo rkbenchWindow.ja
va:1465)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:157)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1247)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.j ava:197)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:568)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:1915)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:37 9)
at org.eclipse.ui.views.tasklist.TaskList.setFocus(TaskList.jav a:1010)
at org.eclipse.ui.internal.WorkbenchPage$2.run(WorkbenchPage.ja va:346)
:839)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:343)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2174)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:1
913)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:331)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:3 05)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:82 1)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:12 20)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2724 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1281 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:73)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2762 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:121 9)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:126)
a:775)
!ENTRY org.eclipse.ui 4 4 Oct 22, 2002 10:34:15.548
!ENTRY org.eclipse.ui 4 0 Oct 22, 2002 10:34:15.558
!STACK 0
java:1482)
at org.eclipse.swt.widgets.Shell.open(Shell.java:669)
at org.eclipse.jface.window.Window.open(Window.java:539)
latform.java:439)
:841)
913)
a:775)
> Takumi,
connections
> > Hi,
Figure
> saved
> only?
anchors?
> > Thank you.
Re: Saving my diagram in GEF [message #34934 is a reply to message #34771] |
Tue, 22 October 2002 16:11  |
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:ap3tcp$g77$1@rogue.oti.com...
ConnectionAnchor has a method called getReferencePoint(). AbstractRouter uses
this method to get the location of the anchors. The source anchor is passed the
reference point from the target anchor and vice versa. This is how ChopboxAchor
works. The source knows the relative direction of the target (say, Glyph A and
Glyph B).
Eric
Current Time: Mon Sep 01 00:28:42 EDT 2025
Powered by FUDForum. Page generated in 0.13104 seconds
