Home » Language IDEs » Java Development Tools (JDT) » Minecraft Mod error(Minecraft Mod creation error 398)
Minecraft Mod error [message #1800775] |
Tue, 08 January 2019 06:30 |
Marco Barros Messages: 3 Registered: January 2019 |
Hello everyone,
I decided to start a Minecraft mod based on a game called Grand Chase. The first steps were easy and I managed to do every thing correctly, but after i write the @SidedProxy part, I tried to launch Minecraft to test it but it didn't work. I tried several things , such as re-writing this part but it didn't work. Could somebody help me ?
CODE Main class:
package lassisolet.GrandChaseMod.main;
import cpw.mods.fml.common.Mod;
import cpw.mods.fml.common.Mod.EventHandler;
import cpw.mods.fml.common.SidedProxy;
import cpw.mods.fml.common.event.FMLInitializationEvent;
import cpw.mods.fml.common.event.FMLPostInitializationEvent;
import cpw.mods.fml.common.event.FMLPreInitializationEvent;
import lassisolet.GrandChaseMod.lib.Strings;
import lassisolet.GrandChaseMod.proxy.CommonProxy;
@Mod(modid = Strings.MODID , version = Strings.VERSION , name = Strings.MODNAME)
public class Grand_Chase_Mod
@SidedProxy(clientSide=Strings.CLIENT, serverSide=Strings.COMMONPROXY)
public static CommonProxy proxy;
@EventHandler
public static void preLoad(FMLPreInitializationEvent event)
//CommonProxy.RegisterRender();
@EventHandler
public static void Load(FMLInitializationEvent event)
@EventHandler
public static void postLoad(FMLPostInitializationEvent event)
CODE Strings class:
package lassisolet.GrandChaseMod.lib;
public class Strings
public static final String MODID = "gcmod";
public static final String VERSION = "1.0";
public static final String MODNAME = "Grand Chase Mod";
public static final String COMMONPROXY = "lassisolet.GrandChaseMod.proxy.CommonProxy";
public static final String CLIENT = "lassisolet.GrandChaseMod.Client";
CODE Client class:
package lassisolet.GrandChaseMod.proxy;
public class Client extends CommonProxy
public static void RegisterRender()
CODE Common proxy class:
public class CommonProxy
Crash Report:
[22:08:38] [main/INFO] [GradleStart]: Extra: []
[22:08:38] [main/INFO] [GradleStart]: Running with arguments: [--userProperties, {}, --assetsDir, C:/Users/Marco/.gradle/caches/minecraft/assets, --assetIndex, 1.7.10, --accessToken, {REDACTED}, --version, 1.7.10, --tweakClass, cpw.mods.fml.common.launcher.FMLTweaker, --tweakClass, net.minecraftforge.gradle.tweakers.CoremodTweaker]
[22:08:38] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.FMLTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Using primary tweak class name cpw.mods.fml.common.launcher.FMLTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.gradle.tweakers.CoremodTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.FMLTweaker
[22:08:38] [main/INFO] [FML]: Forge Mod Loader version 7.99.36.1558 for Minecraft 1.7.10 loading
[22:08:38] [main/INFO] [FML]: Java is Java HotSpot(TM) 64-Bit Server VM, version 1.8.0_192, running on Windows 7:amd64:6.1, installed at C:\Program Files\Java\jre1.8.0_192
[22:08:38] [main/INFO] [FML]: Managed to load a deobfuscated Minecraft name- we are in a deobfuscated environment. Skipping runtime deobfuscation
[22:08:38] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.gradle.tweakers.CoremodTweaker
[22:08:38] [main/INFO] [GradleStart]: Injecting location in coremod cpw.mods.fml.relauncher.FMLCorePlugin
[22:08:38] [main/INFO] [GradleStart]: Injecting location in coremod net.minecraftforge.classloading.FMLForgePlugin
[22:08:38] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.FMLInjectionAndSortingTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.FMLDeobfTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.gradle.tweakers.AccessTransformerTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.FMLInjectionAndSortingTweaker
[22:08:38] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.relauncher.CoreModManager$FMLPluginWrapper
[22:08:38] [main/ERROR] [FML]: The binary patch set is missing. Either you are in a development environment, or things are not going to work!
[22:08:40] [main/ERROR] [FML]: FML appears to be missing any signature data. This is not a good thing
[22:08:40] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.relauncher.CoreModManager$FMLPluginWrapper
[22:08:40] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.FMLDeobfTweaker
[22:08:40] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.gradle.tweakers.AccessTransformerTweaker
[22:08:40] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.TerminalTweaker
[22:08:40] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.TerminalTweaker
[22:08:40] [main/INFO] [LaunchWrapper]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[22:08:41] [main/INFO]: Setting user: Player921
[22:08:42] [Client thread/INFO]: LWJGL Version: 2.9.1
[22:08:43] [Client thread/INFO] [STDOUT]: [cpw.mods.fml.client.SplashProgress:start:188]: ---- Minecraft Crash Report ----
// Who set us up the TNT?
Time: 1/7/19 10:08 PM
Description: Loading screen debug info
This is just a prompt for computer specs to be printed. THIS IS NOT A ERROR
A detailed walkthrough of the error, its code path and all known details is as follows:
-- System Details --
Details:
Minecraft Version: 1.7.10
Operating System: Windows 7 (amd64) version 6.1
Java Version: 1.8.0_192, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 798279344 bytes (761 MB) / 1037959168 bytes (989 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 3 total; -Xincgc -Xmx1024M -Xms1024M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
FML:
GL info: ' Vendor: 'NVIDIA Corporation' Version: '4.5.0 NVIDIA 376.53' Renderer: 'GeForce GTX 560/PCIe/SSE2'
[22:08:43] [Client thread/INFO] [MinecraftForge]: Attempting early MinecraftForge initialization
[22:08:43] [Client thread/INFO] [FML]: MinecraftForge v10.13.4.1558 Initialized
[22:08:43] [Client thread/INFO] [FML]: Replaced 183 ore recipies
[22:08:43] [Client thread/INFO] [MinecraftForge]: Completed early MinecraftForge initialization
[22:08:43] [Client thread/INFO] [FML]: Found 0 mods from the command line. Injecting into mod discoverer
[22:08:43] [Client thread/INFO] [FML]: Searching C:\Users\Marco\Desktop\Grand Chase Mod\eclipse\mods for mods
[22:08:48] [Client thread/INFO] [FML]: Forge Mod Loader has identified 4 mods to load
[22:08:48] [Client thread/INFO] [FML]: Attempting connection with missing mods [mcp, FML, Forge, gcmod] at CLIENT
[22:08:48] [Client thread/INFO] [FML]: Attempting connection with missing mods [mcp, FML, Forge, gcmod] at SERVER
[22:08:48] [Client thread/ERROR] [FML]: An error occured trying to load a proxy into {serverSide=lassisolet.GrandChaseMod.proxy.CommonProxy, clientSide=lassisolet.GrandChaseMod.Client}.lassisolet.GrandChaseMod.main.Grand_Chase_Mod
java.lang.ClassNotFoundException: lassisolet.GrandChaseMod.Client
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:191) ~[launchwrapper-1.12.jar:?]
at java.lang.ClassLoader.loadClass(Unknown Source) ~[?:1.8.0_192]
at cpw.mods.fml.common.ModClassLoader.loadClass(ModClassLoader.java:58) ~[ModClassLoader.class:?]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_192]
at java.lang.Class.forName(Unknown Source) ~[?:1.8.0_192]
at cpw.mods.fml.common.ProxyInjector.inject(ProxyInjector.java:59) [ProxyInjector.class:?]
at cpw.mods.fml.common.FMLModContainer.constructMod(FMLModContainer.java:512) [FMLModContainer.class:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_192]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_192]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_192]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:1.8.0_192]
at com.google.common.eventbus.EventSubscriber.handleEvent(EventSubscriber.java:74) [guava-17.0.jar:?]
at com.google.common.eventbus.SynchronizedEventSubscriber.handleEvent(SynchronizedEventSubscriber.java:47) [guava-17.0.jar:?]
at com.google.common.eventbus.EventBus.dispatch(EventBus.java:322) [guava-17.0.jar:?]
at com.google.common.eventbus.EventBus.dispatchQueuedEvents(EventBus.java:304) [guava-17.0.jar:?]
at com.google.common.eventbus.EventBus.post(EventBus.java:275) [guava-17.0.jar:?]
at cpw.mods.fml.common.LoadController.sendEventToModContainer(LoadController.java:212) [LoadController.class:?]
at cpw.mods.fml.common.LoadController.propogateStateMessage(LoadController.java:190) [LoadController.class:?]
at cpw.mods.fml.common.LoadController.distributeStateMessage(LoadController.java:119) [LoadController.class:?]
at cpw.mods.fml.common.Loader.loadMods(Loader.java:513) [Loader.class:?]
at cpw.mods.fml.client.FMLClientHandler.beginMinecraftLoading(FMLClientHandler.java:208) [FMLClientHandler.class:?]
at net.minecraft.client.Minecraft.startGame(Minecraft.java:522) [Minecraft.class:?]
at net.minecraft.client.Minecraft.run(Minecraft.java:942) [Minecraft.class:?]
at net.minecraft.client.main.Main.main(Main.java:164) [Main.class:?]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
at net.minecraftforge.gradle.GradleStartCommon.launch(Unknown Source) [start/:?]
at GradleStart.main(Unknown Source) [start/:?]
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:182) ~[launchwrapper-1.12.jar:?]
... 41 more
[22:08:48] [Client thread/ERROR] [FML]: Fatal errors were detected during the transition from CONSTRUCTING to PREINITIALIZATION. Loading cannot continue
States: 'U' = Unloaded 'L' = Loaded 'C' = Constructed 'H' = Pre-initialized 'I' = Initialized 'J' = Post-initialized 'A' = Available 'D' = Disabled 'E' = Errored
UC mcp{9.05} [Minecraft Coder Pack] (minecraft.jar)
UC FML{7.10.99.99} [Forge Mod Loader] (forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar)
UC Forge{10.13.4.1558} [Minecraft Forge] (forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar)
UE gcmod{1.0} [Grand Chase Mod] (bin)
[22:08:48] [Client thread/ERROR] [FML]: The following problems were captured during this phase
[22:08:48] [Client thread/ERROR] [FML]: Caught exception from gcmod
cpw.mods.fml.common.LoaderException: java.lang.ClassNotFoundException: lassisolet.GrandChaseMod.Client
at cpw.mods.fml.common.ProxyInjector.inject(ProxyInjector.java:76) ~[forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar:?]
at cpw.mods.fml.common.FMLModContainer.constructMod(FMLModContainer.java:512) ~[forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar:?]
at com.google.common.eventbus.EventSubscriber.handleEvent(EventSubscriber.java:74) ~[guava-17.0.jar:?]
at com.google.common.eventbus.SynchronizedEventSubscriber.handleEvent(SynchronizedEventSubscriber.java:47) ~[guava-17.0.jar:?]
at com.google.common.eventbus.EventBus.dispatch(EventBus.java:322) ~[guava-17.0.jar:?]
at com.google.common.eventbus.EventBus.dispatchQueuedEvents(EventBus.java:304) ~[guava-17.0.jar:?]
at com.google.common.eventbus.EventBus.post(EventBus.java:275) ~[guava-17.0.jar:?]
at cpw.mods.fml.common.LoadController.sendEventToModContainer(LoadController.java:212) ~[forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar:?]
at cpw.mods.fml.common.LoadController.propogateStateMessage(LoadController.java:190) ~[forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar:?]
Caused by: java.lang.ClassNotFoundException: lassisolet.GrandChaseMod.Client
at cpw.mods.fml.common.ModClassLoader.loadClass(ModClassLoader.java:58) ~[forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar:?]
at cpw.mods.fml.common.ProxyInjector.inject(ProxyInjector.java:59) ~[forgeSrc-1.7.10-10.13.4.1558-1.7.10.jar:?]
... 35 more
... 35 more
[22:08:48] [Client thread/INFO] [STDOUT]: [net.minecraft.client.Minecraft:displayCrashReport:388]: ---- Minecraft Crash Report ----
// I feel sad now :(
Description: There was a severe problem during mod loading that has caused the game to fail
... 35 more
... 41 more
Details:
Memory: 617654080 bytes (589 MB) / 1037959168 bytes (989 MB) up to 1037959168 bytes (989 MB)
FML: MCP v9.05 FML v7.10.99.99 Minecraft Forge 10.13.4.1558 4 mods loaded, 4 mods active
[22:08:48] [Client thread/INFO] [STDOUT]: [net.minecraft.client.Minecraft:displayCrashReport:398]: #@!@# Game crashed! Crash report saved to: #@!@# C:\Users\Marco\Desktop\Grand Chase Mod\eclipse\.\crash-reports\crash-2019-01-07_22.08.48-client.txt
Thank you for the help
Marco
Current Time: Tue May 14 21:52:09 GMT 2024
Powered by FUDForum. Page generated in 0.03784 seconds
