Home » Eclipse Projects » Eclipse Platform » Find a class
Find a class [message #335124] Mon, 23 March 2009 16:59 Go to next message
In IntelliJ, it is very easy to find a class of a given name.
One enters ctrl-n, then types in the name of the class, and you are
presented with a list.
Eclipse does not appear to have anything so convenient.
The best I can find is:
Search -> Java -> Type
Is this is, or is there a faster way?
Re: Find a class [message #335126 is a reply to message #335124] Mon, 23 March 2009 17:25 Go to previous messageGo to next message
Al,
You mean like content assist, Ctrl-Space by default, in the editor or a
hot key like Ctrl-Shift-T for searching all classes that's generally
available in the perspective?
Re: Find a class [message #335128 is a reply to message #335126] Mon, 23 March 2009 19:05 Go to previous messageGo to next message
thank you
Re: Find a class [message #335144 is a reply to message #335126] Tue, 24 March 2009 04:10 Go to previous messageGo to next message
You can also check the menu 'Help > Key Assist' to get the rest of the
short cuts. There are lot of convenient short cuts available.
Ed Merks wrote:
> Al,
Re: Find a class [message #335146 is a reply to message #335144] Tue, 24 March 2009 04:40 Go to previous messageGo to next message
Doesn't Al want something like "Open Resource" by CTRL+SHIFT+R? This is
my preferred way to find a class.
Adam
> Ed Merks wrote:
>> Al,
>> a hot key like Ctrl-Shift-T for searching all classes that's generally
Re: Find a class [message #335156 is a reply to message #335146] Tue, 24 March 2009 08:09 Go to previous messageGo to next message
Adam,
Given he explicitly said "find a class" I have to assume that the extra
files provided by Ctrl-Shift-R would be noisy rather than helpful. I
used this only to find things other than .java files, and yes, for that
it's very useful!
> is my preferred way to find a class.
> Adam
>> the short cuts. There are lot of convenient short cuts available.
>> Ed Merks wrote:
>>> Al,
>>> or a hot key like Ctrl-Shift-T for searching all classes that's
>>> generally available in the perspective?
Re: Find a class [message #335192 is a reply to message #335156] Wed, 25 March 2009 10:43 Go to previous message
Also if the class is an inner class, Ctrl+Shift+R won't help :-)
- Prakash
http://blog.eclipse-tips.com
Previous Topic:Resizing code assist pop-ups - Ubuntu
Next Topic:workingSets and headless environments
Current Time: Mon Jul 14 08:24:20 EDT 2025
Powered by FUDForum. Page generated in 0.05508 seconds
