Home » Eclipse Projects » Eclipse Platform » How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage?
How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335112] Mon, 23 March 2009 10:54 Go to next message
Hi all.
In my application I have added the
"org.eclipse.ui.internal.keys.NewKeysPreferencePage" as one of the pages of
the Preference dialog. In my "Problem view" I get a following warning:
"Access to referenced class
'org.eclipse.ui.internal.keys.NewKeysPreferencePage' in attribute 'class' is
discouraged plugin.xml ..."
I would like to remove this warning, so I have tried to do as described
here:
http://wiki.eclipse.org/DTP_Resolving_Internal_Discouraged_A ccess_Warnings.
Unfortunately, it doesn't work. The warning is still there. I add the
following lines to the .classpath file:
<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins">
<accessrules>
<accessrule kind="accessible"
pattern="org/eclipse/ui/internal/NewKeysPreferencePage"/>
</accessrules>
</classpathentry>
What am I doing wrong?
Thanks in advance,
Anders Baumann
Re: How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335122 is a reply to message #335112] Mon, 23 March 2009 12:47 Go to previous messageGo to next message
"Anders Baumann" <anb@maconomy.dk> wrote in message
news:gq87rv$rgb$1@build.eclipse.org...
> Hi all.
> of the Preference dialog. In my "Problem view" I get a following warning:
> is discouraged plugin.xml ..."
> here:
> <accessrules>
> </accessrules>
> </classpathentry>
You're using an internal interface. Eclipse is warning you that you're
using code that is likely to change in a future version, thus breaking your
plug-in. In other words, by doing this you're committing to updating your
plug-in with every version of Eclipse (not to mention distributing multiple
versions of your plug-in). You should make sure to set version ranges in
your plug-in dependencies.
The reason your effort to suppress the warning didn't work appears to be
that you are missing a "/keys" in the access pattern.
Re: How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335150 is a reply to message #335122] Tue, 24 March 2009 05:00 Go to previous messageGo to next message
Hi Walter.
Thanks for your answer. You were right. I did miss the "/keys" in the access
pattern. Unfortunately the warning is still there. My .classpath now
contains:
<accessrules>
pattern="org/eclipse/ui/internal/keys/NewKeysPreferencePage "/>
</accessrules>
</classpathentry>
It seems to me that access rules like the one above work for normal Java
classes, but not for XML files like .classpath.
Is there a better or other way to use the NewKeysPreferencePage in my
preference dialog? It must be a very common thing to have a "Keys"
preference page in a RCP application.
Thanks in advance,
Anders Baumann
"Walter Harley" <eclipse@cafewalter.com> wrote in message
news:gq8efb$tr5$1@build.eclipse.org...
>> Hi all.
>> here:
>> <accessrules>
>> </accessrules>
>> </classpathentry>
> your plug-in. In other words, by doing this you're committing to updating
> your plug-in with every version of Eclipse (not to mention distributing
> multiple versions of your plug-in). You should make sure to set version
> ranges in your plug-in dependencies.
Re: How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335160 is a reply to message #335122] Tue, 24 March 2009 09:58 Go to previous messageGo to next message
On 3/23/2009 12:47 PM, Walter Harley wrote:
> "Anders Baumann"<anb@maconomy.dk> wrote in message
>> Hi all.
>> here:
>> <accessrules>
>> </accessrules>
>> </classpathentry>
I agree with Walter; you should leave the warning in place as a reminder
that you are doing something that is discouraged.
If you really want to remove the warning, it is easier to just use the
QuickFix (put cursor on the marked line of code and hit Ctrl+1) to
insert an @SuppressWarnings("restriction") annotation.
Hope this helps,
Eric
Re: How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335162 is a reply to message #335160] Tue, 24 March 2009 10:49 Go to previous messageGo to next message
Hi Eric.
But how do I put a @SuppressWarnings("restriction") in an XML file? The
warning is in the plugin.xml.
Also, Is there a better or other way to use the NewKeysPreferencePage in my
Thanks in advance,
Anders Baumann
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:gqaou6$peb$1@build.eclipse.org...
>>> Hi all.
>>> warning:
>>> 'class'
>>> here:
>>> <accessrules>
>>> </accessrules>
>>> </classpathentry>
>> your
>> your
>> multiple
> QuickFix (put cursor on the marked line of code and hit Ctrl+1) to insert
> Hope this helps,
> Eric
Re: How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335302 is a reply to message #335162] Tue, 31 March 2009 11:49 Go to previous messageGo to next message
Anders Baumann wrote:
> Hi Eric.
Yes, use org.eclipse.ui.ExtensionFactory to add the preference page.
For example:
<page
name="%PreferencePages.NewKeys"
category="org.eclipse.ui.preferencePages.Workbench"
class="org.eclipse.ui.ExtensionFactory:newKeysPreferencePage "
id="org.eclipse.ui.preferencePages.Keys">
<keywordReference id="org.eclipse.ui.ide.keys"/>
</page>
Paul Webster
Re: How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage? [message #335313 is a reply to message #335302] Tue, 31 March 2009 14:49 Go to previous message
Thanks, Paul. You are the man!!
Anders
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:gqte2g$uqu$1@build.eclipse.org...
>> Hi Eric.
>> my preference dialog? It must be a very common thing to have a "Keys"
> Yes, use org.eclipse.ui.ExtensionFactory to add the preference page. For
> example:
> <page
> </page>
> Paul Webster
Previous Topic:LTK copy refactoring
Next Topic:[Databinding] JFace Rhino Databinding
Current Time: Thu Jul 17 21:32:21 EDT 2025
Powered by FUDForum. Page generated in 0.06789 seconds
