Home » Eclipse Projects » Eclipse Platform » refresh not working properly
refresh not working properly [message #335102] Mon, 23 March 2009 07:03 Go to next message
After creating programmaticaly a new project in the workspace, I refresh
the workspace with this code:
project.getWorkspace ().getRoot ().refreshLocal
(IWorkspaceRoot.DEPTH_INFINITE, monitor);
However, sometimes, the Project Explorer View doesn't show the new project.
What should I do? Is it possible to trigger a resource change event and
how? shoudn't this be done automatically when I build the project, since
I also do project.build (IncrementalProjectBuilder.FULL_BUILD, monitor) ?
Thanks in advance for your help!
Re: refresh not working properly [message #335136 is a reply to message #335102] Tue, 24 March 2009 02:10 Go to previous messageGo to next message
You don't need to refresh the entire workspace. IProject.refreshLocal()
should do.
BTW, how are you creating the project? Are you calling a IProject.create()?
- Prakash
http://blog.eclipse-tips.com
Re: refresh not working properly [message #335165 is a reply to message #335136] Tue, 24 March 2009 12:11 Go to previous messageGo to next message
> should do.
I'm creating the project with create() and I tried doing a refreshLocal
on the workspace AND on the project. Even with these two refreshed,
sometimes (one time out of 30 or 50 times roughly) the new project does
not appear in the Project Explorer.
Re: refresh not working properly [message #335188 is a reply to message #335165] Wed, 25 March 2009 10:38 Go to previous messageGo to next message
Sounds like a bug to me.
- Prakash
Re: refresh not working properly [message #335259 is a reply to message #335102] Fri, 27 March 2009 18:35 Go to previous message
Originally posted by: francis.oaklandsoftware.com
If you are using Eclipse before 3.5 this could be a bug, and it's likely
that it's fixed in 3.5M6, if you can reproduce this problem in 3.5M6
please file a bug report.
On Mon, 23 Mar 2009 04:03:24 -0700, Youmm P. <kototamo@gmail.com> wrote:
> Hello,
> project.
> monitor) ?
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:Project clean event?
Next Topic:Problem with 3.5 rewriting eclipse.ini
Current Time: Sat Nov 08 17:24:25 EST 2025
Powered by FUDForum. Page generated in 0.03535 seconds
