Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Absolute Beginner: EMFT Transaction: documentation / use case scenarios
Absolute Beginner: EMFT Transaction: documentation / use case scenarios [message #33991] Thu, 11 May 2006 16:41 Go to next message
Originally posted by: michael.schifferdecker.gmail.com
I am 100% new to EMFT Transactions and basically would like to study
some documentation about basic use cases / the projects documentation...
Nothing obvious regarding these points on the EMFT page,...
>> Where is the best place to look to get an overview?
Thanks in advance.
Michael
Re: Absolute Beginner: EMFT Transaction: documentation / use case scenarios [message #34044 is a reply to message #33991] Fri, 12 May 2006 11:11 Go to previous message
Hi Michael,
The transaction component is divided into two major layers: EMF
transactions (the ability to manage multiple threads accessing the same
EMF editing domain, live validation of transactions, etc.) and workspace
integration (integrating an EMF editing domain into eclipse's
IUndoableOperation framework for undo/redo).
There are programmer's guides, tutorials and even an unzippable example
available for the two layers. Just install the transaction component
(along with its dependencies) into your eclipse and check out the Help >
Contents for the EMFT Transactions Programmer's Guide and EMFT Workspace
Programmer's Guide.
There is an examples wizard that will unzip an entire example of how to
use the workspace integration layer to transform a standard generated
EMF reflective editor to use the eclipse IUndoableOperations and to use
one editor per resource with a shared editing domain. To access this
example click File > New > Examples... > EMFT Transaction > Workspace
Integration Example. Note that this example is examined in detail in the
Workspace Programmer's Guide's examples section.
I hope this helps,
Chris McGee
Michael Schifferdecker wrote:
> Thanks in advance.
> Michael
Re: Absolute Beginner: EMFT Transaction: documentation / use case scenarios [message #577514 is a reply to message #33991] Fri, 12 May 2006 11:11 Go to previous message
Hi Michael,
Programmer's Guide.
I hope this helps,
Chris McGee
> Thanks in advance.
> Michael
Previous Topic:Absolute Beginner: EMFT Transaction: documentation / use case scenarios
Next Topic:Combine Validation and Transaction together?
Current Time: Sun Aug 31 08:22:28 EDT 2025
Powered by FUDForum. Page generated in 0.13278 seconds
