Home » Eclipse Projects » Eclipse Platform » Fragments contributions behaving inconsistently
Fragments contributions behaving inconsistently [message #335082] |
Fri, 20 March 2009 17:01  |
I have a reporting plugin that has uses fragments to extend it's
behavior for customization for different users needs. When one of the
fragments is included in the application, it works without a hitch.
However, the second fragment doesn't show up (i.e. nothing shows up in
the UI although the fragment is resolved). I have been going over
everything for the past 2 days trying to find a reason for this and have
run out of options (my eyes are getting a little blurry as well). I
don't see any real difference between the two fragments' manifests or
fragment.xml that could explain this. Any help would be appreciated.
plugin.xml for the base plugin:
<?eclipse version="3.4"?>
<plugin>
<extension point="org.eclipse.ui.actionSets">
<actionSet
description="%action.set.workbench.report.description=Workbench Report
Action Set"
id="org.kdr.risk.workbench.report.action.set"
label="%action.set.workbench.report.label" visible="true">
<menu id="report" label="%menu.report.label" path="additions">
<groupMarker name="content"></groupMarker>
<separator name="additions"></separator>
</menu>
</actionSet>
</extension>
</plugin>
Manifest for base plugin:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %plugin.name
Bundle-SymbolicName: org.kdr.risk.report; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: org.kdr.risk.report.Activator
Bundle-Vendor: %plugin.provider
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.kdr.risk.common;bundle-version="1.0.0",
org.kdr.common;bundle-version="1.0.0",
org.kdr.enablement.datepicker;bundle-version="1.0.0",
org.kdr.enablement.internal;bundle-version="1.0.0",
org.kdr.enablement.jakarta.common;bundle-version="1.0.0",
org.kdr.enablement.jboss;bundle-version="1.0.0",
org.kdr.risk.env;bundle-version="1.0.0",
org.kdr.risk.product;bundle-version="1.0.0"
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ActivationPolicy: lazy
Bundle-Localization: plugin-report
Eclipse-BuddyPolicy: registered
Eclipse-ExtensibleAPI: true
fragment.xml for the fragment that is showing in the UI:
<fragment>
<extension point="org.eclipse.ui.commands">
<category description="%category.command.description"
id="org.kdr.risk.workbench.commands" name="%category.command.name" />
<command categoryId="org.kdr.risk.workbench.commands"
description="%command.job.report.option.settle.stormbridge.1.description "
id="org.kdr.risk.command.job.report.option.settle.stormbridge.1 "
name="%command.job.report.option.settle.stormbridge.1.name" />
</extension>
<actionSet
description=" %action.set.workbench.report.stormbridge.description=Workebe nch
Stormbridge Report Action Set"
id="org.kdr.risk.workbench.report.stormbridge.action.set"
label="%action.set.workbenchreport.stormbridge.label" visible="true">
<action
class=" org.kdr.ui.action.option.StartStormbridgeOptionSettlementRep ort1JobActionDelegate "
definitionId="org.kdr.risk.command.job.report.option.settle.stormbridge.1 "
id="org.kdr.job.option.settle.report.stormbridge.1"
label="%action.job.report.option.settle.stormbridge.1.label "
menubarPath="report/content" style="push">
</action>
</actionSet>
</extension>
</fragment>
Manifest for the fragment that is showing in the UI:
Bundle-SymbolicName: org.kdr.risk.report.stormbridge;singleton:=true
Fragment-Host: org.kdr.risk.report;bundle-version="[1.0.0,2.0.0)"
Bundle-Localization: plugin-report-stormbridge
Require-Bundle: org.kdr.enablement.jakarta.common;bundle-version="1.0.0",
org.kdr.enablement.csv;bundle-version="1.0.0",
org.kdr.risk.product;bundle-version="1.0.0",
Export-Package: org.kdr.ui.action.option,
org.kdr.ui.dialog.option,
org.kdr.ui.job.option
fragment.xml for the fragment that is not loading in the UI:
<fragment>
description="%command.job.report.env.vol.peakridge.1.description "
id="org.kdr.risk.command.job.report.env.vol.peakridge.1"
name="%command.job.report.env.vol.peakridge.1.name">
</command>
description="%command.job.report.option.settle.peakridge.1.description "
id="org.kdr.risk.command.job.report.option.settle.peakridge.1 "
name="%command.job.report.option.settle.peakridge.1.name">
</command>
</extension>
<actionSet
description=" %action.set.workbench.report.peakridge.description=Workebenc h
Peak Ridge Report Action Set"
id="org.kdr.risk.workbench.report.peakridge.action.set"
label="%action.set.workbench.report.peakridge.label" visible="true">
<action
class=" org.kdr.ui.action.env.vol.StartPeakridgeVolatilityReport1Job ActionDelegate "
definitionId="org.kdr.risk.command.job.report.env.vol.peakridge.1 "
id="org.kdr.job.env.vol.report.peakridge.1"
label="%action.job.report.env.vol.peakridge.1.label"
</action>
<action
class=" org.kdr.ui.action.option.StartPeakridgeOptionSettlementRepor t1JobActionDelegate "
definitionId="org.kdr.risk.command.job.report.option.settle.peakridge.1 "
id="org.kdr.job.option.settle.report.peakridge.1"
label="%action.job.report.option.settle.peakridge.1.label"
</action>
</actionSet>
</extension>
</fragment>
Manifest for the fragment that is not showing up in the UI:
Bundle-SymbolicName: org.kdr.risk.report.peakridge;singleton:=true
Bundle-Localization: plugin-report-peakridge
Export-Package: org.kdr.ui.action.env.vol,
org.kdr.ui.dialog.env.vol,
org.kdr.ui.job.env.vol,
Output from ss at the osgi console prompt:
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.4.2.R34x_v20080826-1230
1 ACTIVE com.ibm.icu_3.8.1.v20080530
2 RESOLVED org.eclipse.core.commands_3.4.0.I20080509-2000
3 <<LAZY>> org.eclipse.core.contenttype_3.3.0.v20080604-1400
4 ACTIVE org.eclipse.core.databinding_1.1.1.M20080827-0800b
5 ACTIVE org.eclipse.core.expressions_3.4.0.v20080603-2000
6 ACTIVE org.eclipse.core.jobs_3.4.0.v20080512
7 ACTIVE org.eclipse.core.runtime_3.4.0.v20080512
8 RESOLVED
org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 80610
Master=12
9 ACTIVE org.eclipse.equinox.app_1.1.0.v20080421-2006
10 ACTIVE org.eclipse.equinox.common_3.4.0.v20080421-2006
11 ACTIVE org.eclipse.equinox.preferences_3.2.201.R34x_v20080709
12 ACTIVE org.eclipse.equinox.registry_3.4.0.v20080516-0950
Fragments=8
13 <<LAZY>> org.eclipse.help_3.3.101.v20080702_34x
14 ACTIVE org.eclipse.jface_3.4.1.M20080827-2000
15 RESOLVED org.eclipse.jface.databinding_1.2.1.M20080827-0800a
16 RESOLVED org.eclipse.swt_3.4.1.v3449c
Fragments=17, 21
17 RESOLVED org.eclipse.swt.win32.win32.x86_3.4.1.v3449c
Master=16
18 ACTIVE org.eclipse.ui_3.4.1.M20080910-0800
19 <<LAZY>> org.eclipse.ui.forms_3.3.101.v20080708_34x
20 ACTIVE org.eclipse.ui.workbench_3.4.1.M20080827-0800a
21 RESOLVED org.jboss.tools.xulrunner.initializer_1.0.0
Master=16
22 ACTIVE org.kdr.common_1.0.0
23 <<LAZY>> org.kdr.enablement.apache.httpcomponents_1.0.0
24 ACTIVE org.kdr.enablement.apache.logging_1.0.0
25 ACTIVE org.kdr.enablement.apache.xml_1.0.0
26 <<LAZY>> org.kdr.enablement.csv_1.0.0
27 <<LAZY>> org.kdr.enablement.datepicker_1.0.0
28 <<LAZY>> org.kdr.enablement.eclipse.nebula_1.0.0
29 ACTIVE org.kdr.enablement.internal_1.0.0
30 <<LAZY>> org.kdr.enablement.j2ssh_1.0.0
31 ACTIVE org.kdr.enablement.jakarta.common_1.0.0
32 <<LAZY>> org.kdr.enablement.jakarta.regex_1.0.0
33 ACTIVE org.kdr.enablement.jboss_1.0.0
34 <<LAZY>> org.kdr.enablement.jsci_1.0.0
35 <<LAZY>> org.kdr.enablement.reuters_1.0.0
36 <<LAZY>> org.kdr.risk.common_1.0.0
37 <<LAZY>> org.kdr.risk.date_1.0.0
38 <<LAZY>> org.kdr.risk.entity_1.0.0
39 ACTIVE org.kdr.risk.env_1.0.0
40 <<LAZY>> org.kdr.risk.instrument_1.0.0
41 <<LAZY>> org.kdr.risk.location_1.0.0
42 <<LAZY>> org.kdr.risk.portfolio_1.0.0
43 <<LAZY>> org.kdr.risk.product_1.0.0
44 <<LAZY>> org.kdr.risk.report_1.0.0
Fragments=45, 46
45 RESOLVED org.kdr.risk.report.peakridge_1.0.0
Master=44
46 RESOLVED org.kdr.risk.report.stormbridge_1.0.0
Master=44
47 ACTIVE org.kdr.risk.security_1.0.0
48 <<LAZY>> org.kdr.risk.template_1.0.0
49 ACTIVE org.kdr.risk.trade_1.0.0
50 ACTIVE org.kdr.risk.trade.common_1.0.0
51 ACTIVE org.kdr.risk.trade.span_1.0.0
52 <<LAZY>> org.kdr.risk.unit_1.0.0
53 ACTIVE org.kdr.risk.valuation_1.0.0
54 ACTIVE org.kdr.risk.workbench_1.0.0
55 <<LAZY>> org.kdr.risk.xlate_1.0.0
Fragments=56, 57, 58, 59, 60, 61, 62, 63
56 RESOLVED org.kdr.risk.xlate.admiral_1.0.0
Master=55
57 RESOLVED org.kdr.risk.xlate.bofa_1.0.0
Master=55
58 RESOLVED org.kdr.risk.xlate.gs_1.0.0
Master=55
59 RESOLVED org.kdr.risk.xlate.mf_1.0.0
Master=55
60 RESOLVED org.kdr.risk.xlate.ne_1.0.0
Master=55
61 RESOLVED org.kdr.risk.xlate.nymex_1.0.0
Master=55
62 RESOLVED org.kdr.risk.xlate.reuters_1.0.0
Master=55
63 RESOLVED org.kdr.risk.xlate.span_1.0.0
Master=55
Karl
Current Time: Thu Jul 17 14:07:19 EDT 2025
Powered by FUDForum. Page generated in 0.44748 seconds
