Home » Eclipse Projects » Eclipse Platform » Fragments contributions behaving inconsistently
Fragments contributions behaving inconsistently [message #335082] Fri, 20 March 2009 17:01 Go to next message
I have a reporting plugin that has uses fragments to extend it's
behavior for customization for different users needs. When one of the
fragments is included in the application, it works without a hitch.
However, the second fragment doesn't show up (i.e. nothing shows up in
the UI although the fragment is resolved). I have been going over
everything for the past 2 days trying to find a reason for this and have
run out of options (my eyes are getting a little blurry as well). I
don't see any real difference between the two fragments' manifests or
fragment.xml that could explain this. Any help would be appreciated.
plugin.xml for the base plugin:
<?eclipse version="3.4"?>
<plugin>
<extension point="org.eclipse.ui.actionSets">
<actionSet
description="%action.set.workbench.report.description=Workbench Report
Action Set"
id="org.kdr.risk.workbench.report.action.set"
label="%action.set.workbench.report.label" visible="true">
<menu id="report" label="%menu.report.label" path="additions">
<groupMarker name="content"></groupMarker>
<separator name="additions"></separator>
</menu>
</actionSet>
</extension>
</plugin>
Manifest for base plugin:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %plugin.name
Bundle-SymbolicName: org.kdr.risk.report; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: org.kdr.risk.report.Activator
Bundle-Vendor: %plugin.provider
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.kdr.risk.common;bundle-version="1.0.0",
org.kdr.common;bundle-version="1.0.0",
org.kdr.enablement.datepicker;bundle-version="1.0.0",
org.kdr.enablement.internal;bundle-version="1.0.0",
org.kdr.enablement.jakarta.common;bundle-version="1.0.0",
org.kdr.enablement.jboss;bundle-version="1.0.0",
org.kdr.risk.env;bundle-version="1.0.0",
org.kdr.risk.product;bundle-version="1.0.0"
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ActivationPolicy: lazy
Bundle-Localization: plugin-report
Eclipse-BuddyPolicy: registered
Eclipse-ExtensibleAPI: true
fragment.xml for the fragment that is showing in the UI:
<fragment>
<extension point="org.eclipse.ui.commands">
<category description="%category.command.description"
id="org.kdr.risk.workbench.commands" name="%category.command.name" />
<command categoryId="org.kdr.risk.workbench.commands"
description="%command.job.report.option.settle.stormbridge.1.description "
id="org.kdr.risk.command.job.report.option.settle.stormbridge.1 "
name="%command.job.report.option.settle.stormbridge.1.name" />
</extension>
<actionSet
description=" %action.set.workbench.report.stormbridge.description=Workebe nch
Stormbridge Report Action Set"
id="org.kdr.risk.workbench.report.stormbridge.action.set"
label="%action.set.workbenchreport.stormbridge.label" visible="true">
<action
class=" org.kdr.ui.action.option.StartStormbridgeOptionSettlementRep ort1JobActionDelegate "
definitionId="org.kdr.risk.command.job.report.option.settle.stormbridge.1 "
id="org.kdr.job.option.settle.report.stormbridge.1"
label="%action.job.report.option.settle.stormbridge.1.label "
menubarPath="report/content" style="push">
</action>
</actionSet>
</extension>
</fragment>
Manifest for the fragment that is showing in the UI:
Bundle-SymbolicName: org.kdr.risk.report.stormbridge;singleton:=true
Fragment-Host: org.kdr.risk.report;bundle-version="[1.0.0,2.0.0)"
Bundle-Localization: plugin-report-stormbridge
Require-Bundle: org.kdr.enablement.jakarta.common;bundle-version="1.0.0",
org.kdr.enablement.csv;bundle-version="1.0.0",
org.kdr.risk.product;bundle-version="1.0.0",
Export-Package: org.kdr.ui.action.option,
org.kdr.ui.dialog.option,
org.kdr.ui.job.option
fragment.xml for the fragment that is not loading in the UI:
<fragment>
description="%command.job.report.env.vol.peakridge.1.description "
id="org.kdr.risk.command.job.report.env.vol.peakridge.1"
name="%command.job.report.env.vol.peakridge.1.name">
</command>
description="%command.job.report.option.settle.peakridge.1.description "
id="org.kdr.risk.command.job.report.option.settle.peakridge.1 "
name="%command.job.report.option.settle.peakridge.1.name">
</command>
</extension>
<actionSet
description=" %action.set.workbench.report.peakridge.description=Workebenc h
Peak Ridge Report Action Set"
id="org.kdr.risk.workbench.report.peakridge.action.set"
label="%action.set.workbench.report.peakridge.label" visible="true">
<action
class=" org.kdr.ui.action.env.vol.StartPeakridgeVolatilityReport1Job ActionDelegate "
definitionId="org.kdr.risk.command.job.report.env.vol.peakridge.1 "
id="org.kdr.job.env.vol.report.peakridge.1"
label="%action.job.report.env.vol.peakridge.1.label"
</action>
<action
class=" org.kdr.ui.action.option.StartPeakridgeOptionSettlementRepor t1JobActionDelegate "
definitionId="org.kdr.risk.command.job.report.option.settle.peakridge.1 "
id="org.kdr.job.option.settle.report.peakridge.1"
label="%action.job.report.option.settle.peakridge.1.label"
</action>
</actionSet>
</extension>
</fragment>
Manifest for the fragment that is not showing up in the UI:
Bundle-SymbolicName: org.kdr.risk.report.peakridge;singleton:=true
Bundle-Localization: plugin-report-peakridge
Export-Package: org.kdr.ui.action.env.vol,
org.kdr.ui.dialog.env.vol,
org.kdr.ui.job.env.vol,
Output from ss at the osgi console prompt:
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.4.2.R34x_v20080826-1230
1 ACTIVE com.ibm.icu_3.8.1.v20080530
2 RESOLVED org.eclipse.core.commands_3.4.0.I20080509-2000
3 <<LAZY>> org.eclipse.core.contenttype_3.3.0.v20080604-1400
4 ACTIVE org.eclipse.core.databinding_1.1.1.M20080827-0800b
5 ACTIVE org.eclipse.core.expressions_3.4.0.v20080603-2000
6 ACTIVE org.eclipse.core.jobs_3.4.0.v20080512
7 ACTIVE org.eclipse.core.runtime_3.4.0.v20080512
8 RESOLVED
org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 80610
Master=12
9 ACTIVE org.eclipse.equinox.app_1.1.0.v20080421-2006
10 ACTIVE org.eclipse.equinox.common_3.4.0.v20080421-2006
11 ACTIVE org.eclipse.equinox.preferences_3.2.201.R34x_v20080709
12 ACTIVE org.eclipse.equinox.registry_3.4.0.v20080516-0950
Fragments=8
13 <<LAZY>> org.eclipse.help_3.3.101.v20080702_34x
14 ACTIVE org.eclipse.jface_3.4.1.M20080827-2000
15 RESOLVED org.eclipse.jface.databinding_1.2.1.M20080827-0800a
16 RESOLVED org.eclipse.swt_3.4.1.v3449c
Fragments=17, 21
17 RESOLVED org.eclipse.swt.win32.win32.x86_3.4.1.v3449c
Master=16
18 ACTIVE org.eclipse.ui_3.4.1.M20080910-0800
19 <<LAZY>> org.eclipse.ui.forms_3.3.101.v20080708_34x
20 ACTIVE org.eclipse.ui.workbench_3.4.1.M20080827-0800a
21 RESOLVED org.jboss.tools.xulrunner.initializer_1.0.0
Master=16
22 ACTIVE org.kdr.common_1.0.0
23 <<LAZY>> org.kdr.enablement.apache.httpcomponents_1.0.0
24 ACTIVE org.kdr.enablement.apache.logging_1.0.0
25 ACTIVE org.kdr.enablement.apache.xml_1.0.0
26 <<LAZY>> org.kdr.enablement.csv_1.0.0
27 <<LAZY>> org.kdr.enablement.datepicker_1.0.0
28 <<LAZY>> org.kdr.enablement.eclipse.nebula_1.0.0
29 ACTIVE org.kdr.enablement.internal_1.0.0
30 <<LAZY>> org.kdr.enablement.j2ssh_1.0.0
31 ACTIVE org.kdr.enablement.jakarta.common_1.0.0
32 <<LAZY>> org.kdr.enablement.jakarta.regex_1.0.0
33 ACTIVE org.kdr.enablement.jboss_1.0.0
34 <<LAZY>> org.kdr.enablement.jsci_1.0.0
35 <<LAZY>> org.kdr.enablement.reuters_1.0.0
36 <<LAZY>> org.kdr.risk.common_1.0.0
37 <<LAZY>> org.kdr.risk.date_1.0.0
38 <<LAZY>> org.kdr.risk.entity_1.0.0
39 ACTIVE org.kdr.risk.env_1.0.0
40 <<LAZY>> org.kdr.risk.instrument_1.0.0
41 <<LAZY>> org.kdr.risk.location_1.0.0
42 <<LAZY>> org.kdr.risk.portfolio_1.0.0
43 <<LAZY>> org.kdr.risk.product_1.0.0
44 <<LAZY>> org.kdr.risk.report_1.0.0
Fragments=45, 46
45 RESOLVED org.kdr.risk.report.peakridge_1.0.0
Master=44
46 RESOLVED org.kdr.risk.report.stormbridge_1.0.0
Master=44
47 ACTIVE org.kdr.risk.security_1.0.0
48 <<LAZY>> org.kdr.risk.template_1.0.0
49 ACTIVE org.kdr.risk.trade_1.0.0
50 ACTIVE org.kdr.risk.trade.common_1.0.0
51 ACTIVE org.kdr.risk.trade.span_1.0.0
52 <<LAZY>> org.kdr.risk.unit_1.0.0
53 ACTIVE org.kdr.risk.valuation_1.0.0
54 ACTIVE org.kdr.risk.workbench_1.0.0
55 <<LAZY>> org.kdr.risk.xlate_1.0.0
Fragments=56, 57, 58, 59, 60, 61, 62, 63
56 RESOLVED org.kdr.risk.xlate.admiral_1.0.0
Master=55
57 RESOLVED org.kdr.risk.xlate.bofa_1.0.0
Master=55
58 RESOLVED org.kdr.risk.xlate.gs_1.0.0
Master=55
59 RESOLVED org.kdr.risk.xlate.mf_1.0.0
Master=55
60 RESOLVED org.kdr.risk.xlate.ne_1.0.0
Master=55
61 RESOLVED org.kdr.risk.xlate.nymex_1.0.0
Master=55
62 RESOLVED org.kdr.risk.xlate.reuters_1.0.0
Master=55
63 RESOLVED org.kdr.risk.xlate.span_1.0.0
Master=55
Karl
Re: Fragments contributions behaving inconsistently [message #335298 is a reply to message #335082] Tue, 31 March 2009 10:55 Go to previous message
menubarPath="report/content" ...
actionSets cannot see anything defined in another actionSet ... it just
doesn't work.
You can either replicate your menu structure in each actionSet (this is
allowed) or you can use commands/handlers (instead of IActionDelegates)
and use org.eclipse.ui.menus (which can see other org.eclipse.ui.menus
menu contributions)
PW
Paul Webster
Previous Topic:Register a "New Wizard" programmatically?
Next Topic:Local Update Site Mirror
Current Time: Sat Jul 26 10:04:26 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
