Home » Eclipse Projects » Eclipse Platform » LinkageError when starting project under Eclipse 3.5 M6
LinkageError when starting project under Eclipse 3.5 M6 [message #335066] Fri, 20 March 2009 03:08 Go to next message
Hello.
I just migrated from Eclipse 3.5M5 to M6 (with up to date CDO, Zest
Plugins).
The problem is that my existing project (RCP project consisting of
several plug ins) runs fine under M5, but doesn't start anymore under M6.
What does this LinkageError mean? How to resolve it? Why does the app
still run in M5?
I already tried to clean and refresh the whole project, without any success.
Kai
!ENTRY org.eclipse.osgi 4 0 2009-03-20 08:05:06.390
!MESSAGE Application error
!STACK 1
java.lang.LinkageError: loader constraint violation: loader (instance of
org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously
initiated loading for a different type with name
"org/eclipse/core/databinding/observable/Realm"
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:492)
at org.pubcurator.core.Application.start(Application.java:20)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:511)
at org.eclipse.equinox.launcher.Main.run(Main.java:1284)
at org.eclipse.equinox.launcher.Main.main(Main.java:1260)
!ENTRY org.eclipse.osgi 2 0 2009-03-20 08:05:06.421
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-03-20 08:05:06.421
!MESSAGE Bundle org.pubcurator.val.test_1.0.0 [105] was not resolved.
!SUBENTRY 2 org.pubcurator.val.test 2 0 2009-03-20 08:05:06.421
!MESSAGE Constraints from the fragment conflict with the host:
Require-Bundle: org.eclipse.swtbot.eclipse.finder; bundle-version="2.0.0"
Require-Bundle: org.eclipse.swtbot.swt.finder; bundle-version="2.0.0"
Require-Bundle: org.junit4; bundle-version="0.0.0"
Require-Bundle: org.apache.log4j; bundle-version="1.2.13"
Re: LinkageError when starting project under Eclipse 3.5 M6 [message #335072 is a reply to message #335066] Fri, 20 March 2009 07:42 Go to previous message
Problem solved.
My problem was somewhere I didn't exspected or have thought about until
yet (nearly all problems have that in common ;-)). I imported several
eclipse (mostly databinding) plugins from M5 into my workspace.
That old (and incompatible) versions of databinding was then used as
dependency for my plugins and resulted in this exception.
Kai
Kai Schlamp schrieb:
> Hello.
> Plugins).
> still run in M5?
> success.
> Best regards,
> Kai
> !STACK 1
> at
> at
> at
> at
> at
> at
Previous Topic:Localizing about.html
Next Topic:How to refresh a property tab
Current Time: Fri Sep 12 15:34:44 EDT 2025
Powered by FUDForum. Page generated in 0.03547 seconds
