Home » Eclipse Projects » Eclipse Platform » Resizing code assist pop-ups - Ubuntu
Resizing code assist pop-ups - Ubuntu [message #335055] Thu, 19 March 2009 13:14 Go to next message
Originally posted by: zhodaie.gmail.com
Hi all,
I don't know if it is here the right place to post it (if not my apologies)
On Ubuntu (maybe also other linuxes) I cannot resize the code assist
pop-up windows. For example, during debugging when the program is halted
you can move mouse cursor on variables and there pops up a window
showing contents of the object (as if you pressed Ctr-Shift-I on it).
Or during coding, when you press "." after an object's name, you see
code assist pop-up. In Windows I can resize both these windows but under
Ubuntu not. Is there a way to solve it? or it's a platform limitation?
Thank you,
Zardosht Hodaie.
Re: Resizing code assist pop-ups - Ubuntu [message #335182 is a reply to message #335055] Wed, 25 March 2009 09:11 Go to previous message
Zardosht Hodaie wrote:
> Hi all,
> apologies)
> halted you can move mouse cursor on variables and there pops up a
> window showing contents of the object (as if you pressed Ctr-Shift-I
> on it).
> under Ubuntu not. Is there a way to solve it? or it's a platform
> limitation?
It's a known problem: https://bugs.eclipse.org/bugs/show_bug.cgi?id=12238
Dani
> Thank you,
> Zardosht Hodaie.
Previous Topic:View creation at application startup
Next Topic:Find a class
Current Time: Wed Sep 24 21:07:48 EDT 2025
Powered by FUDForum. Page generated in 0.04119 seconds
