[Databinding] Display error dialog when validation returned error status [message #335040] |
Wed, 18 March 2009 13:17  |
I have to display an error dialog when validation returned an error
status. Sure, this only makes sense for Text controls and the FocusOut
event. The text control should be focussed when the dialog is closed.
What is the recommended way to do that? I tried some different ways, but
they all seem ugly.
Kind regards, Sebastian
Re: [Databinding] Display error dialog when validation returned error status [message #335046 is a reply to message #335042] |
Thu, 19 March 2009 05:33   |
I already tried this and it works, but it has a drawback: After the
dialog was shown and the Text focused again, the user can leave the Text
without any further error dialog. That's not surprising, as the
validation status did not change meanwhile. But in my case, the user
should be trapped until the input has the correct format.
I think this is no good UI, but I have to implement this due to project
requirements :(
Any idea? I thought of setting a stale flag manually, but it does not
seem to be possible.
Sebastian
Matthew Hall wrote:
> Sebastian Paul wrote:
>> but they all seem ugly.
> You should add a value change listener to the binding's
> getValidationStatus() observable. When it changes value, show the
> dialog if the current status is an error.
> You could call text.setFocus() after the dialog closes in your value
> change listener. Be careful with this though, it is possible to
> accidentally trap the user in a field with no way to correct the problem.
> Matthew
Re: [Databinding] Display error dialog when validation returned error status [message #335053 is a reply to message #335049] |
Thu, 19 March 2009 11:33  |
We're planning support for automatic control decoration from a binding:
See https://bugs.eclipse.org/268472
Matthew
>> Text without any further error dialog. That's not surprising, as the
>> project requirements :(
> We are trying to convince our customer of changing the requirement and
> add a control decoration instead. This will bypass the problem.
> Regards, Sebastian
FUDForum. Page generated in 0.11839 seconds
