Toggle Menu Item [message #335027] |
Tue, 17 March 2009 07:45  |
I need to use a toggle menu item. The status of the toggle menu item needs
to be persisted even if I close the eclipse instance. That means if I
check the toggle menu item and restart eclipse, the toggle menu item
should be in checked state itself.
Right now, I have implemented the toggle menu item using the command
"org.eclipse.ui.commands" extension point. But I am not able to persist
the toggle state.
If eclipse does not provide a built-in persistence for toggle menu item,
how can I use my own persistence mechanism? Can I use my own
PersistenceStore?
Any help is appreciated.
Madhu
FUDForum. Page generated in 0.03979 seconds
