Home » Eclipse Projects » Eclipse Platform » [Databinding] JFace Databinding for DOM-SSE
[Databinding] JFace Databinding for DOM-SSE [message #334990] Fri, 13 March 2009 13:15 Go to next message
I have created new project called JFace DOM-SSE Databinding which is
enable to bind DOM Node from SST TextEditor (ex : XML editor from WTP),
with another JFace implementation (SWT UI, ....). It can be helpfull when
you want manage XML editor with SWT UI (like manage plugin.xml with PDE).
I have started to write something about JFace DOM-SSE Databinding at
http://wiki.eclipse.org/JFace_Data_Binding/SSE#JFace_DOM-SSE _Databinding.
Today no sources are available, because I'm waiting for Boris to see where
I can put this project.
If you are interested, don't hesitate to contact me.
Regards Angelo
Re: [Databinding] JFace Databinding for DOM-SSE [message #335011 is a reply to message #334990] Mon, 16 March 2009 11:17 Go to previous message
Matthew and Boris, I have updated the wiki of JFace Databinding to explain
more the concept of JFace DOM-SSE Databinding at
http://wiki.eclipse.org/JFace_Data_Binding/SSE.
I have explained what I'm using MasterDetail concept that Matthew has
explaiend me at
http://wiki.eclipse.org/JFace_Data_Binding/SSE#Master_detail .2FObservableValue
I have tried to explain more the problematic with Node observed instance
which change and I have tried to have generic concept for that (it can be
work with DOM, EMF, Bean...). It means that
we could have "observed instance change management" into the Core of
Databinding?
What do you think?
If you don't understand what I mean, don't hesitate to contact me.
Regards Angelo
Previous Topic:Problems starting eclipse on moblin
Next Topic:newTypeHierarchy really slow
Current Time: Tue Jul 22 01:37:07 EDT 2025
Powered by FUDForum. Page generated in 0.02762 seconds
