Home » Eclipse Projects » DTP » RoutineEditor to open different SQL Objects with same name
RoutineEditor to open different SQL Objects with same name [message #33979] Tue, 07 August 2007 01:16 Go to next message
With Oracle Package Specification and Body, there will be 2 different
SQL objects with same name. Current version of RoutineEditor cannot open
2 SQL Objects with same name. Could this be looked into ? Let me know if
it is a bug, happy to log it.
Anthos
Re: RoutineEditor to open different SQL Objects with same name [message #33990 is a reply to message #33979] Tue, 07 August 2007 01:39 Go to previous message
Originally posted by: hui.cao.sybase.ocm
Anthos,
Whether to open a new RoutineEditor depends on the equality of
ProcEditorInput, not the name. Although the 2 routine objects have the same
name, there must be something different between them that you can put into
your customized ProcIdentifier object, which can be created from
DBHelper.getProcIdentifier.
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
"Anil Samuel" <anil.samuel@oracle.com> wrote in message
news:46B80016.10700@oracle.com...
> Hi
> With Oracle Package Specification and Body, there will be 2 different SQL
> objects with same name. Current version of RoutineEditor cannot open 2 SQL
> Objects with same name. Could this be looked into ? Let me know if it is a
> Regards
> Anthos
Re: RoutineEditor to open different SQL Objects with same name [message #587035 is a reply to message #33979] Tue, 07 August 2007 01:39 Go to previous message
Anthos,
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
> Hi
> Regards
> Anthos
Previous Topic:RoutineEditor to open different SQL Objects with same name
Next Topic:GenericSQLParser vs. AbstractSQLQueryParser
Current Time: Sun Aug 31 08:30:05 EDT 2025
Powered by FUDForum. Page generated in 0.03613 seconds
