| Problems starting eclipse on moblin [message #334925] |
Tue, 10 March 2009 10:29  |
Hi all,
I have tried searching for answers to this puzzler but to no avail,
apologies if I am just looking for the wrong keywords.
I get the splash screen and status bar updating and then, well, nothing.
No log files in either configuration or the workspace and no stdout.
Easiest steps to reproduce:
Download:
jdk1.6.0_12
eclipse-SDK-3.4.2-linux-gtk.tar.gz
unpack eclipse
create workspace dir
wrap LD_LIBRARY_PATH / PATH for the dir
run with -data and -vm
Are there any steps to be taken that can create more logs to help narrow
down the problem?
Using the jdt package stops at Mylyn with "Could not set color: 255, 256,
256". Removing mylyn features and plugins then has the same effect as the
sdk download.
The device has an atom 800 mhz processor and 512mb with 800x480. I have
found links saying 1024x768 is a required resolution and have used xrandr
with a virtual screen of that size but it makes no difference.
cheers and many thanks in advance,
Chris
| Re: Problems starting eclipse on moblin [message #334997 is a reply to message #334925] |
Sat, 14 March 2009 07:17  |
Hi All,
I figured out that the jvm is actually coring. Having run jstack on the
core I'm none the wiser.
The results of the pstack are below if anyone else can grok it.
cheers,
Chris
Attaching to core core.2966 from executable ../jdk1.6.0_12/jre/bin/java,
please wait...
Debugger attached successfully.
Client compiler detected.
JVM version is 11.2-b01
sun.jvm.hotspot.debugger.UnalignedAddressException: Trying to read at
address: 0xd8ffffe9 with alignment: 4
sun.jvm.hotspot.debugger.linux.LinuxDebuggerLocal$1.checkAli gnment(LinuxDebuggerLocal.java:181)
sun.jvm.hotspot.debugger.linux.LinuxDebuggerLocal.readCInteg er(LinuxDebuggerLocal.java:469)
sun.jvm.hotspot.debugger.DebuggerBase.readAddressValue(Debug gerBase.java:442)
sun.jvm.hotspot.debugger.linux.LinuxDebuggerLocal.readAddres s(LinuxDebuggerLocal.java:423)
sun.jvm.hotspot.debugger.linux.LinuxAddress.getAddressAt(Lin uxAddress.java:74)
at sun.jvm.hotspot.runtime.x86.X86Frame.getLink(X86Frame.java:3 87)
at sun.jvm.hotspot.runtime.x86.X86Frame.sender(X86Frame.java:28 9)
at sun.jvm.hotspot.runtime.Frame.sender(Frame.java:194)
at sun.jvm.hotspot.runtime.Frame.realSender(Frame.java:199)
at sun.jvm.hotspot.runtime.VFrame.sender(VFrame.java:119)
at sun.jvm.hotspot.runtime.VFrame.javaSender(VFrame.java:151)
sun.jvm.hotspot.runtime.JavaThread.getLastJavaVFrameDbg(Java Thread.java:231)
at sun.jvm.hotspot.tools.PStack.initJFrameCache(PStack.java:208 )
at sun.jvm.hotspot.tools.PStack.run(PStack.java:66)
at sun.jvm.hotspot.tools.PStack.run(PStack.java:53)
at sun.jvm.hotspot.tools.PStack.run(PStack.java:48)
at sun.jvm.hotspot.tools.JStack.run(JStack.java:60)
at sun.jvm.hotspot.tools.Tool.start(Tool.java:221)
at sun.jvm.hotspot.tools.JStack.main(JStack.java:86)
at sun.tools.jstack.JStack.runJStackTool(JStack.java:118)
at sun.tools.jstack.JStack.main(JStack.java:84)
Deadlock Detection:
No deadlocks found.
----------------- 2966 -----------------
0xffffe410 ????????
0x0804dd78 ContinueInNewThread + 0x88
0x080497f6 main + 0x276
0xb7dc90c0 __libc_start_main + 0xe0
----------------- 2968 -----------------
0xffffe410 ????????
0x2d3f57f0 ????????
address: 0x49bb8ce2 with alignment: 4
sun.jvm.hotspot.debugger.linux.x86.LinuxX86CFrame.sender(Lin uxX86CFrame.java:60)
at sun.jvm.hotspot.tools.PStack.run(PStack.java:161)
----------------- 2969 -----------------
0xffffe410 ????????
0x06310269 _ZN2os13PlatformEvent4parkEv + 0xb9
0x06373f61 _ZN13ObjectMonitor4waitExbP6Thread + 0x571
0x063718d2 _ZN18ObjectSynchronizer4waitE6HandlexP6Thread + 0x42
0x0626d90a JVM_MonitorWait + 0x1da
0xb5cc7f1d * java.lang.Object.wait(long) bci:0 (Interpreted frame)
0xb5cc0fcd * java.lang.Object.wait() bci:2 line:485 (Interpreted frame)
0xb5cc0fcd * java.lang.ref.Reference$ReferenceHandler.run() bci:46
line:116 (Interpreted frame)
0xb5cbe2cc <StubRoutines>
0x0621b25d _ZN9JavaCalls11call_helperEP9JavaValueP12methodHandleP17Java CallArgumentsP6Thread
+ 0x15d
0x0630f998 _ZN2os20os_exception_wrapperEPFvP9JavaValueP12methodHandleP1 7JavaCallArgumentsP6ThreadES1_S3_S5_S7_
+ 0x18
0x0621ab70 _ZN9JavaCalls12call_virtualEP9JavaValue11KlassHandle12symbol HandleS3_P17JavaCallArgumentsP6Thread
+ 0xa0
0x0621abfd _ZN9JavaCalls12call_virtualEP9JavaValue6Handle11KlassHandle1 2symbolHandleS4_P6Thread
+ 0x5d
0x0628b265 _Z12thread_entryP10JavaThreadP6Thread + 0x75
0x063a03dd _ZN10JavaThread3runEv + 0xfd
0x06310ac9 _Z10java_startP6Thread + 0x139
0xb7f1d3cb start_thread + 0xcb
----------------- 2970 -----------------
0xffffe410 ????????
0xb5cc0fcd * java.lang.ref.ReferenceQueue.remove(long) bci:44 line:116
(Interpreted frame)
0xb5cc0e67 * java.lang.ref.ReferenceQueue.remove() bci:2 line:132
(Interpreted frame)
0xb5cc0e67 * java.lang.ref.Finalizer$FinalizerThread.run() bci:3 line:159
(Interpreted frame)
+ 0x15d
+ 0x18
+ 0xa0
+ 0x5d
----------------- 2971 -----------------
0xffffe410 ????????
0x0630ddad _ZN2os11signal_waitEv + 0xd
0x0630aec8 _Z19signal_thread_entryP10JavaThreadP6Thread + 0x28
----------------- 2972 -----------------
0xffffe410 ????????
0x062fd09d _ZN7Monitor5IWaitEP6Threadx + 0xcd
0x062fd691 _ZN7Monitor4waitEblb + 0xd1
0x061a4c0f _ZN12CompileQueue3getEv + 0x5f
0x061a6374 _ZN13CompileBroker20compiler_thread_loopEv + 0x184
----------------- 2973 -----------------
0xffffe410 ????????
0x062fd7e1 _ZN7Monitor4waitEblb + 0x221
0x062e2be5 _ZN17LowMemoryDetector32low_memory_detector_thread_entryEP10 JavaThreadP6Thread
+ 0x85
----------------- 2974 -----------------
0xffffe410 ????????
0x0de54428 ????????
----------------- 2975 -----------------
0xffffe410 ????????
0x044bf5d8 ????????
sun.jvm.hotspot.debugger.UnmappedAddressException
at sun.jvm.hotspot.debugger.PageCache.checkPage(PageCache.java: 208)
at sun.jvm.hotspot.debugger.PageCache.getData(PageCache.java:63 )
at sun.jvm.hotspot.debugger.DebuggerBase.readBytes(DebuggerBase .java:205)
sun.jvm.hotspot.debugger.linux.LinuxDebuggerLocal.readCInteg er(LinuxDebuggerLocal.java:471)
----------------- 2976 -----------------
0xffffe410 ????????
0xb5cc0fcd *
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent()
bci:4 line:377 (Interpreted frame)
0xb5cc0e67 *
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run() bci:1
line:317 (Interpreted frame)
+ 0x15d
+ 0x18
+ 0xa0
+ 0x5d
----------------- 2977 -----------------
0xffffe410 ????????
0xb5cc0fcd *
0xb5cc0e67 *
+ 0x15d
+ 0x18
+ 0xa0
+ 0x5d
----------------- 2978 -----------------
0xffffe410 ????????
0x059d35c8 ????????
address: 0x49bb8d1d with alignment: 4
----------------- 2979 -----------------
0xffffe410 ????????
0xb5cc0fcd *
org.eclipse.swt.widgets.Synchronizer.syncExec(java.lang.Runn able) bci:138
line:185 (Interpreted frame)
0xb5cc0fcd *
org.eclipse.ui.internal.UISynchronizer.syncExec(java.lang.Ru nnable) bci:91
line:150 (Interpreted frame)
0xb5cc0fcd * org.eclipse.swt.widgets.Display.syncExec(java.lang.Runnable)
bci:108 line:4021 (Interpreted frame)
0xb5cc0fcd *
org.eclipse.ui.internal.StartupThreading.runWithoutException s(org.eclipse.ui.internal.StartupThreading$StartupRunnable)
bci:7 line:94 (Interpreted frame)
0xb5cc0fcd * org.eclipse.ui.internal.Workbench.init() bci:196 line:1358
(Interpreted frame)
0xb5cc0da1 *
org.eclipse.ui.internal.Workbench.access$32(org.eclipse.ui.i nternal.Workbench)
bci:1 line:1280 (Interpreted frame)
0xb5cc0da1 * org.eclipse.ui.internal.Workbench$57.run() bci:18 line:2283
(Interpreted frame)
+ 0x15d
+ 0x18
+ 0xa0
+ 0x5d
----------------- 2980 -----------------
0xffffe410 ????????
0xb5cc0fcd *
0xb5cc0fcd *
0xb5cc0fcd *
org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(org.eclipse.ui.internal.StartupThreading$StartupRunn able)
bci:7 line:50 (Interpreted frame)
0xb5cc0fcd *
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(ja va.lang.String,
org.eclipse.core.runtime.IAdaptable) bci:93 line:1040 (Interpreted frame)
0xb5cc0e67 * org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow()
bci:30 line:1829 (Interpreted frame)
0xb5cc0fcd *
org.eclipse.ui.internal.Workbench.access$27(org.eclipse.ui.i nternal.Workbench)
bci:1 line:1820 (Interpreted frame)
0xb5cc0fcd * org.eclipse.ui.internal.Workbench$45.run() bci:4 line:1780
(Interpreted frame)
0xb5cc14a9 * org.eclipse.ui.internal.Workbench.runStartupWithProgress(int ,
java.lang.Runnable) bci:75 line:1806 (Interpreted frame)
0xb5cc0fcd * org.eclipse.ui.internal.Workbench.openFirstTimeWindow()
bci:47 line:1778 (Interpreted frame)
0xb5cc0fcd *
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow() bci:7
line:190 (Interpreted frame)
0xb5cc14a9 * org.eclipse.ui.application.WorkbenchAdvisor$1.run() bci:89
line:788 (Interpreted frame)
+ 0x15d
+ 0x18
+ 0xa0
+ 0x5d
----------------- 2982 -----------------
0xffffe410 ????????
0xb5cc0fcd *
org.eclipse.jdt.internal.core.search.processing.JobManager.r un() bci:86
line:371 (Interpreted frame)
0xb5cc14a9 * java.lang.Thread.run() bci:11 line:619 (Interpreted frame)
+ 0x15d
+ 0x18
+ 0xa0
+ 0x5d
----------------- 2967 -----------------
0xb7f21d3a __pthread_getspecific_internal + 0x2a
0x063a7a01 _ZN18ThreadLocalStorage15get_thread_slowEv + 0x11
0x06311d54 JVM_handle_linux_signal + 0x14
0x0630ea68 _Z13signalHandleriP7siginfoPv + 0x18
0xffffe440 ????????
0x93b7a27f ????????
0x93b80b36 ????????
0x93fc52e8 ????????
0x0f00be0f ????????
address: 0xe0e80001 with alignment: 4
FUDForum. Page generated in 0.08838 seconds
