Home » Eclipse Projects » Eclipse Platform » Common Navigator Framework content extensions....
Common Navigator Framework content extensions.... [message #334912] Mon, 09 March 2009 18:23 Go to next message
Hey All,
I encountered a strange issue with Common Navigator Framework (CNF). I
configured the navigator view by following the blogs by Michael Elder:
http://scribbledideas.blogspot.com/2006/07/pdf-versions-now- available.html
The problem is that: each time the RCP program starts up, the resource
tree doesn't show up in my customized navigator view. But the
Content/Filter configurations are Okay.
If you right click in the navigator view, it brings up the resource tree.
The resource tree works fine with creating new file/projects. It only
happens when the RCP program starts up.
I know it is strange. Therefore, any clue and input is highly appreciated!
Thank you so much! Have a nice day!
Frank Du
Re: Common Navigator Framework content extensions.... [message #334914 is a reply to message #334912] Tue, 10 March 2009 00:59 Go to previous message
Make sure you do all of the stuff here:
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf_rcp.htm
Francis
Frank Du wrote:
> Hey All,
> Frank Du
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:Help how to implement refreshLocal
Next Topic:global action ...
Current Time: Sat Sep 13 02:24:05 EDT 2025
Powered by FUDForum. Page generated in 0.03108 seconds
