Home » Eclipse Projects » Eclipse Platform » dynamically updating plugin classpath
dynamically updating plugin classpath [message #334888] Fri, 06 March 2009 13:57 Go to next message
Is it possible to modify the classpath of a plugin dynamically.
I make use of some external jar files in my application, for which, I make
use of the
external:$LOCATION$/xxx.jar
where $LOCATION is an environment variable, which works fine.
I now have a situation where the user can specify a diffrent location for
the jar file while using the application. I need to figure out how to
replace the old jar with the new in the plgin CP.
Is there an api to access the manifest file and update the classpath
entry? If that is possible, maybe I could reload the plugin and the new
classpath would be effective.
Any suggestions?
Jeevan
Re: dynamically updating plugin classpath [message #334889 is a reply to message #334888] Fri, 06 March 2009 15:11 Go to previous messageGo to next message
Are they pointing to a different location so they can pick up a later
version? Updating libs by dynamically loading bundles with different
versions is handled relatively well by the OSGi framework.
You might have to uninstall your bundle, write a new manifest, and then
re-install your newly updated bundle.
I have a bad example of supplying multiple versions of a "lib" to the
system attached to https://bugs.eclipse.org/bugs/show_bug.cgi?id=263723
PW
Paul Webster
Re: dynamically updating plugin classpath [message #334899 is a reply to message #334889] Mon, 09 March 2009 09:45 Go to previous messageGo to next message
The way it is now, I can change the environment variable and it works fine
(but, I need to exit the application). I am trying to do this without
exiting the application, the reason why I was looking to update the
manifest file.
With you solution, I still need to exit the application.
Jeevan
> PW
Re: dynamically updating plugin classpath [message #334900 is a reply to message #334899] Mon, 09 March 2009 10:02 Go to previous messageGo to next message
> fine (but, I need to exit the application). I am trying to do this
> without exiting the application, the reason why I was looking to update
> the manifest file.
why? If you uninstall the bundle it's gone ... then you re-install the
bundle with the updated variable. I would imagine if you are using
system properties, uninstalling, change the property, and re-installing
would allow the system property to be read a second time.
Nothing in my post or example said "and restart the workbench" :-)
PW
Paul Webster
Re: dynamically updating plugin classpath [message #334934 is a reply to message #334900] Tue, 10 March 2009 13:32 Go to previous messageGo to next message
I tried the solution, but, Eclipse does not let the user change system
properties programmatically.
>> the manifest file.
> PW
Re: dynamically updating plugin classpath [message #335309 is a reply to message #334934] Tue, 31 March 2009 14:09 Go to previous message
In what way? System.setProperty(*) thows a SecurityException?
PW
Paul Webster
Previous Topic:Adding filter in Project Explorer
Next Topic:LTK copy refactoring
Current Time: Sat Nov 08 17:24:44 EST 2025
Powered by FUDForum. Page generated in 0.04072 seconds
