Home » Eclipse Projects » Eclipse Platform » How to add the red wave line?
How to add the red wave line? [message #334878] Thu, 05 March 2009 16:57 Go to next message
Hey All,
We build a XML editor. If a line of text is not valid, a problem marker
(red cross) can be added to the vertical ruler.
However, the red wave line is missing. Originally it underlines the XML
content that is invalid.
How can I bring them back? What class or method is responsible for
creating such wave lines? Must quick-fix work with it?
Any input or hints will be appreciated. Thank you so much!
Frank
Re: How to add the red wave line? [message #334890 is a reply to message #334878] Fri, 06 March 2009 20:16 Go to previous messageGo to next message
Hi Frank,
Did you missed the attributes IMarker.CHAR_START and IMarker.CHAR_END when
you create the problem marker?
Sharon
http://www.eclaxy.com
Re: How to add the red wave line? [message #334913 is a reply to message #334890] Mon, 09 March 2009 19:57 Go to previous messageGo to next message
Hi Sharon,
Thank you so much for the hints. I checked your suggestions through
debugging. But the validation marker is created by child class of WTP XML
editor. It uses a different way to mark out the offset and length.
I figured out the line is called: Squiggle line. The related settings are:
SQUIGGLE_SELECTION_STRATEGY_ATTRIBUTE
SQUIGGLE_NAME_OR_VALUE_ATTRIBUTE
from class
org.eclipse.wst.xml.core.internal.validation.core.AbstractNe stedValidator
However, I haven't understood how it works to set up squiggle information.
It seems more like a configuration problem in my code. Any clue about the
issue?
Thanks a lot in advance!
Frank Du
Sharon F wrote:
> Hi Frank,
> Sharon
Re: How to add the red wave line? [message #334915 is a reply to message #334913] Tue, 10 March 2009 02:55 Go to previous messageGo to next message
Hi Frank,
Sorry but I know nothing about WTP. Maybe someone else here could help you.
Good luck!
Sharon
Re: How to add the red wave line? [message #334924 is a reply to message #334915] Tue, 10 March 2009 10:20 Go to previous message
Hey Sharon,
Thank you so much for the reply! You do remind of another newsgroup to
better address this issue. I have post the question to wtp.webtools. Thank
you so much!
Best Regards,
Frank
Previous Topic:auto code formatting
Next Topic:Common Navigator ClassCastException
Current Time: Thu Jul 17 22:36:12 EDT 2025
Powered by FUDForum. Page generated in 0.07810 seconds
