Home » Eclipse Projects » Eclipse Platform » wizards
wizards [message #334869] Wed, 04 March 2009 17:46 Go to next message
Hi All,
Is it possible to launch a wizard defined in another plugin just using
its ID ?
thx
Re: wizards [message #334873 is a reply to message #334869] Thu, 05 March 2009 09:55 Go to previous message
You would create and execute a paramterized command for the wizards.
id = org.eclipse.ui.newWizard
id = org.eclipse.ui.file.export
id = org.eclipse.ui.file.import
And include the page ID you want it to open with (I assume that's what
you are asking).
The other alternative is to use the ActionFactory actions for IMPORT,
EXPORT, or NEW but I don't believe they allow you to specify a page.
PW
Paul Webster
Previous Topic:Common Navigator tutorial
Next Topic:CNF
Current Time: Fri Jul 18 01:26:14 EDT 2025
Powered by FUDForum. Page generated in 0.06412 seconds
