Home » Eclipse Projects » Eclipse Platform » Populating a table asynchronously
Populating a table asynchronously [message #334844] Mon, 02 March 2009 23:39 Go to next message
Hi all,
I have a problem. I've been up all night trying to create a simple dialog
containing a table that will fill up as a background job supplies the info.
To be more precise, the job does a svn checkout and I want to show the
progress (files downloaded so far) in a table. Problem is I don't know how
to set the input for the table's content provider without freezing the UI.
An example would help a lot... thanks!
Re: Populating a table asynchronously [message #334845 is a reply to message #334844] Tue, 03 March 2009 02:37 Go to previous messageGo to next message
Andrei Serea wrote:
> Hi all,
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet045TableViewerFillFromBackgroundThread.java ?view=markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet046UpdateViewerFromBackgroundThread.java?vi ew=markup
The above links should be helpful.
And http://wiki.eclipse.org/index.php/JFaceSnippets
Hitesh
Re: Populating a table asynchronously [message #334846 is a reply to message #334845] Tue, 03 March 2009 05:18 Go to previous messageGo to next message
Thanks Hitesh. It is very close to what I needed, but not exactly.
In those examples the input for the viewer comes directly from the same
thread as the one that updates the viewer.
In my case the input is supplied asynchronously by a non-ui thread, so I
cannot update the viewer from that thread (i get a invalid thread access
exception). The only way I imagine is to listen for changes in the ui
thread. But listening, although done with semaphores in a async run from
the ui thread, it still freazez the ui.
I'm out of ideas...almost. I'm gonna try the Realm and IObservable api
right now.
But I appreciate any guiding.
Thanks a lot!
Re: Populating a table asynchronously [message #334847 is a reply to message #334846] Tue, 03 March 2009 05:43 Go to previous messageGo to next message
This is not correct! The example uses a TimerTask which is a none-ui
thread and to sync back it uses the Display#asyncExec!
Tom
> right now.
> Thanks a lot!
Re: Populating a table asynchronously [message #334851 is a reply to message #334847] Tue, 03 March 2009 08:22 Go to previous messageGo to next message
You are right. The only thing I might add is that in the example, syncExec
is called instead of asyncExec.
I had no idea one could access the shell and display from a non-ui thread.
it still doesn't make sense.
But now, after digging for a couple of hours into realms, I am quite
curious. Can anyone point me towards a place where I could read more about
realms (except the existing snippets and docs from the eclipse site)?
Anywho, thanks a million!!!
Re: Populating a table asynchronously [message #334855 is a reply to message #334851] Tue, 03 March 2009 11:40 Go to previous message
Originally posted by: wegener.cboenospam.com
"Andrei Serea" <andrei.serea@gmail.com> wrote in message
news:32e185bd5fe6d832add0cd42d8e65ed0$1@www.eclipse.org...
You can't access the shell and display from a non-ui thread. The syncExec
method still calls the run method on the Display's UI thread. The
difference between async and sync is the point that the call returns to the
non-ui thread. For asyncExec, the call returns after the runnable is
scheduled on the UI thread. With syncExec, the method schedules the
runnable on the UI thread and then waits for the runnable to complete. This
blocks the non-UI thread until the runnable completes. Both calls involve
two separate threads (assuming that the sync/asyncExec call isn't made from
the UI thread.)
Previous Topic:Ganymede SR2 update updates eclipse.ini !
Next Topic:Switch perspective open Welcome page
Current Time: Wed Nov 19 06:02:03 EST 2025
Powered by FUDForum. Page generated in 0.05118 seconds
