Re: Launch default in Eclipse IDE [message #1796647 is a reply to message #1796633] |
Tue, 16 October 2018 21:10 |
Stephan Herrmann Messages: 1853 Registered: July 2009 |
Looking at this error:
java.lang.NoSuchMethodError: gObjectClass_finalize
at org.eclipse.swt.internal.gtk.GTK._gtk_widget_destroy(Native Method)
at org.eclipse.swt.internal.gtk.GTK.gtk_widget_destroy(GTK.java:8591)
at org.eclipse.swt.widgets.Widget.destroyWidget(Widget.java:464)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1193)
at org.eclipse.swt.widgets.Control.release(Control.java:4302)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:499)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:2740)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:681)
at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:1338)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1969)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:6468)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5904)
at org.eclipse.swt.internal.gtk.GTK._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.GTK.gtk_main_do_event(GTK.java:4084)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1383)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:1626)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4516)
this appears not to be a Java or JDT problem, but an SWT problem. Still it could be caused by an inconsistent installation (apparently java and native parts of SWT are not compatible).
Seeing your mention of "32 bit": are you sure you installed the 32-bit version of Eclipse?
Are you aware that Eclipse will gradually drop support for 32 bit in the near future?
[Updated on: Tue, 16 October 2018 21:11] Report message to a moderator
FUDForum. Page generated in 0.02981 seconds
