Home » Eclipse Projects » Nebula » Could we add text alignment in grid varying by row
Could we add text alignment in grid varying by row [message #33953] |
Thu, 03 May 2007 10:53  |
Originally posted by: slorenc.infogix.com
I would like to propose adding ability to vary column alignment in grid
control. Currently you can set it once for the entire column but if you
want different alignment in each cell of a single column you can't do it.
Looking at GridItem implementation I think it could be done in a similar
manner to how the text, fonts and backgrounds are saved for each column.
Then the DefaultCellRenderer could retrieve alignment from item instead of
from itself.
Swavek
Re: Could we add text alignment in grid varying by row [message #34025 is a reply to message #34007] |
Thu, 03 May 2007 15:43   |
Chris,
I tried adding it to the CellRenderer but realized that cell renderer would
have to hold this data for each row in a column. It will not scale if you
have large number of rows. GridItem is the object which holds style data
for the entire row so it is logical to place it there. Plus if virtual
management of rows is implemented fully in Grid and I would like to take
advantage of it I would have to add virtual managment of alignment
information inside CellRenderer as well.
I got the code working and could volunter if you are intested. It's a 3
line change in DefaultCellRender and a few set/get methods in GridItem.
There is another change to DefaultColumnHeaderRender that has to do with
alignment. I think this one is easy to add and makes the column header more
esthetically pleasing. I think it looks more esthetic to center text in the
header of the column rather than left justify it. A simple change to the
DefaultColumnHeaderRenderer would make it possible to change the default
alignment to center (or even right justified). What do you think abou this
change? After adding get/setTextAlignment all is needed is this code in
paint method
// draw header text
int textX = getBounds().x + x + pushedDrawingOffset;
int textY = y + pushedDrawingOffset;
// shorten header text to 'My header text...' to fit within
specified column width
String headerShortString = TextUtils.getShortString(gc,
column.getText(), width);
int textWidth = gc.stringExtent(headerShortString).x;
if ((textAlignment & SWT.CENTER) != 0)
textX += (width - textWidth) / 2;
else if ((textAlignment & SWT.RIGHT) != 0)
textX += width - textWidth;
gc.drawString(headerShortString, textX, textY, true);
replacing this code around line 126
gc.drawString(TextUtils.getShortString(gc, column.getText(), width),
getBounds().x + x + pushedDrawingOffset,
y + pushedDrawingOffset,true);
Swavek
"Chris Gross" <chris.gross@us.ibm.com> wrote in message
news:f1d23c$fqe$2@build.eclipse.org...
> Hi Swavek,
> The feature could be added as you suggest but I'm not sure its something
> that many people would use. I will consider adding it in the future but
> I'm wary of adding feature upon feature that simply make the Grid more
> complex. You can always create your own cell renderer to have this
> feature in your own app.
> -Chris
>> of from itself.
>> Thanks,
>> Swavek
Re: Could we add text alignment in grid varying by row [message #34052 is a reply to message #34025] |
Thu, 03 May 2007 16:21   |
Hi Swavek,
If you wanted to add this feature in your own renderer you would still
want to keep the value of the property on each GridItem. You could
store it in the GridItem's data map (i.e. setData(key,value),
getData(key,value)).
I'd be interested in any patch that you can contribute but please post
it to a bugzilla entry and please use a patch file (i.e. CVS Team
provider unified patch). But I will have to think about whether to
commit each patch. There's a sweet spot somewhere between adding all
functionality anyone could ever want in the Grid and just making it
extensible so if you want the behavior you can add it yourself.
-Chris
> Chris,
> paint method
> // draw header text
> Swavek
>> Hi Swavek,
>> Regards,
>> -Chris
>>> of from itself.
>>> Thanks,
>>> Swavek
Re: Could we add text alignment in grid varying by row [message #34082 is a reply to message #34052] |
Thu, 03 May 2007 16:56   |
I am now trying to use GridItem's data map because I decided to implement
the cell renderer myself. This way I can alter not just alignment but also
how the bounding rectangle is drawn.
My goal is to display Excel's spreadsheet in a grid as closely as possible
(fonts, alignment, background and text color) etc. That's why I wanted to
control alignment on per cell rather than per column basis.
Thanks for suggestion.
Swavek
news:f1dg7c$t45$1@build.eclipse.org...
> Hi Swavek,
> want to keep the value of the property on each GridItem. You could store
> I'd be interested in any patch that you can contribute but please post it
> to a bugzilla entry and please use a patch file (i.e. CVS Team provider
> unified patch). But I will have to think about whether to commit each
> patch. There's a sweet spot somewhere between adding all functionality
> anyone could ever want in the Grid and just making it extensible so if you
> -Chris
>> Chris,
>> would have to hold this data for each row in a column. It will not scale
>> if you have large number of rows. GridItem is the object which holds
>> style data for the entire row so it is logical to place it there. Plus
>> if virtual management of rows is implemented fully in Grid and I would
>> like to take advantage of it I would have to add virtual managment of
>> alignment information inside CellRenderer as well.
>> more esthetically pleasing. I think it looks more esthetic to center
>> text in the header of the column rather than left justify it. A simple
>> change to the DefaultColumnHeaderRenderer would make it possible to
>> change the default alignment to center (or even right justified). What
>> do you think abou this change? After adding get/setTextAlignment all is
>> needed is this code in paint method
>> // draw header text
>> width),
>> Swavek
>>> Hi Swavek,
>>> Regards,
>>> -Chris
>>>> you want different alignment in each cell of a single column you can't
>>>> do it.
>>>> similar manner to how the text, fonts and backgrounds are saved for
>>>> each column. Then the DefaultCellRenderer could retrieve alignment from
>>>> item instead of from itself.
>>>> Thanks,
>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #34116 is a reply to message #34082] |
Fri, 04 May 2007 11:16   |
Post some screenshots when you're done. I'd like to see it!
-Chris
> Swavek
>> Hi Swavek,
>> Regards,
>> -Chris
>>> Chris,
>>> // draw header text
>>> width),
>>> Swavek
>>>> Hi Swavek,
>>>> Regards,
>>>> -Chris
>>>>> do it.
>>>>> Thanks,
>>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #34825 is a reply to message #34116] |
Tue, 15 May 2007 13:43   |
Chris,
What are the chances of adding variable row heights to this upcoming release
of Grid? I had to modify Grid class extensively to get it to work but would
prefer if it was done by you so I don't have to deal with licensing issues.
Swavek
news:f1finl$p1c$1@build.eclipse.org...
> -Chris
>> also how the bounding rectangle is drawn.
>> possible (fonts, alignment, background and text color) etc. That's why I
>> wanted to control alignment on per cell rather than per column basis.
>> Swavek
>>> Hi Swavek,
>>> Regards,
>>> -Chris
>>>> Chris,
>>>> scale if you have large number of rows. GridItem is the object which
>>>> holds style data for the entire row so it is logical to place it there.
>>>> Plus if virtual management of rows is implemented fully in Grid and I
>>>> would like to take advantage of it I would have to add virtual
>>>> managment of alignment information inside CellRenderer as well.
>>>> 3 line change in DefaultCellRender and a few set/get methods in
>>>> GridItem.
>>>> with alignment. I think this one is easy to add and makes the column
>>>> header more esthetically pleasing. I think it looks more esthetic to
>>>> center text in the header of the column rather than left justify it. A
>>>> simple change to the DefaultColumnHeaderRenderer would make it possible
>>>> to change the default alignment to center (or even right justified).
>>>> What do you think abou this change? After adding get/setTextAlignment
>>>> all is needed is this code in paint method
>>>> // draw header text
>>>> width),
>>>> Swavek
>>>>> Hi Swavek,
>>>>> something that many people would use. I will consider adding it in
>>>>> the future but I'm wary of adding feature upon feature that simply
>>>>> make the Grid more complex. You can always create your own cell
>>>>> renderer to have this feature in your own app.
>>>>> Regards,
>>>>> -Chris
>>>>>> grid control. Currently you can set it once for the entire column
>>>>>> but if you want different alignment in each cell of a single column
>>>>>> you can't do it.
>>>>>> from item instead of from itself.
>>>>>> Thanks,
>>>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #34899 is a reply to message #34825] |
Tue, 15 May 2007 16:26  |
I will not be able to add that feature soon. If your code is good
quality and takes into account all the features of Grid then I'd
consider applying it. If you're interested in this, first step is to
create a bugzilla entry and attach a patch.
-Chris
> Chris,
> Swavek
>> -Chris
>>> Swavek
>>>> Hi Swavek,
>>>> Regards,
>>>> -Chris
>>>>> Chris,
>>>>> GridItem.
>>>>> // draw header text
>>>>> width),
>>>>> Swavek
>>>>>> Hi Swavek,
>>>>>> Regards,
>>>>>> -Chris
>>>>>>> you can't do it.
>>>>>>> Thanks,
>>>>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #581763 is a reply to message #33953] |
Thu, 03 May 2007 12:20  |
Hi Swavek,
-Chris
> from itself.
> Swavek
Re: Could we add text alignment in grid varying by row [message #581787 is a reply to message #34007] |
Chris,
paint method
// draw header text
Swavek
> Hi Swavek,
> -Chris
>> of from itself.
>> Thanks,
>> Swavek
Re: Could we add text alignment in grid varying by row [message #581830 is a reply to message #34025] |
Hi Swavek,
-Chris
> Chris,
> paint method
> // draw header text
> Swavek
>> Hi Swavek,
>> Regards,
>> -Chris
>>> of from itself.
>>> Thanks,
>>> Swavek
Re: Could we add text alignment in grid varying by row [message #581853 is a reply to message #34052] |
Swavek
> Hi Swavek,
> -Chris
>> Chris,
>> // draw header text
>> width),
>> Swavek
>>> Hi Swavek,
>>> Regards,
>>> -Chris
>>>> do it.
>>>> Thanks,
>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #581873 is a reply to message #34082] |
-Chris
> Swavek
>> Hi Swavek,
>> Regards,
>> -Chris
>>> Chris,
>>> // draw header text
>>> width),
>>> Swavek
>>>> Hi Swavek,
>>>> Regards,
>>>> -Chris
>>>>> do it.
>>>>> Thanks,
>>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #582317 is a reply to message #34116] |
Chris,
Swavek
> -Chris
>> Swavek
>>> Hi Swavek,
>>> Regards,
>>> -Chris
>>>> Chris,
>>>> GridItem.
>>>> // draw header text
>>>> width),
>>>> Swavek
>>>>> Hi Swavek,
>>>>> Regards,
>>>>> -Chris
>>>>>> you can't do it.
>>>>>> Thanks,
>>>>>> Swavek
Re: Could we add text alignment in grid varying by row [message #582355 is a reply to message #34825] |
-Chris
> Chris,
> Swavek
>> -Chris
>>> Swavek
>>>> Hi Swavek,
>>>> Regards,
>>>> -Chris
>>>>> Chris,
>>>>> GridItem.
>>>>> // draw header text
>>>>> width),
>>>>> Swavek
>>>>>> Hi Swavek,
>>>>>> Regards,
>>>>>> -Chris
>>>>>>> you can't do it.
>>>>>>> Thanks,
>>>>>>> Swavek
Current Time: Thu Jul 17 22:06:32 EDT 2025
Powered by FUDForum. Page generated in 0.09923 seconds
