Home » Eclipse Projects » Eclipse Platform » [JFace,Databinding]BooleanCellEditor not updating model
[JFace,Databinding]BooleanCellEditor not updating model [message #334748] Wed, 25 February 2009 19:00 Go to next message
I am trying to use BooleanCellEditor, that I found in JFace snippets, with
databinding to an EMF model object using ObservableValueEditingSupport.
But I think it is not updating the model object and also not working well
its LabelProvider. I tried to debug this and I think it is something about
deactivating. It just not triggers editor update so editingsupport is not
working to update. Well, I looked at ComboboxCellEditor code and updated
BooleanCellEditor deactivation with following:
Object newValue = doGetValue();
markDirty();
boolean isValid = isCorrect(newValue);
setValueValid(isValid);
fireApplyEditorValue();
deactivate();
Well it seems to update the model object now. But the problem is that, if I
enter editing mode and leave without changing the checkbox state, after
exiting editing mode LabelProvider does not show anything. I am not sure if
it is even called.
Can someone help me with this?
Tankut Koray
Re: [JFace,Databinding]BooleanCellEditor not updating model [message #334768 is a reply to message #334748] Thu, 26 February 2009 11:16 Go to previous message
Could you provide a standalone snippet demonstrating the problem you're
seeing? This is tough to visualize
Matthew
Tankut Koray wrote:
> with databinding to an EMF model object using
> well its LabelProvider. I tried to debug this and I think it is
> something about deactivating. It just not triggers editor update so
> editingsupport is not working to update. Well, I looked at
> ComboboxCellEditor code and updated BooleanCellEditor deactivation with
> following:
> markDirty();
> deactivate();
> if I enter editing mode and leave without changing the checkbox state,
> after exiting editing mode LabelProvider does not show anything. I am
> not sure if it is even called.
> Tankut Koray
Previous Topic:Loading xml files from jars at the runtime
Next Topic:[DataBinding] Best pratice to observe instance model (Bean, EMF..) which change
Current Time: Mon Jul 21 22:16:24 EDT 2025
Powered by FUDForum. Page generated in 0.03399 seconds
