Home » Eclipse Projects » Eclipse Platform » Command Framework in custom editor
Command Framework in custom editor [message #334648] Mon, 23 February 2009 04:26 Go to next message
I have build a custom editor (based on a TreeViewer) with a context menu
that is currently generated programatically. After converting some other
part of my code to use the command framework, I'd like to use the
command framework in my editor as well. However I was unable to find any
information, as to how I might declaratively specify the commands.
Documentation on ECF appears to be a bit thin anyway (one wiki page that
I know of). Where can I look for further reading about context menus in
custom editors?
As an added complication: there is one submenu that has to be created
programmatically at runtime (using model data). Can this be achieved
when using ECF?
Damian Philipp
Re: Command Framework in custom editor [message #334660 is a reply to message #334648] Mon, 23 February 2009 14:12 Go to previous messageGo to next message
Damian Philipp wrote:
> Hello,
There are a couple of wiki's mentioned in my sig, plus examples in the
org.eclipse.ui.examples.contributions plugin (available in cvs
:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse )
PW
Paul Webster
Re: Command Framework in custom editor [message #334672 is a reply to message #334660] Tue, 24 February 2009 05:12 Go to previous message
thank you for your reply.
I have seen those sites already. They were very helpful in integrating
commands in other popup menus (namely that of the Project Explorer).
But they don't say anything about how to get popup menus working on
custom parts.
This on the other hand was very helpful. For future reference, the
following code enabled PCF popup menus on the viewer in my editor:
MenuManager contextMenu = new MenuManager();
contextMenu.setRemoveAllWhenShown(true);
getSite().registerContextMenu(contextMenu, viewer);
Control control = viewer.getControl();
Menu menu = contextMenu.createContextMenu(control);
control.setMenu(menu);
Perhaps this could be added to the wiki?
Now there is just one other problem - other plugin contributions are
showing up on my editor, where it just doesn't make any sense. Example:
How do you create a "Run configuration" for a string that you are about
to translate?
Oh well, after all this digging I might just have to go back to
programatically creating actions.
But thanks to you anyway!
Damian Philipp
Previous Topic:How do I find new Extension Points?
Next Topic:How do I activate the Quick Fix command in a context menu?
Current Time: Fri Jul 18 05:43:51 EDT 2025
Powered by FUDForum. Page generated in 1.09956 seconds
