Home » Eclipse Projects » Eclipse Platform » The selection did not contain anything that can be run on a server
The selection did not contain anything that can be run on a server [message #334640] Sat, 21 February 2009 11:49 Go to next message
trying to run an application by pressing [Ctrl][F11] sometimes I get the
error message
This error message also occurs, when there is nothing selected.
When I repeat to press [Ctrl][F11] the application is launched successfully.
On which circumstances appears that error message after pressing
[Ctrl][F11], i. e. what is the reason for this error?
How can this error message be avoided?
Currently I use Eclipse 3.3.2.
Thomas Wiedmann
Re: The selection did not contain anything that can be run on a server [message #334644 is a reply to message #334640] Mon, 23 February 2009 00:51 Go to previous messageGo to next message
Have a look at the Run/Debug->Launching->Launch Operation preferences. That
should explain you. I set it to "Always launch the previously launched
application". It works well for me
- Prakash
http://blog.eclipse-tips.com
Re: The selection did not contain anything that can be run on a server [message #1766555 is a reply to message #334644] Fri, 23 June 2017 00:05 Go to previous message
 is currently offline Friend
eclipse Right-click project -> properties -> Project Facets -> Runtimes -> checked "Apache Tomcat vX.0"(your tomcat version) -> Apply -> finish. https://stackoverflow.com/questions/43186315/tomcat-404-error-the-origin-server-did-not-find-a-current-representation-for-th
[Updated on: Fri, 23 June 2017 00:06]
Previous Topic:How to disable debugging underlying classes (change the source attachment)
Next Topic:Click 'Help->Help Contents', Eclipse is crashed in Linux
Current Time: Fri Jul 18 07:05:32 EDT 2025
Powered by FUDForum. Page generated in 0.10531 seconds
