(EMF generated) editor plugin does not run (without reported errors) [message #334601] |
Thu, 19 February 2009 14:34 |
Originally posted by: K_Juenemann.gmx.de
I created a very simple Final State Machine model (ecore) and let EMF
generate code for it ("Generate All"), cause I wanted to try out
openArchitectureWare. So I tested the generated plugins (via "Run as")
and everything worked fine. But when I export all 4 plugins and copy the
created jars to eclipse/dropins/ and restart eclipse, the plugins are
*not* loaded. However, there are no compilation errors, and the plugins
do run via "Runs as" as mentioned above. I also did not change anything
in the generated projects.
I then deleted the ./metadata/.log file and started eclipse with -clean
-debug. The plugins are still not loaded. See
http://nopaste.php-q.net/154543 for the log file contents: my plugins
(*.fsm.*) are not mentioned here.
Any suggestions what might be the problem???
Konrad
Eclipse version:
Version: 3.4.1
Build id: M20080911-1700
FUDForum. Page generated in 0.06902 seconds
