Home » Eclipse Projects » Eclipse Platform » How do I activate the Quick Fix command in a context menu?
| How do I activate the Quick Fix command in a context menu? [message #334600] |
Thu, 19 February 2009 13:42  |
Hi all,
I am attempting to add quick fix to a SourceViewer per the instructions in
http://wiki.eclipse.org/FAQ_How_do_I_implement_Quick_Fixes_f or_my_own_language%3F,
i.e.:
<extension
point="org.eclipse.ui.ide.markerResolution">
<markerResolutionGenerator
class="eu.etaxonomy.taxeditor.tests.QuickFixer"
markerType="org.eclipse.core.resources.problemmarker">
</markerResolutionGenerator>
</extension>
I have added a menu to my StyledText widget with this plugin.xml code:
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:eu.etaxonomy.taxeditor.tests.view">
<command
commandId=" org.eclipse.jdt.ui.edit.text.java.correction.assist.proposal s "
</menuContribution>
</extension>
and this:
MenuManager menuMgr = new MenuManager();
menuMgr.add(new
GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
getSite().registerContextMenu(menuMgr, sourceViewer);
Control control = sourceViewer.getTextWidget();
Menu menu = menuMgr.createContextMenu(control);
control.setMenu(menu);
My StyledText widget contains an annotation that extends MarkerAnnotation
and shows its IMarker.MESSAGE attribute when hovering over the
SourceViewer's ruler.
So far so good.
But when I right-click inside the StyledText widget to look at the menu,
"Quick Fix Ctrl+1" is grayed-out / deactivated. Similarly, Ctrl+1 does
nothing.
It seems as if the SourceViewer is failing some kind of context test for
activation. I've poked around in the plugin.xml's of the required plugins,
and I can't find the appropriate handler for the assist command, nor can I
find where the marker resolution generator is called.
Any ideas?
Many thanks in advance!
| Re: How do I activate the Quick Fix command in a context menu? [message #334618 is a reply to message #334611] |
Fri, 20 February 2009 10:01   |
Daniel Megert wrote:
>> However, "Quick Fix Ctrl+1" in the SourceViewer context menu is still
>> disabled. Where exactly does the editor framework check for the
>> content assistant?
> If you use/subclass one of the editors you get it for free, otherwise
> you have to create and connect an action that then invokes the
> corresponding operation on the source viewer.
My question is then, what is the action / handler that the editors use for
quick assist? My goal is to use the exact same presentation format the IDE
uses to display the results of my custom IMarkerResolutionGenerator.
>> And out of curiosity, where is the key binding to Ctrl-1 set?
> In plugin.xml where the command is defined.
Yes, but not in my project's plugin.xml - I have looked through the
plugin.xml files of the various plugins my project references, and I can't
find it. If I could find this, then I could presumably find the action /
handler used by the default editor, and adapt accordingly.
Thanks for patiently bearing with me,
Pepe
| Re: How do I activate the Quick Fix command in a context menu? [message #334656 is a reply to message #334618] |
Mon, 23 February 2009 10:52   |
>>> still disabled. Where exactly does the editor framework check for
>>> the content assistant?
> for quick assist? My goal is to use the exact same presentation format
> the IDE uses to display the results of my custom
> can't find it. If I could find this, then I could presumably find the
> action / handler used by the default editor, and adapt accordingly.
See: /org.eclipse.ui.ide/plugin.xml
Dani
> Pepe
| Re: How do I activate the Quick Fix command in a context menu? [message #334673 is a reply to message #334656] |
Tue, 24 February 2009 07:06  |
OK, finally got all this working on a very rough test basis, and thought
I'd put the code here since Lord knows there isn't much else out there!
1. Hover over ruler shows marker text "Your blablabla don't work."
2. Hover over red-squigglied annotation shows "Your blablabla don't work."
followed by "2 quick fixes available" and 2 quick fix proposals. Clicking
on either proposal shows a "not yet implemented" dialog.
3. Both Control-1 and the right-click context menu inside the SourceViewer
show the 2 quick fix proposals in a white popup and, after a slight delay,
in a yellow popup with further information ("Problem description: Your
blablabla don't work.").
Hope someone finds this useful:
CLASS VIEW extends VIEWPART
public class View extends ViewPart {
private TextViewer text;
private StyledText styledText_2;
private StyledText styledText;
public static final String ID = "eu.etaxonomy.taxeditor.tests.view";
private SourceViewer sourceViewer;
public void createPartControl(final Composite parent) {
// Create annotation model
AnnotationModel model = new
ResourceMarkerAnnotationModel(ResourcesPlugin.getWorkspace() .getRoot());
// Create vertical ruler
final IVerticalRuler ruler = new Ruler(16);
// Create source viewer
sourceViewer = new SourceViewer(composite, ruler, SWT.WRAP |
SWT.MULTI | SWT.RESIZE);
// Add model to viewer
sourceViewer.setDocument(new Document("bla bla bla bla bla bla bla
bla bla bla bla bla bla "), model);
createAnnotationPainter();
// Configure viewer
ViewerConfiguration config = new ViewerConfiguration();
sourceViewer.configure(config);
for (String contentType :
config.getConfiguredContentTypes(sourceViewer)) {
config.getConfiguredTextHoverStateMasks(sourceViewer,
contentType);
// Create annotation that implements IAnnotationPresentation.
MarkerAnnotation annotation = null;
try {
IMarker marker =
ResourcesPlugin.getWorkspace().getRoot().createMarker(IMarke r.PROBLEM);
marker.setAttribute(IMarker.MESSAGE, "Your blablabla don't
work.");
// Note that hover text is retrieved from marker's text, not
annotation's
annotation = new MarkerAnnotation(marker);
annotation.setQuickFixable(true);
} catch (CoreException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
// Add annotation to model - it should then show up in the ruler
model.addAnnotation(annotation, new Position(0,5));
// register context menu
menuMgr.add(new
public void showPossibleQuickAssists() {
sourceViewer.getQuickAssistAssistant().showPossibleQuickAssi sts();
private void createAnnotationPainter(){
// Annotations section
IAnnotationAccess fAnnotationAccess = new
DefaultMarkerAnnotationAccess();
// To paint the annotations
AnnotationPainter annotationPainter = new
AnnotationPainter(sourceViewer, fAnnotationAccess);
// Add ability to paint red squigglies
annotationPainter.addAnnotationType(AnnotationWithMarker.INT ERNAL_ANNOTATION);
annotationPainter.setAnnotationTypeColor(AnnotationWithMarke r.INTERNAL_ANNOTATION,
new Color(Display.getDefault(), new RGB(255, 0, 0)));
sourceViewer.addPainter(annotationPainter);
CLASS VIEWERCONFIGURATION extends SOURCEVIEWERCONFIGURATION
@SuppressWarnings("restriction")
public class ViewerConfiguration extends SourceViewerConfiguration {
private IQuickAssistAssistant quickAssistAssistant = new
QuickAssistAssistant();
public IQuickAssistAssistant getQuickAssistAssistant(ISourceViewer
sourceViewer) {
quickAssistAssistant.setQuickAssistProcessor(new
IQuickAssistProcessor() {
public boolean canAssist(
IQuickAssistInvocationContext invocationContext) {
// TODO Auto-generated method stub
return false;
public boolean canFix(Annotation annotation) {
if (annotation instanceof MarkerAnnotation) {
return ((MarkerAnnotation)
annotation).isQuickFixable();
return false;
public ICompletionProposal[] computeQuickAssistProposals(
* TextInvocationContext - length, offset, and sourceviewer
ISourceViewer viewer= invocationContext.getSourceViewer();
int documentOffset= invocationContext.getOffset();
ICompletionProposal proposal1 = null;
ICompletionProposal proposal2 = null;
Iterator<?> iter =
viewer.getAnnotationModel().getAnnotationIterator();
while (iter.hasNext()) {
Annotation annotation = (Annotation) iter.next();
proposal1 = new MarkerResolutionProposal(
new QuickFix("proposal1"),
((MarkerAnnotation) annotation).getMarker());
proposal2 = new MarkerResolutionProposal(
new QuickFix("proposal2"),
return new ICompletionProposal[] { proposal1, proposal2 };
public String getErrorMessage() {
return null;
quickAssistAssistant.setInformationControlCreator(
getInformationControlCreator(sourceViewer));
return quickAssistAssistant;
private IAnnotationHover annotationHover = new
DefaultAnnotationHover();
public IAnnotationHover getAnnotationHover(ISourceViewer sourceViewer)
return annotationHover;
public ITextHover getTextHover(ISourceViewer sourceViewer, String
contentType) {
return new AbstractAnnotationHover(true) {
public Object getHoverInfo2(ITextViewer textViewer, IRegion
hoverRegion) {
IAnnotationModel model = ((SourceViewer)
textViewer).getAnnotationModel();
Iterator parent =
((IAnnotationModelExtension2)model).getAnnotationIterator(ho verRegion.getOffset(),
hoverRegion.getLength(), true, true);
Iterator iter = new JavaAnnotationIterator(parent, false);
Position position = null;
Annotation a = (Annotation) iter.next();
Position p = model.getPosition(a);
annotation = a;
position = p;
return new AnnotationInfo(annotation, position,
textViewer) {
public ICompletionProposal[] getCompletionProposals() {
proposal2 };
CLASS QUICKFIX implements IMARKERRESOLUTION
public class QuickFix implements IMarkerResolution {
String label;
QuickFix(String label) {
this.label = label;
public String getLabel() {
return label;
public void run(IMarker marker) {
MessageDialog.openInformation(null, "QuickFix Demo",
"This quick-fix is not yet implemented");
CLASS QUICKFIXHANDLER implements ABSTRACTHANDLER
public class QuickFixHandler extends AbstractHandler {
public Object execute(ExecutionEvent event) throws ExecutionException {
IWorkbenchPart part = HandlerUtil.getActivePart(event);
if (part instanceof View) {
((View) part).showPossibleQuickAssists();
return null;
EXTENSION POINTS FOR CONTEXT MENU AND COMMAND HANDLER
<extension point="org.eclipse.ui.handlers">
<handler
class="eu.etaxonomy.taxeditor.tests.QuickFixHandler"
commandId=" org.eclipse.jdt.ui.edit.text.java.correction.assist.proposal s ">
<activeWhen>
<with variable="activePartId">
<equals value="eu.etaxonomy.taxeditor.tests.view" />
</with>
</activeWhen>
</handler>
</extension>
<extension
</extension>
Current Time: Sat Nov 08 17:24:40 EST 2025
Powered by FUDForum. Page generated in 0.24155 seconds
