Home » Eclipse Projects » Eclipse Platform » retrieving local history of an IFile
retrieving local history of an IFile [message #334534] Mon, 16 February 2009 11:51 Go to next message
--------------060206060303020808050007
hi,
I have found a way to retrieve the history of a given IFile when its
project is connected to a VCS repository through code as :
<snip>
final IProject project = file.getProject();
final RepositoryProvider provider = RepositoryProvider.getProvider(project);
final IFileHistoryProvider historyProvider =
provider.getFileHistoryProvider();
final IFileHistory history = historyProvider.getFileHistoryFor(target,
IFileHistoryProvider.NONE, new NullProgressMonitor());
</snip>
Though try as I might, I cannot find any API way of retrieving the same
information when the project is _not_ connected to a repository. All I
found was something like
<snip>
final FileSystemManager fsm =
((org.eclipse.core.internal.resources.Workspace)workspace).g etFileSystemManager();
final HistoryStore = fsm.getStates(file.getFullPath(), new
</snip>
Which leads to a fair amount of discouraged access warnings. Isn't there
any open API I'd have missed while digging through the code?
Laurent Goubet
Obeo
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr/">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------060206060303020808050007--
Re: retrieving local history of an IFile [message #334535 is a reply to message #334534] Mon, 16 February 2009 12:30 Go to previous messageGo to next message
--------------090600000105000505090309
Sorry, went a little overboard on that one ... my IFile was not an IFile
(IResource :p) and I was too confident in the code completion.
Laurent Goubet
Obeo
laurent Goubet a
Re: retrieving local history of an IFile [message #334773 is a reply to message #334535] Thu, 26 February 2009 13:35 Go to previous message
Hi Laurent,
I am trying to retrieve the latest file in the local history. Did you get
it to work without accessing the internal API so that you do not get the
discourage access warnings?
I have something like:
FileSystemResourceManager fsm =
((org.eclipse.core.internal.resources.Workspace)PlusUIPlugin .getWorkspace()).getFileSystemManager();
IFileState[] fileStates =
fsm.getHistoryStore().getStates(myFile.getFullPath(),null);
InputStream is = fileStates[0].getContents(); //these are the contents I
want of the last file.
Zeus
Previous Topic:[Databinding] Problem with listener of AggregateValidationStatus
Next Topic:Assembly indexer in Ganymede
Current Time: Mon Jul 21 21:42:44 EDT 2025
Powered by FUDForum. Page generated in 0.28277 seconds
