Home » Eclipse Projects » Eclipse Platform » Breakpoint View not refreshing for my debugger
Breakpoint View not refreshing for my debugger [message #334504] Thu, 12 February 2009 17:53 Go to next message
Originally posted by: ross.siberiancellars.com
I have implemented a debugger for a custom environment (Callflow Debugger)
following the paper by
DarinWright and Bjorn Freeman--Benson. However, I am having problems
with the Breakpoints View refreshing. When I send the DebugEvent.Create
via DebugPlugin.getDefault().fireEventSet(....), I would expect a UI refresh
so that I can change the breakpoint icon from the default to the icon
display when they are active in my IDebugModelPresentation class as
happens when you are debugging Java.
Everything else seems to generally be working except that.
Ross Yakulis
Re: Breakpoint View not refreshing for my debugger [message #334516 is a reply to message #334504] Fri, 13 February 2009 11:25 Go to previous message
I figured this out. To get the breakpointView to refresh, you need to
invoke the fireBreakPointChanged() on all the breaakpoints your debugger
supports.
for all breakpoints set that I own
DebugPlugin.getDefault().getBreakPointManager().fireBreakpoi ntChanged(breakpoint)
"Ross Yakulis" <ross@siberiancellars.com> wrote in message
news:gn2991$lr9$1@build.eclipse.org...
> refresh
> Ross Yakulis
Previous Topic:Best way to test an update site
Next Topic:[FieldAssist] Pasting into a control with field assist not working?
Current Time: Thu Jul 17 17:31:43 EDT 2025
Powered by FUDForum. Page generated in 0.07149 seconds
