Home » Eclipse Projects » Eclipse Platform » Print multiple files at once
Print multiple files at once [message #334291] Fri, 30 January 2009 19:22 Go to next message
In Eclipse, is it possible to print multiple files at once
programmatically where only one of files is opened in the editor?
Thanks.
Re: Print multiple files at once [message #334299 is a reply to message #334291] Sun, 01 February 2009 11:17 Go to previous messageGo to next message
Janice wrote:
Almost everything is possible via code ;-)
Dani
> Thanks.
Re: Print multiple files at once [message #334405 is a reply to message #334299] Fri, 06 February 2009 19:18 Go to previous message
I am using StyledText to display the content of one file. Is it safe to
open all the files that I'd like to print together, concatenate the
contents into one string, and set this string with
'StyledText.getContent().setText()' to StyledText. Then call print from
StyledText, and set the original text back to the StyledText?
Thanks.
Previous Topic:Form.reflow()
Next Topic:Using command Framework to add items to pagebooks
Current Time: Fri Nov 14 19:23:55 EST 2025
Powered by FUDForum. Page generated in 0.03394 seconds
